Author Topic: 22re is smoking.... help me...  (Read 2921 times)
86turboyota
  • Male Posts: 1,079
  • Member since Jul '05
« on: Apr 27, 2006, 12:16:04 PM »
I cant seem to go more than 2 weeks without replacing parts on one of my toyotas... now my 86 22-re in my 4runner is buring oil... producing a fair amount of smoke when i go slowly downhill......  i have burned about half a quart in 500 miles.... what should i do?  How long will this engine last buring oil like this?  Do i need to rebuild?  What are my options?
Thanks,
Andy
My Build 1986 4runner SAS 36s etc
http://board.marlincrawler.com/index.php?topic=22625.0
"Later, I learned that even though I engage 4WD my hubs are not automatically locking? Something about manual locking hubs I think. What's manual mean? I need to read a manual to lock them? lol  So I found these neat autolocking hubs and installed them. Sometimes they dont stay locked while I am backing up, but that's fine because I dont have a backup camera to see where Im going (like our RV) so I just simply dont ever back up"- BigMike
toymech
  • Turtle Points: -155
  • Male Posts: 158
  • Member since Feb '05
Re: 22re is smoking.... help me...
« Reply #1 on: Apr 27, 2006, 06:40:52 PM »
 Do a cylinder leak down test,sounds like a stuck ring or a broken one. Hopefully its just high manifold vacuum sucking oil past the valve stem seals or a worn valve guide= easy common 22re stuff.  Good luck.   Mike :turtle:
87 Runner-rebuilt 22re,3 inch downey ifs lift,allpro rear bumper,Detroit locked rear with 4.88s,detroit true trac front diff,Marlin crawler clutch,R151F trans,Marlin Crawler 4.7 reduction gearset,33 inch Goodyear MTRs
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Apr 27, 2006, 09:06:05 PM »
Thanks,
Andy
1/2 a qt in 500 miles  :rofl:  ive seen brand new engines burn more oil than that,  probably a valve stem seal, no big deal man, dont worry about it
when you burn a quart in 100 miles then  its time for some new rings,
no more than you are burning i wouldnt touch a thing
86turboyota [OP]
  • Male Posts: 1,079
« Reply #3 on: Apr 28, 2006, 07:20:06 AM »
how do i do this test?
86turboyota [OP]
  • Male Posts: 1,079
« Reply #4 on: Apr 28, 2006, 07:21:35 AM »
Is a valve stem seal hard to change out?
86turboyota [OP]
  • Male Posts: 1,079
« Reply #5 on: Apr 28, 2006, 07:22:57 AM »
something else that i just remebered to put on here is that it only smokes on compression... such as when i go down hill but am not on the gas...
« Reply #6 on: Apr 28, 2006, 12:55:00 PM »
yea  thats just a valve stem seal,  well you CAN do it without removing the head,  but usually is done when the head is rebuilt
you have to remove the valve spring and retainer and replace the stem seal,  not really worth the trouble if ya ask me
Last post Jul 27, 2008, 05:18:56 AM
by Trunkz
Last post May 19, 2011, 11:03:53 PM
by yotaneck13
Last post Jan 07, 2011, 11:11:31 PM
by bamajojo9
Last post Jan 18, 2011, 08:30:54 PM
by dgrant71
Last post May 31, 2020, 11:14:15 AM
by Gnarly4X
