Author Topic: 22r smoking inside cab!!  (Read 4023 times)
bamajojo9
  • Member since Apr '10
« on: Jan 03, 2011, 07:26:26 AM »
So I have an 87 pu with a 22 r in it and its smoking into the cab through the little transfer case hole... I do have a front differential leak, could this be that with a lackbof oil, or could it be like an exhaust leak into the truck?
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Member since Aug '10
  • Get Some
Re: 22r smoking inside cab!!
« Reply #1 on: Jan 03, 2011, 07:57:10 AM »
Sounds like some oil burning and or your tranny is getting real hot
You should take a peak with a light around dark smoke can be seen w a light
Good luck
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #2 on: Jan 03, 2011, 08:04:54 AM »
My guess, is that you have a leak, and its burning on your exhaust.  Does it smoke going down the road, sitting still, or both ?
bamajojo9 [OP]
« Reply #3 on: Jan 03, 2011, 08:26:21 PM »
Most when driving but sometimes not moving to but not all the time
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #4 on: Jan 03, 2011, 08:40:35 PM »
Do you have a GOOD boot on the shifters?
83yota5960
  • Turtle Points: -20
  • Male Posts: 551
  • Member since Sep '09
« Reply #5 on: Jan 03, 2011, 08:49:09 PM »
does it smell like exhaust, if so you got a leak my truck was like that smoky exhaust pored threw the boot, about killed me, had to drive with my head out the window.
83 short bed yota 35's 5.29's 4.7 f-150's arb front aussie locker rear high steer ifs rear axle
83 short bed yota 31 a/t mild lift welded ifs rear axle
99 audi A4 as my new daily driver.
bamajojo9 [OP]
« Reply #6 on: Jan 03, 2011, 09:38:16 PM »
bamajojo9 [OP]
« Reply #7 on: Jan 03, 2011, 09:41:10 PM »
I really can't tell.... all I no is that it comes yo from the transfer case hole and worries me that it might be exhaust
83yota5960
  • Male Posts: 551
« Reply #8 on: Jan 03, 2011, 10:37:03 PM »
well if it is from the exuast you would or should be able to hear the leak
bamajojo9 [OP]
« Reply #9 on: Jan 04, 2011, 12:26:57 PM »
I no I have a leak at the manifold
Humboldt County Crawler
  • Turtle Points: -3
  • Male Posts: 114
  • Member since Jan '11
  • pop wheelies
« Reply #10 on: Jan 05, 2011, 09:18:43 PM »
if tail pipe is under truck ex. will come in trk and even worse if windiw is open
Build & Destroy Smoke'em If You Got'em
83yota5960
  • Male Posts: 551
« Reply #11 on: Jan 06, 2011, 08:30:00 PM »
its probably exuast then cause i have the same thing you do smoke coming in and i have a leak at the manifold to
bamajojo9 [OP]
« Reply #12 on: Jan 06, 2011, 09:20:02 PM »
Well I fixed the leak at the manifold and it still does it!! I'm scared to roll the windows up because I'm scared that if it is exhaust then it will kill me. I've never even heard of anything like this happening
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #13 on: Jan 07, 2011, 04:38:56 AM »
Is there a noticeable oil leak anywhere? Since you fixed the exhaust leak I'd look for even a small one dripping on the pipes.
OOPS
  • Male Posts: 2,561
« Reply #14 on: Jan 07, 2011, 04:43:28 PM »
Like I asked before, how are the boots on your shifters. That is what boots are designed to do, keep the outside from getting in. If they are ripped or not sealed to the floorboard outside will get into the cab.
bamajojo9 [OP]
« Reply #15 on: Jan 07, 2011, 11:11:31 PM »
Yeah good idea.. and no sir my boots are all ripped up bit it has always had an open spot around the top of the transfer case boot
Last post Oct 03, 2005, 09:55:36 PM
by Rocksurfer
Last post Apr 28, 2006, 12:55:00 PM
by 79coyotefrg
Last post Jul 27, 2008, 05:18:56 AM
by Trunkz
Last post Sep 16, 2012, 11:46:41 PM
by konarider1993
Last post Apr 07, 2017, 12:30:26 PM
by MrFatEggs
