WE DONT SAY THAT HERE well ill check that out. thanks
i cant see anything in those pictures. does anyone know what i said? i cant remember....must have been bad for them to take it out
i have a bad oil leak. i heard from a buddy what he thinks it is.he says that if you dont clean the pool of oil out of the bolt hole on the top of the timing cover when you are re-installing the head or timing cover (anything where you have to remove that damned bolt), the oil in the bottom of the hold will be compressed when you are tightening the bolt and it will be forced through the cast timing cover and make a slight crack right under where that bolt grabs onto the cover. know what im trying to say? theres only 1 top bolt on the timing cover. when you take it out, theres oil in the bottom of the bolt hole. the bolt is being tightened into the hole and it quite literally FORCES the oil through the weakest point in the metal. and then it leaks like a mother*****!!!!!is this a known problem? i actually investigated by cleaning out the hole and looking in it. i couldnt see anything. duh.but then i put some water in the hold and pressurized it with some compressed air and watched the water drip out from under that spot, right where i expected it too.should i just pull the timing cover off and find the crack and repair it? maybe just pick up a new cover.i have a spare 22re, is the cover the same on that?
OK so we got the thick bacon... but RK can't find the salami... and Deans wife has the cheese...
5.71 is too low. You will break your pinion alot i've heard.
just ordered one 5.29 4cyl diff with arb and standard compressor from and well, I CANT WAIT TO GET MY STUFF AND INSTALL IT!!!!!!!!!after I pay the rest of this off I will drop the money on the same exact thing for the front, 5.29 with arb.after that, dual cases.im trying to get all this for my truck before i move out of my house in about a year or so. once i move out ill have to pay for other and i wont have any money for truck parts.
Started by Squirrel_4_life Parts For Sale
Started by canadiancrawler Parts For Sale
Started by jared A Rigs For Sale
Started by CSAKing Rigs For Sale
Started by E YOTA RC Rock Crawler Tech
