went to start up my truck today after doing a little welding and we couldnt get it going Angry, we disconnected the battery while welding too. then after a bunch of tries it started up and we shut it off to put the air cleaner back on and then it wouldnt start back up. we checked the spark plug for spark and nothing. when sent power to the primary side of the coil and attached a lead to the secondary side the coil sparked the module is getting 12 volts to it. we checked the power going to the hall effect sensor( i believe that is what it is ) it had .67 volts on one terminal and nothing on the other. any ideas what could be wrong?
