OK. Driver's side is all torn apart, painted, and ready to be rebuilt. But I have a small problem. When I took my hub apart to paint it and put new grease in it, I lost a piece. This was the first time that I had torn a Toyota hub apart, so I didn't know that there was a small spring with a ball on the end of it inside the red knob. Well, I found the spring, but I can't findthe little ball. Is this ball really all that important?? Does anyone know what I am even talking about? If I do need it, can I get it from Toyota? Or will I have to go to a junkyard and buy a whole hub just for the little tiny ball that may not even be in there? Also, I was missing one of the cone washers for some reason. Where can a replacement cone washer be sourced from? Toyota? Please help!Thanks
Is it really necessary though?
the only big rock i can see for miles and rocksurfer hits it head on!
How the hell does one get a birfield apart!?!? Do you take the c-clip out before banging on it with a brass punch, or after? I have been working on it for like an hour, and I am very pissed because I can't get it apart, and the FSM is very vague when it comes to getting the two shafts apart. Please help immediately!!!
unless you dropped it in the dirt or see metal pieces in it just use a wad of grease in your hand and pack the birf, to much chance on damage if you remove it completely
i could probably locate some
Started by 95TacoTruck General 4WD Discussion
Started by 1Bad4Runner General 4WD Discussion
Started by Poowoo Project Research and Build-Ups
Started by Bs85 Toyota Pickup/4Runner Tech 1979-95
