The Eighty-Sixed Runner
Started by Doof, September 27, 2007, 08:22:00 PM
0 Members and 19 Guests are viewing this topic.
whats the next step
keep the runner
2nd gen extra cab/first gen bed
Duffil
Doof
new poll...
post what you picked and reasons if you dont mind... thanks :beer:
Duffil
DUALS.  I figure you might as well get the driveline work outta the way now.  Not to mention the gear selection you will have with stock duals.  After all, it isn't that hard to pop out the rear case and clearance it for the 4.7s.  I'm sure it would help with your front driveline binding as well.
skipnrocks
seems like you would be better off with duals now and putting in gears later.  That way you have more gearing options.  JMO.
WILLYNILLY
lilbuddy
run duals..
btw its spelled dual not duel
RIP Kyota.... you are the man
GET IT!!!
skipnrocks
Quote from: LILBUDDY on February 13, 2008, 06:46:27 PM
run duals..
Give the kid a break its not like his generation grew up with computers and spell check or anything!
WILLYNILLY
Geno
I say keep it two wheel drive and drop and bag it.
OFRD_GRL – as much as i appreciate strip clubs, i could never date a chic. they are all flopin crazy.
better front driveline angle with duals!
Doof
cant edit the poll but duals will be before case gears now....just a matter of time... im hopping that next week i can get my rear lift blocks cut and lower my pregnant dog a few inches. that would make me super stoked and want to work on it and get it close to being as done as it can be for now.
hey chris what was the dual t-case skid plate you had?
it was pretty damn BEEF
skipnrocks
Did you ever find out for sure what caused you d-shaft to bind?  Does your pinion angle need to be changed a little bit?
WILLYNILLY
lilbuddy
sky manufacturing
i like it since you can mount it either above or below the plate and even get spacers to lift it up even more.
GET IT!!!
Doof
just the :pokinit: for saken angle on the DL. when its lower it will be a lot better. i wish i could run a HP up front, but dont have the funds to buy anything like that right now. i also got the leak fixed. the flange but came unscrewed and was spewing gear oil all over. so i took that off, put it back on tight, hit the lil notch thing down in the groove on the bolt to keep it from spinning and filled it back up with 1.5 quarts of g.o. i just need to get in there and pressure wash it all clean so i know if its leaking again or not. i thought i cracked the t-case but turned out it was the loose flange...
edit:
Quote from: LILBUDDY on February 13, 2008, 07:15:03 PM
sky manufacturing
thanks dood... :thumbs:
Duals:
Better DL angles
More Gear Options.
and just the BLING factor mainnne
Doof
Geno
If you are just buying an adapter and using stock cases then 21 spline.  You can get a 23 spline adapter and 23 spline 4.70 gears and run them in the rear.
Doof
cool thanks rick... yea two stockers for the time being
skipnrocks
Do the duals only come in a 23 spline?  Or can the adapter be altered to accept 23 later?   Sounds kinda crappy if you buy an adapter and then have to buy gears and then replace the adapter again.
WILLYNILLY
Quote from: Geno on February 13, 2008, 07:28:38 PM
get the MC-07 23 spline, and get the 23 spline turbo input shaft.
then you wont have to upgrade your adaptor later when you go 23 spline 4.7s
Geno
Doof
Quote from: ImaHoToy87 on February 13, 2008, 07:33:00 PM
to bad its not a package deal... 369 for the adaptor and 150 for the turbo input shaft :yikes:
damn.... and how much for a 23 spline 4.7?
Geno
hmmm.... well personally id go duels..
Geno
Doof
24 on it? thats a debit....
or is it a credit card maxxed out?
Ramrod
duals are the shiznet fo sho, better driveline more gears and lower gearing plus easier to upgrade later
Quote from: TEAM RAMROD on February 13, 2008, 07:54:55 PM
fo sho
Doof
maxxed out lol
tax return will put me back on the better half of that though
Ramrod
