knuckle started smoking up
Started by konarider1993, September 11, 2012, 06:04:20 PM
konarider1993
right after the knuckle rebuild  :hammerhead: bearings froze up??
Slolyfe
Pull it apart. That should tell you. Grease everything?
You'll never take me alive
mudaddict
I agree tear it back down and inspect if it was smoking more then likely something was not greased properly.
I work At
All Pro Off Road
konarider1993
Quote from: mudaddict on September 11, 2012, 10:23:13 PM
I didnt put as much grease in this knuckle because i ran out. Think i could just pump some in?
Slolyfe
Quote from: konarider1993 on September 11, 2012, 10:53:49 PM
No. Did you pack the bearings?
Slolyfe
Quote from: konarider1993 on September 11, 2012, 11:04:34 PM
Yeah
I would pull it apart and find the problem. Once something is smoking I'm pretty sure its too late.
konarider1993
darn i really dont wanna do that again
Slolyfe
Just think of it as practice for the trail. How much driving did you do on it? 2 or 4 wd? How much smoke? Jack it up and shake the tire back and forth. Is the hub hot when it smokes?
OOPS
Which bearings froze up, trunnion or wheel bearings?
Were you wheeling (in 4 WD) when it started smoking?
Did you pack the Birfields full?
Did you pack the trunnion bearings?
Did you pack the wheel bearings and set them up right?
Here is a link to the section of the FSM for setting up the whole frontend. Read it.
http://www.lukemiller.org/toys/1985_toyota_4wd_front_axle_FSM.pdf
konarider1993
Ya im pretty sure we packed everything. I was thinking it was the trunnion bearings ill jack it up and see
konarider1993
Quote from: Slolyfe on September 11, 2012, 11:22:53 PM
I did quite a bit of driving on it. It started smoking when i was on the road in 2wd at a stoplight and i could see it coming over the hood, then drove less than a mile home, and it quit smoking.
nisota
Enough smoked to see it coming over the hood? Holy crap! when you tear it down post pics of smoked knuckle please.
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
OOPS
Sounds to me that your wheel bearings were to tight or something is wrong with your brakes causing them to drag.
junya92toy
No way its the knuckle bearings, they just turn a little when you turn the wheel.
Its more then likely you over tightened the wheel bearing nuts.
Cheesemaker
Best advice in a situation like that, is to pull over and look and feel where the issue is.  IE; is the hub hot?  Rotor hot?  Caliper hot?  Upper/lower bearings hot?  That way you could diagnose the issue right away, instead of trying to guess after you get home.
jrock
You sure it the knuckle? Maybe something got onto your exhaust or burnt off your rotor?
konarider1993
I did get new calipers, pads, and didnt resurface rotors and they had oil on them but i dont know. I took it on a couple hour road trip after the knuckle rebuild and had no issues previous to this. I hope its just oil burning off rotors :therethere:
Quote from: konarider1993 on September 12, 2012, 08:54:01 AM
ok, that leads me to think somebody else did the job and you were either not there or liquored up and didnt know.
you either packed the bearings with grease or you didnt.
there is no physical way that the trunion bearings smoked at all.  it has to be the wheel bearings or you were running down the interstate with your hubs locked and burned the birfield up.
the rotors had oil on them??  where the hell did you learn to run with oil on your rotors?? :dunno:
it is very easy to get the wheel bearings too tight  and after a short drive they could very easily get so hot that they smoked that much.  in that case you need new bearings and races.
konarider1993
Quote from: 79coyotefrg on September 12, 2012, 06:04:46 PM
true true i think it was oil on rotors i didnt resurface them. I got a bigger problem now though.
