Total Members Voted: 0
Pops make me think electrical. Check all your grounds, check for loose or frayed wires, something shorting out somewhere. Check the battery...you may have blown your alternator. Also check fuses and the big fusible links in the black box... they like to POP when they go bad.
Doubt it has anything to do with the starter...way you describe it is that you just arent getting enough juice to the starter to torque the engine over...it is going somewhere...just gotta find out where.
FOUND THE PROBLEM thanks for the help but we were all wrong. Broke the TIMING CHAIN
I am going to put in the 20r head because it will cost to much money to redo the head on the 22r. The only question i have is that the 20r head has a dual chian system on it and the 22r motor had a single chian on it what should i do change the crank gear or change the double chain to a single chain?
Started by krawlr Chit Chat Camp
Started by Roc Doc Engine
Started by 4RnrRick Engine
Started by CTENG in KS General 4WD Discussion
Started by Phazertwo « 1 2 » Toyota Pickup/4Runner Tech 1979-95
