Gas Prices hit $2/gallon!
Started by BigMike, September 19, 2006, 07:28:09 AM
News said it would happen this year (2006), what do you think?
It will happen
14 (45.2%)
No way in hell
17 (54.8%)
Total Members Voted: 31
abnormaltoy
#600
Octane is really simple...it's a measure of how easily the gasoline will burn. The reason "race" engines need a fuel with a higher octane rating is not the cam...it's only because of compression. A high compression engine will diesel, the fuel will ignite from compression alone. The higher octane rating of race gas makes it harder to ignite the gas, so it won't ignite until it gets a spark. If your timing is right...a stock, or near stock, compression Toyota engine doesn't need high octane fuel...you might as well be giving the extra $$$ to the local food bank, at least it'll do somebody some good. My engine is around 11 to 1 and I have never needed to use anything other than 87 octane. If you have any doubts try this link http://www.howstuffworks.com/question90.htm
-- Winston Churchill
Travis Tritt (I know!)
thanks abnormaltoy.. that was very useful.
abnormaltoy
Duffil
abnormaltoy
Quote from: that HO kid on July 19, 2008, 09:31:56 PM
.... i know the more octane.... the better.... TO A POINT!
if you go too much octane in a street legal vehicle, it not only becomes illegal, but it starts harming :pokinit:.... therefore reversing the purpose.
Oh man, you too have been snowballed!  I always :rofl2:  when some poor sob informs me that you'll blow up an engine if you use high octane gas  :haha:  I'm fairly performance ignorant, but one of the few things I picked up growing up around stocker and te51levin was if you use a high octane fuel in a normal engine it'll......  run!  I've run 110 octane in a stock engine, flogged it unmericful for hours and never had any issue.  Only reason I ran it was cause it was barely more at the race track and I just wanted to smell it  :haha:
Quote from: kneedownnate on July 19, 2008, 11:24:20 PM
it doesnt damage rings or nothing?
abnormaltoy
It only hurts your wallet. Live and learn.
Duffil
no. Race fuel/high octane runs cooler than lower octane fuel and doesn't hurt anything.
thats good to know.... cause higher octane takes less effort to ignite, correct? thus less heat is created.
Stocker
#610
Quote from: that HO kid on July 20, 2008, 12:24:36 AM
Quote from: abnormaltoy on July 19, 2008, 10:02:10 PM
I think maybe you are confusing gasoline (and octane boosters) with other exotic fuels or additives, which are not designed for use in a normal gasoline engine.  And you may be thinking that higher octane = more power output.
Not to oversimplify, an engine's power output is determined by the components of the engine and its control mechanisms, whether mechanical (old school) or electronic.  If an engine is designed such that it requires high octane gasoline, then using low octane gas can harm the engine.  But if it is designed for low octane gas, using high octane will not make it produce more power.  Of course, if carbon deposits cause the engine to ping (spark knock, pre-ignition, detonation) on 87 octane, using a premium grade may be used to solve mask the problem.
My goal in life is to be as a good a person as my dog already thinks I am.
If you don't learn something every day, you're not paying attention.
abnormaltoy
Quote from: Stocker on July 20, 2008, 06:55:23 AM
Which is why I said a stock-ish Toy engine is fairly low compression and since higher octane resists compression ignition...higher octane fuel isn't needed. True, if you have a high compression engine you can cause damage because of detonation. But, most people know if they have a 12.5:1 engine and will use higher octane fuel. BUT...you can have a static compression ratio of 8:1, but have an effective ratio of 12:1 if you've added a turbo or supercharger, you will need higher octane in that case.
KDXSR5
I use the premium high octane gas in my truck (exxon specifically) so i can bump the timing more without detonation. The engine will not allow you to do that on regular because it begins to detonate.
abnormaltoy
Nope...higher octane fuel is harder to ignite, it resists compression ignition.
The bottom line is...if you have a stock engine use what the manufacturer suggests. Running race gas in a low/stock engine is unnecessary.
The reason people run high octane fuel (or fuel with additives) is to stop compression ignition so the charge will ignite at the proper time...when the spark plug lights it off. In a 12.5:1 engine 87 octane might light off at only 1/4 of the piston uptravel (detonation) causing the piston to fight the explosion the rest of the way toward the top. In a stock engine 87 octane will just compress until it is ignited, just before the top of the upstroke. All this is because all things being equal...compression causes heat, check out the high pressure side of a refrigeration unit.
Stocker
Quote from: abnormaltoy on July 20, 2008, 08:28:51 AM
Ack!  Sorry for the confusion, my post was directed at HO kid, not at you!!  I quoted both him and you to point out to him that you had already answered the exact question that he had just asked.
On the record, I agree with everything you posted here so far!   :thumbs:
abnormaltoy
Quote from: Stocker on July 20, 2008, 09:45:03 AM
Well, did you get the part where I get to be king of the world for a day?
I often reread something I said, like in your quote, and think I may not have made point very well...most times my mind goes way faster than my fingers, so I kind of fragment my answers. (I think it has something to do with all my partying in the 70's)  :dunno:
Wait, I didn't party in the 70s but I have the same affliction  :bolt:
JanMarie13
Quote from: kneedownnate on July 20, 2008, 09:07:40 PM
You were a RESULT of 70's partying, Nate, so I guess that counts.  :yupyup:
RIP Kyle, we love and miss you man.  :smooch:
Quote from: KYOTA on October 03, 2009, 10:33:31 AM
thanks for the smooch I miss you too !  :yesnod:
Stocker
Quote from: MPA on July 21, 2008, 05:41:16 AM
:haha:  :rofl2:
abnormaltoy
Picture Stocker and Mrs. Stocker in satin disco clothes...just a pithin' woo!
MiniSimp
Down to $4.05 with 10c discount at Safeway :-\
:rofl2:  I hadn't thought of that!
Quote from: abnormaltoy on July 21, 2008, 08:54:35 AM
I dunno, I seem to remember seeing pics of mrs. stocker wearing bell bottoms, but I'm pretty sure stocker wears the same flannel shirt and jeans as he did in the 70s  :ack:
KDXSR5
I saw 3.85 on the way to work today
abnormaltoy
Quote from: kneedownnate on July 21, 2008, 10:06:17 AM
Sounds like me...waaay different sizes, but, t-shirts and jeans (and sports man-bra :gap:). Although I dated this one girl whose parents owned a clothing store in Dallas...she bought me some oh-fishel disco clothes.
BLACKDOG
Quote from: abnormaltoy on July 21, 2008, 11:51:43 AM
:worthless:
              -Ronald Reagan
abnormaltoy
Quote from: BLACKDOG on July 21, 2008, 01:28:20 PM
:worthless:
Yeah right...like I would've left any photos around. Love/lust will make you do silly ass things, like wear satin pants on New Years Eve.
Stocker
:headscratch:   Clearly, you do not know us well...      :gap:
Quote from: kneedownnate on July 21, 2008, 10:06:17 AMI dunno, I seem to remember seeing pics of mrs. stocker wearing bell bottoms, but I'm pretty sure stocker wears the same flannel shirt and jeans as he did in the 70s  :ack:
Yer probly right -- not just the same style, the very same clothes!    :cheese:
Quote from: abnormaltoy on July 21, 2008, 01:47:50 PM
:haha:
superyota
paid $4.25 yesterday in costa mesa at the ampm.  cheepest i've seen in the last few weeks.  even cheeper than bakersfield where it was $4.39 at a fast trip the day before yesterday.  i sure am glad i got my civic up and going again.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
BLACKDOG
Saw 3.99 for gas this morning.  didn't see the diesel prices though.  I'll probably be filling up this weekend, so I'll know then.
              -Ronald Reagan
Quote from: superyota on July 22, 2008, 02:26:28 PM
Yea, but you can't fit 2nd gen doors in a civic though  :gap:
