Willy Nilly
Started by skipnrocks, May 02, 2006, 05:19:42 PM
skipnrocks
Hi everyone,  Im new here.  This is my little willlys jeep,  Ive been working on it for almost a year now :flamer:,  should be done this summer.  Its a fairly simple rig,
Hydraulic Steering
350 small block @ around 350 horses
Tuned port fuel injection
Custom four link
16" fox air shocks
Custom cage
atlas four speed t-case
14 bolt rear,
10bolt front
Detroits front and rear
And then the visuals,  bucket seats, harnesses.
Anyways the pics
The Begining
WILLYNILLY
skipnrocks
Alright everyone there it is.  As  you can see I had a bit of a rust problem :smack:,  done quite a bit, and have a bit to go. Let me know if you have any suggestions.  I have been considering ordering a fiberglass tub,  but Have gotten mixed reports.  I was gonna order it from JC whittney to be more specific.  But fiberglass is easy to work with.  As you can see in the pics my wheel base is slghtly longer,  and i need to be able to lengthen the tub here.
WILLYNILLY
Willy Mammoth
You need to go through my buildup thread. I bought a new steel tub from Vintage Jeeps in Texas. It cost me $2000 to the door here in FL.
From what I can see you have a good start.
What size tires are you going to run? I would extend the body in the wheel well so you can get the tires to clear. (see buildup for more info)
BTW  :welcome: and keep the pictures comming.
skipnrocks
#3
 :thumbs:  Thanks Man,
I have it in the workings to make the wheel wells big enough for 40s,  I have some cutaway fenders  in the parts Pile..
But I hope to run 38/12.50  give or take
By the way man,  I love your willys,  I orgionally wanted the new lib diesel for my jeep,  but the 350 was free.  I would loveto see more videos of your rig, ive already seen the ones from your sitings post,  good stuff :biggthumpup:.  I found your posts shortely after I started on mine, and have loved watching it progress.  You have some very impressive skills. :bowdown:
WILLYNILLY
Lady Di
Cool to see another Willys build on the board :wave:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
whiteman
Quote from: MrsWillyMammoth on May 03, 2006, 04:17:35 AM
X2  -  My favorite 4x4 :love:
skipnrocks
WILLYNILLY
skipnrocks
  Alright  I got a new body tub on the way, (thanks for the offer to build some pannels mammoth) but I went with a fiberglass tub since I can work that stuff.  I have tube fenders so I dont have to work on cracking them, and I think i will desighn a 3psc removable exo for rougher trails.  i dont care for the exos on dd,  so I think I can make it pin on on the sliders and cage, and then over the front clip.   :flamer:
Might be a headache but who knows it might be cool.   :reg:  I have never seen anything like it.
WILLYNILLY
skipnrocks
Ok the deed is done.  My front axle has gone from your average 10 bolt to a hd ten bolt, for what its worth.  This week in went all new seals, detroit, hd ball joints, and hd u joints, new hardened pins and a 3 in wider stance thanks to some heavyduty offroad spacers.  I am now sitting at 6ft 10in wide in front and 6ft 8in in the rear.  Dont know how wide that is compared to other rigs but it should be good for my little willys jeep :thumbs: .  I dont want to dump a ton of money in to it but I want it to be trail worthy till I get out of school and can afford to put some unimogs under it.
WILLYNILLY
Quote from: skipnrocks on May 04, 2006, 07:09:26 PM
your removeable pin idea doesnt sound like its going to have the sheer strength needed to do anything other than cause problem in the event of a roll
slorunner85
Quote from: jim74 on May 20, 2006, 06:02:58 PM
'85 4ruggy linked ft and rr
42"iroks
pro rock 60 arb
14bolt spooled
5.13
marlins dual ultimate
skipnrocks
Sheer strength wouldnt be an issue,  it would be only meant to protect the body..  But at any rate i know I didnt explain it that well but it would slide on from the side and it would be a compression issue purely on the sliders/frame and on the roll cage.  I dont know if that makes any more sence but thats the idea behind it.
Here is a getto pic i did real quick,  the red is my body tub,  and the top and bottom bar is the slider and roll cage,  the black represents the protruding pins,  and the other  bars show rough mock of bars.  In a roll it would be mostly compression,  and may limit the body work I have to do.
WILLYNILLY
Willy Mammoth
I see no problem with this idea. You just need to make sure the cage is firmly afixed to the frame.
Use a solid plug in the end of the pipe and a 1/2 through bolt.
skipnrocks
Thanks mammth,  I think thats a great idea to use a solid pin and half inch bolt.  Should be pretty sweet.  Got some other stuff to get done first.   Dang time limitiations and budgets.  Wouldnt life be good with out either.  lol :gap:
WILLYNILLY
Ramrod
is that a chevy frame? :puke:
skipnrocks
You better believe it,  the frame is from the 3/4 ton chevy i got the motor and axles from.   When I found out that my origional frame was toast I made some measurements and found that the old chevy frame was pretty darn close to what I needed,  and for a light rig would provide some extra rigity.   SO I hacked off the back end  :flamer: and this is what I ended up with.   :gap:  Which worked perfect,  I didnt have to actually pull the motor, just modified the body to fit.
WILLYNILLY
Ramrod
skipnrocks
 :gap:  Think its redneck huh. lol, oh well.  Workes great!!! :crossed:
WILLYNILLY
locktup
Ive been looking at these for an upcoming project  :flamer:.   http://www.diy4x.com/misc.htm
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
www.LOCKTUPFABRICATION.com
skipnrocks
Thats some pretty sweet stuff man :cool:.  I dont worry a whole lot about sheering bolts,  all 8 pts on my cage are held in place by 4 grade 8 bolts each 1/2in thick.  But looks like it would be a clean strong alternative.  I might use something like that on my removable exo.  It would definatly add some sheer strength.  What are you building
WILLYNILLY
locktup
Quote from: skipnrocks on May 23, 2006, 10:56:36 AM
Thats what I had in mind, was the exo.
I'm always building something for someone  :flamer:.
www.locktup4x4.com
skipnrocks
Check this guys,  A buddy of mine in montana tried to drive  :driving: through a "shallow" pond. :hammerhead:  I had to laugh at him.  Of course his truck was fine, after draining a gallon or so of water out of the oil pan.  Pulling the air box, and draining that, and pulling the plugs and sucking the water out of the cylinders.    Its ok to laugh, im his best friend and thats exactly what I did.   :ha_ha: :ha_ha: :ha_ha:
WILLYNILLY
skipnrocks
I had an epiphany today,  Tell my what you think.  I want to either move my rear shocks into the tub and attaching them directly to the cage, or running tubing down to the shock loops to keep them from flexing into the fiberglass tub,  Dont want to break anything.    Alright the pros and cons for each
PROS Running to cage inside the tub.
1.  very rigid
2.  gets the shock 2-5 inches further away from the tires.
3.  ?
Cons
1.  Dont know how to seal out road noise with a hole in the tub
2.  hole in the tub
3.  ?
Pros for keepin them outside the tub
1.  No holes in the tub
2.  ?
Cons
1.  keeps some tight but clearing clearances during flex
2.  under stress could press loop through the fiberglass tub
3. ?
Alright guys help me out with the list.   Give me some more pros and cons
WILLYNILLY
skipnrocks
Alright new question.  I was thinkin of using a bed liner in the cab to protect the fiberglass tub from my feet.  But  i  heard some people speak praises to them  :biggthumpup: , and some who complain that it didnt last as well as they wanted :thumbdown:.    So whats the best thing to do,  are they what their cracked up to be.  Am I going to be making more of a headache if i do body dammage and have a liner on the inside.   I would assume all know I am refering to the spray on type.  What should I do.  Maybe only spray the floors.
HELP
WILLYNILLY
skipnrocks
#24
 :smack: :smack: :smack: :smack: :smack: :smack: :smack: :smack: :smack: :smack:
Can anybody tell me how to do fiberglass,  Im sure you can see that i have a bit of a gap between body pieces and I dont know much about fiberglass to put it back togethere to make it look good. And WillyMammoth what kinda paint did you use?  Wasnt it some sore of one stage or single step or something?
WILLYNILLY
skipnrocks
Alright so I got tired of waiting for the body and not seeing any visual progress so i sat down with photoshop and I think i got the final color,  and am thinking a big white star on the hood.
WILLYNILLY
skipnrocks
Alright not many updates, but my rig has been declared fit for travel by the state of montana  :driving:.  Good thing they dont actually do inspections  :biggthumpup:,  Oh and check it out, new montana law,  $120 got me a perment license and registration,  yes thats right i never have to pay again   :beerchug:
WILLYNILLY
Shite!  I'm moving to montana :burnout:
Wanna take me elk huntin?!
BLACKDOG
Quote from: kneedownnate on October 07, 2006, 11:19:45 PM
No kidding :headshake:
I'm right behind ya nate :thumbs:
              -Ronald Reagan
skipnrocks
Quote from: BLACKDOG on October 08, 2006, 02:00:14 PM
Heck yea,  bring your snow shoes boys lets go huntin!!
WILLYNILLY
