Project Toyotal Chaos
Started by ben_teq, May 20, 2007, 11:42:51 AM
Slolyfe
You'll never take me alive
Coming together, good job man!
Russell_G
Wow dude!!! Freakin WOW!!!!! Looks really good. I honestly cant say i saw this project going this direction.
What are your plans for the new floor and seams? Seam sealer? line-X?
87 longbed bobbed 12inches, locked,geared,Tacoma dash, 3rz swap Its a never ending project.
My build
http://board.marlincrawler.com/index.php?topic=58589.0
minicrawlin
 :drooling:    thats the second coolest thing i've seen in a long time! great work man! keep it going, racing seasons wheeling season too ha ha
the rocks Rock in South D SON!
fade
I got 1 word. Amazing. Keep up the awesome work man. That thing is bitchin.
86 mini truck 18" rays
09 highlander
70 suburban
89sastoyo
ha all I have to say is wow. Great build man I haven't signed in for a couple weeks and BAM 7mgte first gen haha. I would deffinetly consider beefin up your cross member. I have mine with a slit piece of schedule 40 on the botom with the center section recessed in and gussets galore and it still managed to crack and tried falling apart... with that boosted motor and the cases I think you might run into problems later on down the road. Other than that man this things gangster keep up the good work.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
Johnny5
looks awesome man.incase i missed it was size iroks u running??
HDcruiser
Keep up the good work  :thumbs: she looks awesome!!
krelnydelnky
hot damn what motor is that?? nice work man unreal
COFFIN CRAWLERZZ CRU
GONZO97
this build is freaking clean good work man
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
ben_teq
Did a couple things the last few days, worked on a dash bezel and finished up the cross member. The to do list is getting smaller. Also fj-rankenstein was over working with wiring, it was a long day of weeding out wires mapping things out and sitting on the ground...but we got a lot accomplished, we got rid of A LOT of truck harness that doesn't need to be there anymore, re routed some wires and started to get ready for some donor car harness to be grafted into the truck harness.
Harness coming together
unclejpl4x4
i love the dash thats nice simple and sweet just how i like it
fade
Don't throw out that wire. Melt it down and sell it for beer/gas moneys...
09 highlander
70 suburban
TheCookieMonster
sweet ass truck. you canadians do some good work up there  :beerchug:
pumkin toy
truck is lookin sick!  I need to get the intercooler installed on mine
97 4runner Limited
fj-rankenstein
i enjoy working on the electrical portion quite a bit...  with benp's harness we are stripping everything out of the harness that doesnt have to be there..  basically the same thing that i did to project extend-a-toy..
the things that i deleted out of the harness were:
-the factory wiring for the speakers and stereo...  the connector in the fuse box will be taken out and another connector with heavier gauge wire will take its place..  this will now be a circuit that will power the 7m engine ecu...
-the next to go was the entire a/c portion of the harness... i took all the extra wiring out and will also use this circuit for either the engine swap or something like the electric water pump or some other accessory needing power.
- then, sinse the harness was apart, we took the main power wires/ charging wires that went from the battery and are switching them over to exit on the other side of the harness..  the positive battery terminal will end up sitting on the opposite fender from the stock position so this is where the new power will come into the harness..   i really hate when people do motor swaps and string wires over the engine or just have the wiring be a complete mess..
-the main wire for the starter solenoid also got rerouted through the harness to the other side sinse the starter is on the opposite side of the original 22r...
the wires and connector were then farmed out of the supra harness for the C1, B1 and M1 connections and now are awaiting their new home on the 22r first gen truck harness...  we should then have an engine that turns over and mabey even starts..    :thumbs:
the never ending build...
http://board.marlincrawler.com/index.php?topic=12165.0;highlight=extend-a-toy
Quote from: BigMike on April 10, 2010, 11:30:18 AM
Was searching for something and came across this old jew. BUMP to a classic thread :thumbs:
pumkin toy
Damn I need you to come and re-wire my 7mgte!  My harness is kinda scary
97 4runner Limited
GrenadedToy
so was there absolutely no way a radiator would fit in the front core support? even without the intercooler?
Reason I ask is Id really like to swap in the 7mgte into my 72 hilux, but seeing as my engine bay is about 2 inches shorter than a 2nd gen(pretty close to a 1st gen maybe? not sure), I dont know how super tight of a fit it would be. I would definately have to cut the core support. and putting the radiator in the bed is not an option for me.
super sick build.   :cool:
pumkin toy
Quote from: GrenadedToy on May 31, 2010, 03:18:11 PM
Well just for some reference info, my 7mgte in the 4runner is pretty much as tight as possible to the firewall with no bodylift.  I had to cut the core support out just to move the radiator forward enough to clear the pulleys.  I am also running an electric fan in front of the radiator because there is no room for the factory mechanical fan.  Its tight man!  those straight six's are kinda long.
97 4runner Limited
BUDDERS
Quote from: pumkin toy on June 01, 2010, 08:43:34 PM
I wonder if the 1jz or the 2jz are shorter than the 7m?
runner88
WOW!  Excellent craftsmanship!   :beer:
ben_teq
Quote from: BUDDERS on June 01, 2010, 10:16:45 PM
No im almost certain they are an inch or so longer
I maybe could have fit a rad up front but I woulda had to rework a bunch of metal and probably had to ditch the grill or move it ahead lots.
The rear mount rad its not that bad, in the future im gonna ditch the 1.5" lines and go with the fancy an fittings and steel braided lines. Would have been way easier to do that in the first place.
What kinda build are you doin? anything can fit man...cut apart the firewall make it work.
GrenadedToy
Link is in my sig..
I just put a 22re on pane in my hilux but with me wanting to drive back and forth to the trails and around town, filling up is getting to be a pain, milage isn't really the greatest either. and more power is always good  :greengrin: so down the road, I'll probably covert back to gas. I will not conform and buy a tow rig! Its way cooler IMO to drive you're junk to the trail and back.
I heard the JZ motors are like 3 inches longer than the 7m actually..
If I did go this route, Im still stuck between N/A(cheap) and turbo( :driving:).. I figure if Im going through all the work to swap, might as well go turbo, but I want to keep my w56 and diffs alive.
Is it a pain in the ass to work on the motor in such a tight engine bay?
GrenadedToy
not the exact body style of my truck but a 72 hilux none the less.
I spy a 7m...
pumkin toy
I havnt had any problems working on things in my engine bay.  on the sides of the engine there is still plenty of room.  Its just kinda tight to change belts and stuff up front, but really not too bad.
97 4runner Limited
ben_teq
I started some inner doors panels, I made them out of 14 gauge, they are a little hefty but should cut down on road noise. As well a buddy machined me a beefy tube clamp for the hydro assist.
Jaysen
95 22RE. Toyota Ext.Cab SAS. Dual Case.
1988 Honda Civic 4dr lx,
2007 Honda Ruckus scooter
minicrawlin
nice she's moving along!
i like how your using your race car as a bench in the pic with the dash ha ha ha Sweeeet! You gonna install gauages and stereo into that dash panel?
ben_teq
Quote from: minicrawlin on June 06, 2010, 08:02:39 PM
Im gonna put in a cd player, boost gauge, a couple elocker switches, I don't wanna crowd it to much just gonna keep it simple.
minicrawlin
nice keep it simple is where its at!
couple elocker switches mean your going with two selectables instead of the aussie in the rear?
keep up the good work up there in C to the AnaDa man!     :biggthumpup:
