1982 rockcrawler/racecar
Started by 82 HiLux, April 03, 2007, 10:12:36 AM
NorCalToy
doesnt look like nearly that much...wow.
what leaves did you say you were running in the front? i know RUF, but custom pack or what?
btw nice truck. im diggin the white :afro:
:flamer: IFS
82 HiLux
mixed rear packs from my 82 and from an 86 4runner. i had 6 leaves in the springs at first, the top 3 from both truck's rear packs. then i took out one that was in the middle that was a different shape from all the others, mostly because i wanted it a little softer.  now its perfect. it doesnt lean around corners at normal speeds, but driving fast i have almost rolled it once taking a left turn and hitting a big bump in the road.  if i turn really suddenly and hit the brakes, lets say for example in a parking lot parking in a space, one of the back tires will come off the ground.  the springs are pretty soft but i find them to be perfect considering how the work off road. they work amazing, plus COST ME NOTHING
82 HiLux
took a couple pics when i was wheeling to show flex
can anyone spot the problem here?
Mavericks
looks like you need a longer bump stop or your shock needs to be mounted higher, your shocks are bottoming out. looks like you have pretty good flex to me. Nice Truck!
1985 toyota SR5, 22re,  5.29's locked front and rear, duals with twin stick, longfields.
82 HiLux
ya, i have taller bumpstops and bigger tubing to put there. i used the smaller sizes first because i thought it would make it.  :_oops:
not a hard fix though, and i was driving real slow when the shock bottomed out so it didnt suffer any damage. whew
82 HiLux
or is "the problem" i mentioned the oil leak my engine has!??!?! thats also a problem lol
Mavericks
is  the front seal leaking? i had to fix that on mine too. Getting started is the hardest part.
82 HiLux
ya the front crank seal leaks. ive torn into the engine a couple times, and im not willing to again until i can afford a total rebuild and sick parts
have you sleeved the front crank seal yet?
82 HiLux
nope, havent touched it yet.
82 HiLux
realized today my fuel pressure sending unit leaks oil, and thats the reason theres oil all over my axle.
wrapped my header today with header wrap.  WHAT A DIFFERENCE! WOW!
tonight im going to take my weber apart yet again and re-route the float bowl vent to a catch can so i can go up steep hills.
more on this later....
:beerchug:
Pat Just
you have one hell of a nice truck
82 HiLux
thank you :greengrin: ive put a lot of work into it
heres what im doing... this is some great sheit for you other weber guys
hole #1 filled.  the bump you see that i drilled the 7 small holes into is the new float bowl vent.  that bump goes to the hole on the outside of the carb in the last picture
hole #2 filled, both still wet
plugged the top of the old float bowl vent tubes with wax, so the JB weld will settle in and not drain out of the hole. after its dry, remove the wax
the hole where i will attach some 3/8"OD tubing
to be continued...
BigBs84
 :bowdown: I want more on the weber please. And I put you on page 5
Build it wright-wind it tight
   High-N-Tight offroad
http://board.marlincrawler.com/index.php?topic=45027.0 My truggy build
82 HiLux
im gonna get cleaned up and go test it out, i just finished with it.  some problems developed with the carb as far as tuning goes, but i think i have it mostly worked out now.  id describe it, but what ever. ill figure it out. im gonna go try and get to this really good spot in town, its behind a construction site, so its hard to get to unnoticed. it has a REALLY steep dirt wall i can try and drive up and see how it does! i have a feeling the modifications i did WONT fix the problem for some reason though....this just seems too easy. if i go out there and it climbs that hill with no problems, ill be stoked.
82 HiLux
yesterday i converted to an electric fuel pump and got to block off the hole in my head where the mechanical one was. i also made my webers float bowl vent into the fuel return line going to the gas tank.  i had some problems with the fuel pressure regulator so for the time being i removed it. the weber 38 runs GREAT with my universal electric fuel pump which is rated at 4-7 psi. the weber only wants 2 to 3 but it runs great and has no problems. ill have to get pics later of the couple things i did, im pretty excited to try it out on some hills and see how it does.
as for you weber guys, re-routing the float bowl vent is REALLY easy. if you are knowledgable enough to put a weber on your truck in the first place, you can do this little trick. you can see the port on the outside of the carb that you will use. its right on top of the float bowl. just get a piece of 3/8th OD copper tubing, sand it a little where you will insert it, and stick it in the hole. i used red loctite on the outside of the copper when i put it in the hole because it hardens up nicely like glue. it works GREAT for this, sealed the tube in there nicely and holds it strong, and its heat resistant. then just route your new tube into your fuel return line. if you dont know which one it is, look at the top of your gas tank and follow the line up the frame rails
82 HiLux
still waiting on going wheeling to try out my new carb setup....  electric fuel pumps are awesome! i love my new setup, it works flawlessly.
I just got hired by a company called Quality Stainless Tanks in windsor, ca.  i will be trained as a welder and ill be fabricating stainless steel tanks for wine or beer or whatever.  the starting wage is more than i make now and i will only go up from there.  im considering getting a motorcycle so i dont have to use my truck to drive there every day. although it is only like 10 miles to there from my house...but gas prices just KILL me in my truck getting 15-16mpg............well see.  i met all the guys at this place and within 20 minutes i had a job.  i cant wait to start getting paid to do what i love :flamer:
DTB
Quote from: 82 HiLux on July 02, 2008, 09:45:22 AM
Can you make me one of these? PLEASE?
82 HiLux
lol, probably in a few months ill be able to. right now i still have to quit my current job! i cant wait to learn to TIG weld
82 HiLux
FINALLY ORDERED A MARLIN DUAL CASE ADAPTER!!!!!!!!!!!!
and a 1600lb non ceramic clutch
:clap:
BigBs84
Oh your going to love your new duals :thumbs:
82 HiLux
only problem is since i have front and rear lockers, ill be trying to go EVERYWHERE, and my carburetor is a :stopit: when it comes to hills :maddest:
BigBs84
get an MSD and dont let off the gas
82 HiLux
#114
Quoteget an MSD
already got one, good tip though :beerchug: it kicks ass
NOTE TO SELF: DO NOT hook up float bowl vent to fuel return line! :smoke: :hammerhead:
Quote from: 82 HiLux on June 29, 2008, 05:36:51 PM
82 HiLux
ok so heres a few pictures of some stuff
i wrapped my header a while ago, and its GREAT!! a lot quieter and cooler. I went ahead and wrapped my exhaust all the way to the cat because i had extra header wrap. makes me want to wrap it all the way to the tailpipe HAHA
heres when I welded on my new spring perches for my u bolt eliminator kit from all pro.  did i mention all pro's customer service sucks donkey richard?
I DUNNO IF MY SHOCKS ARE LONG ENOUGH....
heres my new stuff
damn bro, you got some goodies, im jealous.
82 HiLux
lol thanks. ive waited a long time for this...and my time has finally come. i have FIVE DAYS in a row off before i start my new job.  ill probably finish the first day :beerchug:
I have a low mile tranny that hasnt been abused to put in in place of mine with 230k atleast on it. and I have the top shift case on my truck now and the top shift case off the tranny i have. and i have my bud built cross member and plenty of u bolts to choose from to attach it to the frame. ill just have to make another front square driveline, but with a single u joint on both ends this time, and take my rear driveline to a shop and actually get it balanced
oh and thats a marlin non-ceramic 1600lb clutch
82 HiLux
tranny and transfercase are out, old clutch is out. im ready to tear into the transfercases tomorrow and get my crawler all setup.  biggest problem right now is i need a way to get the pilot bearing out of my crankshaft. i dont have a puller for it. new bearings are so nice!!! my old throw out bearing and pilot bearing were smoked and were making noise. this is gonna be nice
BigBs84
pack the hole for that bearing with grease and use a 3/8 extention and hit the grease and it will push out that pilot bearing
