Really need your help (stumble when throttle is applied)
Started by MiniSimp, August 07, 2007, 06:59:08 PM
MiniSimp
The answer was the fuel pump, the symptoms are the following:
Ok, so to update on the progress (and lack of) so far:
Ok, so engine is throwing code 11:
Short circuit is check connector terminal T with the air conditioning switch ON or throttle switch (IDL) point OFF - defective air conditioner switch. Throttle Position Sensor (TPS) circuit, Throttle Position Sensor (TPS) or Electronic Control Unit (ECU)
No longer throws this code.
Engine threw code 2 and 6 No longer throws this code
Will not idle below 1300 RPM's After setting timing, Idle is good.
When light throttle is applied it will go to 5K RPM's Actually 3100RPMs is the highest I can get it to go.
When middle/full throttle is applied engine RPM's drop and engine sputters down to 500 RPM's and dies
TPS sensor (2nd one) is good and adjusted
Timing is set to 5*B
Idle is set to 765
There is no air leak from the air box to the throttle body. (air tube is currently wraped in Duct tape.
The AFM tested good with a meter. (AFM has not been modified)
Air box flap moves smooth
Throttle body is clean.
Fuel flow is good before and after the fuel filter (fills 18oz in 15 seconds)
Cold Start injector was replaced with a used one and now works. (fixing the hard start problem)
The ECU tested fine with a meter (except brake switch signal) picking up ECU to swap, just in case.
Spark plugs, wires, dist cap, air filter, O2 sensor are all new.
Igniter tested good with a meter.
There is a light backfire in the intake.
The exhaust is not clogged.
All ground wires are connected.
Tire pressure is 17lbs.
Video with audio:
Duffil
Duffil
Unfortunately, I don't think I know enough about the EFI to be of much help.
If you unplug the TPS, does it change the way it runs? It is pretty rare, but do you have a spare ECU to swap in and check? The only other thing I could think of would be a sticky MAF lever or bad MAF sensor, though I would think it should throw a code if that were the case. :dunno:
If you want to screw with it tomorrow or sunday, those are my days off.
*** YELLER ***
maybe you should come up here and go thru this stuff and see if you need any of it  :dunno:
:usa: :beerwhack:
except BACON
Duffil
Quote from: oldyellercj on August 07, 2007, 07:17:53 PM
:usa: :beerwhack:
see if the numbers on you ECUs match, let him borrow it for testing.
Lady Di
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
Ramrod
Duffil
Quote from: MrsWillyMammoth on August 07, 2007, 07:40:20 PM
OMG! WHAT?? MINI!!!
don't worry.  He'll be there even if it's behind my truck holding a tow rope on a skateboard.
Well, that's better than riding in a jeep, right? :rofl:
Duffil
Quote from: TEAM RAMROD on August 07, 2007, 07:41:17 PM
AIR LEAK! AIR LEAK!
I thought about that, but it should run worse at idle (higher vacuum) than at RPM.
Lady Di
Quote from: Duffil on August 07, 2007, 07:41:48 PM
:yupyup:  Unless one is welding his rear end back under his rig  :disturbed:
(OK so we're not really a jeep)
*** YELLER ***
from toy86 on Pirate
now that ive watched the video it sounds 100% like my 86 when there was a leak in the air intake tube. It happened 2 seprate times and both were just like that. Inspect for leaks, tighten clamps and if that doesnt work either get a new intake hose or wrap the one you have in duct tape (what I did before the other steps) really it solved everything
:usa: :beerwhack:
except BACON
Duffil
AIR LEAK! AIR LEAK!
Quote from: Duffil on August 07, 2007, 07:43:11 PM
or do you mean air leak, as in upstream of the tps...as opposed to vacuum.
Duffil
Quote from: oldyellercj on August 07, 2007, 07:44:59 PM
:usa: :beerwhack:
pulls in outside air, but the AFM stays in the same place, thus no more fuel.  get a can of carb cleaner and go to town.
*** YELLER ***
except BACON
IronClad
Annihilation  Fabrication
Do you need a Hammer?
Ramrod
just like I wrote on pirate first tighten all the clamps on the plastic intake hose.  after that look all around on the hose for cracks or holes.  Everyone ive seen (3-4) was in the first section where its kinda like a snake bend.  If you dont see anything i'd still just wrap it tight with ductape for the hell of it and see if it works.  thats what I did with mine and geno did on his at the rubicon
IronClad
yeepers.. i had the same problem.. wrapped my entire intake tube with duct tape and whammo  good as new
Duffil
Quote from: oldyellercj on August 07, 2007, 07:49:48 PM
Where does he go to town at ???
:usa: :beerwhack:
9th st in modesto.  place called the Brave Bull.  Or at Faces in Sacto.
MiniSimp
Tallchevy
Quote from: Duffil on August 07, 2007, 07:46:19 PM
I know the throttle body is clean cause I cleaned it before he got it. I've ran my 22RE with the intake hose off so I can spray cleaner through the throttle body while it running & it sounds just like yours. I agree, check the intake hose from the air cleaner to the throttle body.
If that don't work, I have a test ECU  from an 85 you can BARROW  :thumbs:
87 4Runner redo
Willy Mammoth
Just wrap the whole motor in duct tape that should do it.
*** YELLER ***
Quote from: Duffil on August 07, 2007, 08:01:59 PM
why do you know where that is ???
:usa: :beerwhack:
except BACON
Duffil
*** YELLER ***
except BACON
Tice
Sounds just like both times my fan went into my intake tube.
www.wheelingarizona.com
I just read this thread. I would check the air box. Have you even opened up the top cover before? If so, then how did you reseal it? Do you have any extra air boxes laying around? Check if they are the square D shape or the round D shape.
If you've got an air leak of any sizeable mention, then it would either not start up, or it would have a very sporadic idle.
Regards,
MiniSimp
Ok, hose wrapped in duct tape did not work.
I'll check the air box tomorrow, along with anything else you guys suggest between now and then.
Thanks again. :down:
85xcab
Won't the older ecm's store code 11 if you run the engine with the test connector jumped?
MiniSimp
Quote from: 85xcab on August 07, 2007, 08:58:06 PM
I have run it with it connected. Will check that tomorrow.
If you are looking for vacuum leaks, then with the engine idling, fill a spray bottle with something flammable, such as brake cleaner, and start squirting once-at-a-time around all intake hoses and vacuum lines, anywhere where vacuum exists at an idle including the line to your brake booster.
If a leak exists, then it will suck the vapors (from the mist you just sprayed) into the intake system and the idle will surge +500 rpm or so and then quickly fall back down to its previous idle.
The larger the vacuum leak the greater the RPM change during this procedure.
For any legal matters, my disclaimer to you is not to worry too much about the fumes from your spray bottle. I know you wouldn't be running your engine in an area that is not well ventilated. The flash point of brake cleaner is safe enough that you could spray it on to your cast exhaust manifold while it is running and although I do not recommend this, it will not cause any problems.
Regards,
