Author Topic: knuckle rebuild  (Read 9346 times)
Bs85
  • Turtle Points: 25
  • Male Posts: 166
  • Member since Aug '07
knuckle rebuild
« on: Aug 21, 2007, 07:49:56 PM »
ok orderd the knuckle rebuild kit because my front end is leaking like crazy and was just wondering how hard is this install and i have never took one apart before so if there is any tricks or special tools any advise would help thanks.
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: knuckle rebuild
« Reply #1 on: Aug 21, 2007, 07:56:04 PM »
Standard Metric Stockets
Standard Metric Wrenches
Lock-Ring Plyers (not snap ring plyers)
54mm (2-1/8") socket
Tube of grease
Cleaner of your choice
Jack stands
Jack
Lug wrench
1985 FSM
Pull Scale
Brass Drift
Hammer
I think that's it....
Follow the instructions in the FSM and it's cake.
Don't throw away anything until you are done.
Bs85 [OP]
  • Turtle Points: 25
  • Male Posts: 166
Re: knuckle rebuild
« Reply #2 on: Aug 21, 2007, 08:15:21 PM »
sweet thanks man!
MiniSimp
  • Male Posts: 5,120
Re: knuckle rebuild
« Reply #3 on: Aug 21, 2007, 08:45:12 PM »
Almost forgot the most important thing.....
Torque wrench!
randito
  • Turtle Points: 2
  • Male Posts: 34
  • Member since Oct '05
Re: knuckle rebuild
« Reply #4 on: Aug 22, 2007, 05:45:23 AM »
I'd give yourself twice the amount of time you think it's gonna take being that you've never done it before.  I did this last year and had trouble getting all the cone washers off and removing my tie rod.  Also depends how rusty your vehicle is and if you wanna take the time to paint your knuckles or axle housing.  Fairly straight forward though, but time consuming, for me anyway.  Good write up here as well.
http://www.4crawler.com/4Runner.shtml
79toy20r
  • Turtle Points: -1
  • Male Posts: 276
  • Member since Feb '06
Re: knuckle rebuild
« Reply #5 on: Aug 22, 2007, 11:12:53 PM »
The cone washers are a cake walk with a brass drift. Atleast they were on my rig
84pickup
  • Male Posts: 335
  • Member since May '07
  • Barnwell Mountain (stock) Texas TrailRiders Jam 08
Re: knuckle rebuild
« Reply #6 on: Aug 23, 2007, 04:08:28 PM »
why did you disconect the tie rod. did you cleanout the knuckle or something.
lets not and say we did.
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
Re: knuckle rebuild
« Reply #7 on: Aug 23, 2007, 04:33:52 PM »
Patience getting the cone washers out.
I had a couple that were difficult with the brass drift.  :yesnod:   I think I was the first guy to take them apart on my truck.  lol
I like to Drive!
  • Administrator
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: knuckle rebuild
« Reply #8 on: Aug 23, 2007, 04:51:45 PM »
Just wondering if you also ordered a pair of Heavy Duty Inner Axle Seals? If its leaking like crazy, then I'd recommend doing your best to prevent it from leaking again.
84pickup
  • Male Posts: 335
Re: knuckle rebuild
« Reply #9 on: Aug 23, 2007, 05:05:07 PM »
on the cone washers i used some punches and a hammer but after bending a few punches, i found that you can just use a BFH and hit the head of the stud and knock the cone washers loose. also you'll need the 52 mm socket to get the giant nut off. and maybe a pair of c-ring pliers the kind that spread while you squeeze the handle.
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
Re: knuckle rebuild
« Reply #10 on: Aug 23, 2007, 05:34:12 PM »
you really shouldnt do that....at least put a nut on the end of the stud and bang on that//or if you are replacing the studs it might be ok
Quote
MiniSimp
  • Male Posts: 5,120
Re: knuckle rebuild
« Reply #11 on: Aug 23, 2007, 05:50:45 PM »
also you'll need the 52 mm 54MM socket to get the giant nut off.
Fixed it for ya. :greengrin:
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
Re: knuckle rebuild
« Reply #12 on: Aug 23, 2007, 06:18:45 PM »
I think a brass hammer would be ok.     :gap:  prolly chew it up though.
I like to Drive!
atoyot
  • Male Posts: 225
  • Member since May '06
Re: knuckle rebuild
« Reply #13 on: Aug 23, 2007, 07:06:39 PM »
im pretty new at this and here is my progress with my front end.
im trying to rebuild it with all the right stuff. i already have an aussie on order, yukon529, knuckle rebuild with heavy duty axle seals. im saving for longfields hub gears, sas kit so the vented discs would pretty much complete my axle i think :dunno: . once i have these i think i would be pretty close to having my front end done. for now without much cash im just cleaning everything i possibly can. anyone got suggestions or tips on cleaning the axle housing? and what do i keep from the old steering stuff?
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: knuckle rebuild
« Reply #14 on: Aug 23, 2007, 07:20:29 PM »
You are doing a good job so far! I used a wire wheel, flapper disc, lots of elbow grease and a pressure washer. I would recommend capping your steering stops and gusseting the knuckle balls
Quote
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
Re: knuckle rebuild
« Reply #15 on: Aug 23, 2007, 07:24:00 PM »
I remember those pics DTB.  :yupyup:
Good progress atoyot.   you'll have it up and running in no time.  :thumbs:
I like to Drive!
atoyot
  • Male Posts: 225
Re: knuckle rebuild
« Reply #16 on: Aug 23, 2007, 07:48:16 PM »
all those things you recommend come with the gusset kit right?
how do you go about cleaning the inside of the axle housing?
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
Re: knuckle rebuild
« Reply #17 on: Aug 23, 2007, 07:51:44 PM »
toilet brush, pressure washer, Super Clean...
atoyot
  • Male Posts: 225
Re: knuckle rebuild
« Reply #18 on: Aug 23, 2007, 07:55:05 PM »
this is only my first step in my build. my sas and rear kit is the last thing on my mind. i want to get everything else ready before i lift it. i want to make sure i dont miss any of the major things  i would need besides the lift itself
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: knuckle rebuild
« Reply #19 on: Aug 23, 2007, 07:56:24 PM »
yes, they all come with the kit.  cleaning the inside is not a fun job! very, very messy
Quote
atoyot
  • Male Posts: 225
Re: knuckle rebuild
« Reply #20 on: Aug 23, 2007, 07:56:56 PM »
thanx very much for the tips
atoyot
  • Male Posts: 225
Re: knuckle rebuild
« Reply #21 on: Aug 23, 2007, 08:00:37 PM »
and it stinks really bad too. i just took off my diff and theres a bit of rust in it. is this normal to have rust in the upper portion?
91 super yoda
  • Turtle Points: -56
  • Male Posts: 400
  • Member since Sep '04
  • Axe' em Jacks
    • Old Town Customs
Re: knuckle rebuild
« Reply #22 on: Aug 23, 2007, 09:47:10 PM »
another easy way to brake the cone washers loose is to spin the rotor and hit the top of the locking hub with a dead blow. it wont mess up the hammer, the studs, or the nuts. takes about 10 sec. per side
MiniSimp
  • Male Posts: 5,120
Re: knuckle rebuild
« Reply #23 on: Aug 24, 2007, 05:11:09 AM »
Since you're doing it right, seperate the hubs and rotors and clean out the hub and put new rotors on it. :twocents:
atoyot
  • Male Posts: 225
Re: knuckle rebuild
« Reply #24 on: Aug 24, 2007, 05:51:54 AM »
everything on my axle is taken part and most of its cleaned and im just saving some $ to get thesas kit so i could get the new rotors on there. im also saving for my lonfields and hub gears first
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: knuckle rebuild
« Reply #25 on: Aug 24, 2007, 10:14:31 AM »
 This is just my opinion, the truss does look good though!!!!!!!
atoyot
  • Male Posts: 225
Re: knuckle rebuild
« Reply #26 on: Aug 25, 2007, 12:00:19 AM »
hey dirt toy boy where did you get the diff armor?
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: knuckle rebuild
« Reply #27 on: Aug 25, 2007, 04:52:21 PM »
sky manufacturing ..they were on sale for like 30 bucks each
Quote
atoyot
  • Male Posts: 225
Re: knuckle rebuild
« Reply #28 on: Aug 26, 2007, 01:54:54 PM »
thanx
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
Re: knuckle rebuild
« Reply #29 on: Aug 27, 2007, 10:27:08 AM »
I just got mine from them.  haven't put them on yet.  :yesnod:
I like to Drive!
Last post Aug 17, 2005, 04:43:35 AM
by 1Bad4Runner
Last post Nov 23, 2006, 02:35:34 PM
by DTB
Last post Oct 15, 2007, 09:13:49 PM
by KDXSR5
Last post Feb 11, 2008, 09:51:42 PM
by GDubb5150
Last post Dec 13, 2012, 09:57:28 PM
by 88_Pathy
