Really need your help (stumble when throttle is applied)
Started by MiniSimp, August 07, 2007, 06:59:08 PM
Whoops, forgot the best part: Car-parts.com reports Supra Turbo fuel pumps from $30 up to $150. Pretty inexpensive for a great part.
MiniSimp
Quote from: BigMike on August 21, 2007, 08:20:41 AM
I have not been following this thread.
That is how you start most posts in any of my threads. :down: :greengrin:
Quote from: BigMike on August 21, 2007, 08:20:41 AMSo the whole problem was the fuel pump?
I am hoping, the pump that was in there was only putting out 18psi when it should have been putting out 33psi.
Quote from: BigMike on August 21, 2007, 08:20:41 AMI know its too late now, but you should have gone with a used Toyota Supra 7M-GTE pump. It is a Denso pump and I would trust it more than I would some auto parts store pump. Best of all its a direct bolt in pump with more pressure/volume capacity.
Yep, bit too late. :slap:
Quote from: BigMike on August 21, 2007, 08:20:41 AMRegarding your posted picture above, why are you not using the factory clamps? They are smaller, and what makes me nervous, is that you should trim off the excess clamp to prevent the clamp from shorting out the connections to the pump. :o
Just using what came with the pump, the hose provided is a little thicker than the one that was on there. It'll be trimmed before installation. :yesnod:
MiniSimp
Quote from: BigMike on August 21, 2007, 08:23:17 AM
Thanks Mike, you're making me feel better about it already! :tantrum:
Duffil
MiniSimp
Quote from: Duffil on August 21, 2007, 01:12:55 PM
so, it's in by now, right?
Nope, applied the epoxy yesterday, putting it in today after work. :yesnod:
Willy Mammoth
Still not in yet? What's the hold up? What if this don't fix it, you won't have any time left.
BTW Christmas is comming.
MiniSimp
Quote from: Willy Mammoth on August 21, 2007, 01:32:07 PM
Trust me, I know. If this doesn't work then...
bigarms23
for the exhaust problem buy a free flow cat from performance products so new pipe and a new flowmaster than should button it up
MiniSimp
Quote from: bigarms23 on August 21, 2007, 02:40:31 PM
Exhaust problem? :dunno:
Wermz84
I like to Drive!
Duffil
Quote from: MiniSimp on August 21, 2007, 02:49:33 PM
yeah, that tiny 1 7/8" exhaust under it. I know, I know, "I like my torque" :blah:
Wermz84
I like to Drive!
MiniSimp
It was the fuel pump!!!!!
All is good, MCR6 is back on! See you there!
Duffil
*** YELLER ***
Quote from: MiniSimp on August 21, 2007, 06:23:24 PM
I TOLD YOU SO Well next time you might wanna listen to your favorite uncle and start there  :disturbed:
:usa: :beerwhack:
except BACON
MiniSimp
Quote from: oldyellercj on August 21, 2007, 06:28:28 PMI TOLD YOU SOWell next time you might wanna listen to your favorite uncle and start there  :disturbed:
:usa: :beerwhack:
No you didn't... :dunno:
Willy Mammoth
:hyper:
Good deal.
Always check the basics before going off the deep end with the technical stuff. :thumbs:
Wermz84
I like to Drive!
*** YELLER ***
except BACON
MiniSimp
You are having way too much fun with the smileys!!!! :talkingn:
Wermz84
I like to Drive!
highridin4x4
So who is bringing a spare pump to MCR6 just in case the epoxy gives up?  :cheese: I am glad you got it fixed. :thumbs: So are you going to carnigie to test it out?
93tonkatoy
:woohoo: :woohoo: :woohoo: :woohoo:
:drunk: :drunk: :drunk:
:party: :party: :party: :party: :party: :party: :party: :party:
:beerchug: :beerchug:
Congrats. Glad to see you got it figured out. You might want to take highridin's advice, and get the f/p mike was referring to, to take with you. If you have to take it out again, might as well put something better back in.
SAVE TELLICO post 491
MiniSimp
I'll be bringing the one I pulled out as a spare. I can feather up the throttle if I need to so it'll work.
93tonkatoy
 :clap2: :clap2: :clap2: :clap2: for everyone who got Mini pointed in the right direction. (I know that doesn't include me. :rivers: )
Friday, I finally got the time to mess with the 86 Celica I just bought for my wife. (250.00 in pretty good condition - straight body, good interior, engine runs...fair)
I cranked the engine with a jump (told bad battery), and the engine had a miss. ok, needs plugs. but it ran for a little while then I tried to move it, and it sounded just like Mini's truck! couldn't get the rpms past 3000. Immediately knew what the problem was. Ordered the pump and screen (had both parts locally - were delivered to the store Sat. morning). Drained the fuel tank and this is what I got out.
There was also sediment in the bucket (rust) and also, more still in the tank. So, I dropped the tank, removed the pump assembly, got as much of the rust out as I could, and reinstalled the new one with the new screen and put it all back together. After hotwiring the pump to get the fuel to the rail, it cranked right up and runs like it should (still need to put in the plugs). After a break, I got to looking at the old screen, and decided to desect it. this is what came out.
That is rust powder and rust balls between the two pieces. Because of this, I am still going to have to find the fuel filter and change it out.
I must give a very BIG THANK YOU to everyone who helped Mini with his problem, because I would still be pulling my hair out trying to figure it out by myself. And another big thanks to mini for starting this thread.
Now a question: Is there a way to test a f/p on the bench? The ?clogged? screen is why I'm asking.
