Her Name is Frank
Started by Twisted Minis, April 18, 2007, 06:36:05 PM
0 Members and 13 Guests are viewing this topic.
topar
Quote from: BUDDERS on October 28, 2008, 03:00:32 PM
Did you just say you are a fat-ass?  I don't think you want to open that can of worms.
Damn if he is a fat ass WTH am I?
Twisted Minis
Thats not me on the bike. Just a friend of mine that seems to be around every time I am building a bike. I'm 6'2" 280 lbs.
2002 Dodge 2500 Cummins
topar
6'4" and 260 lbs and I am a fat ass, Actually founding father of the Buddha Bellied Boys club!
would you make 4WD IFS Arms, to allow a Air shock and be able to keep the stock BJ's and make them 3in wider to able to run T100 CVs.
how much you think that'd run for all 4 arms.
boxed arms.
I have a few friends wondering.
NorCalToy
Quote from: that HO kid on October 28, 2008, 11:05:41 PM
boxed arms.
:D
:flamer: IFS
Twisted Minis
I dwarf these bikes, I'm just normally the one holding the camera.
Me and the guy in the other shot.
He's a little guy. Like a buck forty wet.
Twisted Minis
boxed arms.
I likely can do it, but I need some more info. By 3" wider, are you saying to make the track width wider? Meaning longer than stock control arms? If you have some stock arms I can work off of I can make it work. Doing formed sheet arms is a lot of work, so you are probably looking at a minimum of $1K for a full set, just guessing without knowing what the stock arms look like.
Jud
Damn you do nice work!
I have a few buddies with bagged S10's and 1500's down here in Modesto.
"bout tree fiddy"
Quote from: Twisted Minis on October 28, 2008, 11:11:07 PM
Tube would do too with some plate for where the BJs bolt on at. yes I meant 3in wider by widening the track. We could send in a full set of control arms to you, as I am not sure if both sides are symmetrical. Just needs be able to run a 2.0 Air Shock on either front side of back side of the arm. (in front of or back of the CV axle shaft.)
Twisted Minis
Yeah if you can send me a full set of arms I can do it. I will need to know how far to offset mounts for the shock, or pictures with dimensions.
Quote from: Twisted Minis on October 29, 2008, 09:04:46 AM
i will work on a design and let you know when they are sent in.
I think NorCalToy will be sending his in.
Twisted Minis
Got some custom cup holders.
Built a crossmember and hung the axle.
A little rear wheel camber.
Twisted Minis
GJToyotabug
thats a kinda sick lookin rear end did it come out of the crown vic or something else?
crawlerdan
Quote from: GJToyotabug on October 29, 2008, 08:37:23 PM
looks like a jag to me. or a vete
Twisted Minis
Its a Jaguar axle. The stock axle is sitting next to the car in the last picture.
It wouldn't need wheel adapters and custom mounts if it was stock.  ;)
GJToyotabug
lol i wasnt paying attention looks good
wflaw45
cant wait to see pictures of that interceptor on the ground!
that's the strangest axle I've ever seen.
Twisted Minis
Look up a 60s Mercedes. Its weird too.
Twisted Minis
toy4x4ota
LIFTED TRUCKS ARE GAY
46&2
BUDDERS
I really like the suspension for the seat pan.  Did that shock come off a mountain bike?
The exhausT looks cool too, but I'm curious, does the wrap around part actually serve a purpose (like more backpressure) or is it just for looks?
Twisted Minis
Quote from: BUDDERS on November 01, 2008, 07:39:04 AM
Yeah its a cheap mountain bike spring.
The loop in the header is an old go kart racing trick. The loop is there for back pressure as well as length. It provides more top end power with the length, and helps the motor rev a bit higher. It helps these motors a lot, since they are industrial, and create mostly torque.  There are companies that have been selling racing headers with the same design for years. And I have used the same setup on a few go karts with great results, even increasing top speed without changing anything else. And the bike will be set up with a very low gear ratio so it should have good all around power.
BUDDERS
Right on  :thumbs: I thought it might be a trick to squeeze a few more ponies out of those motors.
Twisted Minis
Every little bit counts when you've only got 5!
muddytaco
nice truck like the lexus emblems and wheels awesome little touches
95 tacoma 5" revtek/bilstein detroit locked 9" with drilled and slotted rotors front and back, 8000# mile marker winch, 16" crager crawlers, too much other crap to mention
96 t100 2wd (soon to be sasd i hope) - dead
85 efi 4runner
01 sequoia
muddytaco
that crown vic is bad too is that a vette rearend?
85 efi 4runner
01 sequoia
crawlerdan
Quote from: muddytaco on November 02, 2008, 04:36:17 PM
jaguar rear end
