Knuckle Rebuild...
Started by Poowoo, November 22, 2006, 03:39:19 PM
Poowoo
Hey you guys... I just got my front end pulled apart to install some new gears in the axle... and I decided to rebuild the knuckles, but the only problem is that I don't exactly know how to. I got a rebuild kit without the wheel bearings and I have the hub taken off and I have my axle shafts out, but I just dont know how or what to replace, I am kind of a newbie when it comes to this stuff. I was just wondering if anyone had some kind of instructions or anything... I have looked around and I have only found how to get to the axle shafts which I am already at that point. Anyways sorry if this is a really task to do I am just curious and I want to do it right. Thanks Pete
don't know if this helps but here you go.  and replace everything that comes with the kit.  keep all bearings as spares.
alwayzbroken
Arew those the actual Toyota Part Numbers? I assume they are.
Poowoo
Alright thanks that does help, anything can help me at this point.
mad maud
theres another schematic to be found @  www.milneroffroad.com    there a uk 4x4 parts supplier    go to jap 4x4 parts click on toyota pickup then go into steering and suspencion and click the diagram link
IVE TRIED TO GIVE A DAM AND FAILED
toyotagod69
Yes those are and I have one of those enlarged, this does help out if you really need to rebuild the knuckles....
DTB
replace all felts, seals, gaskets, hub rebuild (gaskets), and bearings. I would recommend OEM ONLY (especially for bearings, USE ONLY Koyo or NGK japanese bearings) Also check the condition of shims
