My 82 ex-cab...Hydro-Assist questions
Started by 82juguete, May 17, 2007, 07:53:58 PM
82juguete
And the PURDY head, resurfaced with a valve job and looking brand new...
82juguete
I'm ready to get this thing back together ASAP, but with a wise understanding of the way things tend to go, I'll be stoked if im back on the road in 2-3 weeks
82juguete
Got some stuff painted today and couldnt resist throwin it together to get a preview...
also painted the oilpan and timing cover since i had leftover paint
I CANT WAIT TO FINISH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
82 HiLux
that engine is looking sweet!
when you are bolting the head onto the engine, make sure to torque the very front head bolt that goes down into the timing cover to 9 FOOT POUNDS  otherwise you will break the timing cover.  i try to share that with as many people as possible because its easy to over torque that bolt and break the timing cover. i like that red paint
82juguete
Thanks for the pointer... Im sure ill be inquiring for many other tips along the way haha
skipnrocks
WILLYNILLY
Joey88RUNR
82juguete
Yea it would, but i just need to get this thing back on the road.  I dont need an added variable until i get it fired back up...then i might consider EFI further down the road.
82juguete
UPDATE!!!
Engine is in... i got a few days worth of hooking up lines, wires and such and its time to fire her up!
hilux-1983
82juguete
Also ran a new exhaust off my new header.... should flow like crazy compared to the stock setup... ill enjoy it till i gotta swap it back for smog..
2-1/4" straight pipe to a purple horny and a turndown....  I really liked the sound of the glasspack on my first exhaust so i kept the theme..
82 HiLux
sweet! theres nothing better than firing up a freshly rebuilt engine for the first time. make sure to follow all the break in rules!!!!
82juguete
Yea i cant wait...
Hey can someone post some pics of the heater tube setup that mounts to the back of the timing cover on the drivers side?  I seem to have misplaced it and im drawing a blank on what it looks like...and where it goes to
82juguete
Anyone???  I just got these few odds and ends and then im hopin to fire this thing later this week
82 HiLux
i could take a picture for you tomorrow when its light out. i have the same motor. send me a PM so i dont forget
82juguete
Alright so i am missing an important piece and after looking at a buddies junk 22r im finding that the heater tube is something like this
It mounts here:
Goes under the header like this and then theres a section of hose joining it to another hard pipe that goes to the bottom of the intake somewhere... is this correct??:
I dont really understand what this does... were all 22r's like this?  I cant seem to locate the hard pipe on the bottom of the intake, and i basically left that alone when i pulled the motor...
really confused and the fact that these seem to be the only parts i cant find has me baffled!
:headscratch:
82juguete
Also, I am assuming that this hose connects here, again on the drivers side down by the header
but on 2 other trucks ive looked at, this little port off the hard pipe is just plugged off...is this because they are bypassing the heater???
89sastoyo
When I put the header on my 84 I just unbolted that bs. one of them is from the exaust side and it preheats the intake or something or other? not exactly sure but thats what I was told. The one on the intake I have always seen even on 20rs but if you dont have one and it doesnt leak im sure you dont need it because I forgot to tighten mine one the 84 and it leaked everywhere. It shouldnt hook into the one on the exaust side either. The one on the exaust side only has air going threw it no water.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
82juguete
I think your talking about the tube that recirculates exhaust back around the block and to that asv valve or whatever on the pass side.  I did eliminate that since the header has no provisions for it, but this other tube comes directly off the timing cover and follows almost the same route...
hilux-1983
I took pics of what you need. I'll post them in a few.
hilux-1983
#230
Ok, after a little picture taking and "fancy" editing, here you go:
Driver side:
Passenger side, just in case you need it too
Hope this clears it all up. Advice is nice but backing it up with pictures is best.
82juguete
thanks a lot man, but i got it figured out...just needed that blockoff plate and it was still stuck to the old timing cover.  That weird setup i saw mustve been only on a few years of 22r.  Thanks for posting the pics though, i really appreciate it.  :thumbs:
ALmost got to fire the motor today but the water pump is leaking like crazy, so i need to pull it off tomorrow, check it, redo the gasket and seal it up better i guess... i hope to God thats all it takes...  :crossed:
82juguete
Well i pulled the pump today, and the gasket was all retarded looking... i dont know how i missed it initially, but it was the wrong shape right where the leak formed and there was no gasket on the mating surface at all in that area.  Nice, easy fix right?  Well i put a new, better fitting gasket on with some high-tack spray, torqued it on and put some water in, only to find another small leak coming from around the water bypass tube.  So frustrating.  Im pulllin that tomorrow to reseal it...but if its the timing cover thats leaking ima be a little pissed.
89sastoyo
nice thats good to hear and yeah thats the same one i didnt tighten and it leaked but good o hear you got it covered let us know how the motor runs
92 2wd DD
first gen cab
82juguete
Finally took care of the leaks!!!  :woohoo: Pulled the water tube today and i dont know how it got overlooked... there was some old gasket material i missed and the whole flange itself was warped right toward the middle where the tube is supposed to mate to the timing cover.  I cut the gasket out, which i think should be a seperate gasket anyway, and made a new one outta gasket material.  Used another bypass tube in better shape, sealed it up good, bolted it back on, pulled the t-stat and filled up the block with water...NO LEAKS.  just need to bolt up the stuff i had to undo and get the rad back from getting re-cored and God-willing this thing will breathe, hopefully tuesday.
82juguete
It finally runs....
but theres a catch.
Oil pump started leaking like crazy, and given that its sealed with an o-ring, its clear that it has failed in one way or another.  Oil seems to be leaking from the lower left bolt on the pump, and pulling this bolt verifies this,as oil almost streams out when the bolt is removed.  Removing bolt also reveals that the hole is stripped and will need to be heli-coiled tomorrow.  This could also be the source of the leak since stripped bolt couldnt torque properly.  All in all its a pretty accessible fix, and i was really happy with how the motor runs (minus said leak)
hilux-1983
82juguete
Got the oil pump leak fixed, o-ring got chewed up between the edge of the outer pump gear somehow  :shake: ..  Got it back together and fixed a small coolant leak where the heater hose meets the firewall and actually got to drive it!   :driving:
Now ive got a couple of questions... being that i have never experienced a brand new clutch before, is it normal for there to be a slight whirring sound upon engagement?  It only happens briefly and goes away when the clutch is fully released.  Its a marlin 1200 lb clutch and i did new pilot, throwout, the works.  Keep in mind my shifter covers are still off, so drivetrain noise is a lot more noticeable than usual.  Anything out of the ordinary with that noise??
Also, my odometer stopped turning at 279699, so i was curious if anyone had ideas for how to monitor my mileage during this critical break in period.  Fixing the odo would be the best but i understand its quite an ordeal, and im not even sure if something is busted beyond repair.  Keeping a manual log on paper of mileage is most likely what ill do, but i know its pretty inaccurate...
Pretty stoked on gettin it rolling again, and cant wait to break it in and open this thing up.
gmack192
what brand of header are you using? and where did you find it??    Thanks
82juguete
Header brand unknown, i havent really seen any others like it... and i bought it from TRACKER on this board.  It fits nicely and doesnt leak so im happy with it...
