i found that you can just use a BFH and hit the head of the stud and knock the cone washers loose.
also you'll need the 52 mm 54MM socket to get the giant nut off.
you really shouldnt do that....at least put a nut on the end of the stud and bang on that//or if you are replacing the studs it might be ok
im trying to rebuild it with all the right stuff. i already have an aussie on order, yukon529, knuckle rebuild with heavy duty axle seals. im saving for longfields hub gears, sas kit so the vented discs would pretty much complete my axle i think . once i have these i think i would be pretty close to having my front end done. for now without much cash im just cleaning everything i possibly can. anyone got suggestions or tips on cleaning the axle housing? and what do i keep from the old steering stuff?
You are doing a good job so far! I used a wire wheel, flapper disc, lots of elbow grease and a pressure washer. I would recommend capping your steering stops and gusseting the knuckle balls
all those things you recommend come with the gusset kit right?how do you go about cleaning the inside of the axle housing?
Good progress atoyot. you'll have it up and running in no time.
toilet brush, pressure washer, Super Clean...
cleaning the inside is not a fun job! very, very messy
im pretty new at this and here is my progress with my front end.
Since you're doing it right, seperate the hubs and rotors and clean out the hub and put new rotors on it.
sky manufacturing ..they were on sale for like 30 bucks each
Started by 1Bad4Runner General 4WD Discussion
Started by Poowoo Project Research and Build-Ups
Started by KDXSR5 « 1 2 3 4 » Toyota Pickup/4Runner Tech 1979-95
Started by jmac Engine
Started by slimlaudin Newbie Questions
