Author Topic: 22re smoking at start up, any help ??  (Read 10274 times)
dgrant71
  • Turtle Points: 3
  • Male Posts: 236
  • Member since Apr '10
« on: Jan 14, 2011, 09:25:45 PM »
I have a 22re that i just did a head gasket replacement on, brand new head, new cam, new timing kit, new oil pump, new water pump... The shop i got the new head from swapped my valves and i believe used new valve seats. When i drove the truck into the shop to swap the head gaskets it was smoking white smoke horribly. Put the new head gasket on and everything else and started it and it was still smoking the same white smoke but not as bad as before, drove it around the block and the smoke went away after about a mile and a half... It continues to smoke at start up and for the first mile and a half, it is alot of white smoke out the exhaust too. I went to the gas station and turned the truck off and turned it back on and there is no smoke. It only smoke if the truck is off for an hour or so... I have a exhaust leak between the exhaust manifold and the head at the moment but that could not because any problem like that... Does any one have any ideas to help? Thanks
yoshaleng
  • Turtle Points: 134
  • Male Posts: 1,258
  • Member since Jul '09
Re: 22re smoking at start up, any help ??
« Reply #1 on: Jan 14, 2011, 09:31:53 PM »
 :headscratch:
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #2 on: Jan 14, 2011, 09:43:24 PM »
Is the water level dropping?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
dgrant71 [OP]
  • Turtle Points: 3
  • Male Posts: 236
« Reply #3 on: Jan 14, 2011, 10:09:56 PM »
I can not tell because a hose popped off that i for got to tighten a clamp on and shot some coolant out and i had to refill the radiator. lol :/
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« Reply #4 on: Jan 14, 2011, 10:28:02 PM »
hoe many time have you driven it? it usually takes awhile for the water in the exhaust to fully burn off. and if im not mistaken there are a couple exhaust studs that go into water jackets
UA 342
STEAMFITTERS
dgrant71 [OP]
  • Turtle Points: 3
  • Male Posts: 236
« Reply #5 on: Jan 14, 2011, 10:33:49 PM »
It probably has a total of maybe 30 mintues idling and 15 minutes driving..
yoshaleng
  • Male Posts: 1,258
« Reply #6 on: Jan 15, 2011, 01:41:15 AM »
How many lbs did you torque the head bolts?
dgrant71 [OP]
  • Turtle Points: 3
  • Male Posts: 236
« Reply #7 on: Jan 15, 2011, 10:09:00 AM »
I believe the truck is using coolant, torques head at 60lbs
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Member since Aug '10
  • Get Some
« Reply #8 on: Jan 15, 2011, 10:37:20 AM »
Some times oil leaks down the valve seals, idk if you replaced these
This will cause smoke for a few minutes in the morning start up
How did the block look when you installed the head, was it good
Was it rusty , was it decked or cleaned up w a scuff pad?
And were your old valves cut after the new seats were installed
Did they pressure check?   Was the head decked
I'll try to help you !
dgrant71 [OP]
  • Turtle Points: 3
  • Male Posts: 236
« Reply #9 on: Jan 15, 2011, 11:16:01 AM »
The head is brand spanking new, the shop I bought the head from swapped the valves and put new seals in the valves.. The block looked fine, no rust, I cleaned it well with a razor blade.. I am not sure if it's burning water or not will be able to check tomorrow because I have to drive truck about an hour.. Thanks for the help so far guys it's much appreciated!! Keep the thoughts coming :)
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Get Some
« Reply #10 on: Jan 15, 2011, 11:23:59 AM »
New valve seats and old valves ? Or new valve seats and fresh cut valves
I only ask because the oil drops on to the pistons
What does it sound like when it's cranking
Is it a steady stroke or does the strokes get faster then slower!!
dgrant71 [OP]
  • Turtle Points: 3
  • Male Posts: 236
« Reply #11 on: Jan 15, 2011, 12:58:41 PM »
New valve seats and old valves is correct.. It starts after about 1 second of cranking.. The smoke doesn't come usually until 30 seconds to a minute after the truck is started
Steve_925
  • Male Posts: 1,876
« Reply #12 on: Jan 15, 2011, 02:00:08 PM »
he's saying it white smoke, so its not oil.
UA 342
STEAMFITTERS
93REDCRAWLER
  • Turtle Points: 110
  • Male Posts: 563
  • Member since Nov '10
  • You see it we wheel it
« Reply #13 on: Jan 17, 2011, 05:40:56 PM »
Dos your oil have antifreese in it? :headscratch:
How long have you had the truck?
It might just be that its cold in the mornings all vehicals smoke when its cold but it goes away when the motor has heated up.
dgrant71 [OP]
  • Turtle Points: 3
  • Male Posts: 236
« Reply #14 on: Jan 17, 2011, 10:46:22 PM »
THE TRUCK PASSED SMOG TODAY!!!! lol... The truck doesn't have water in the oil and the coolant doesnt seem to be dropping at all... Even if i turn the truck off for an hour it still smokes for the first few minutes of start up.. oh well i can live with it if it will still pass smog.. If any one has any ideas let me know and thank you to every one that has posted and tryed to help, thanks so much
Tofudude
  • Turtle Points: -31
  • Member since Jun '10
« Reply #15 on: Jan 18, 2011, 12:16:24 AM »
its just moisture that got caught in the night....mine use to do that in the summer...during winter it just spits out water
dgrant71 [OP]
  • Turtle Points: 3
  • Male Posts: 236
« Reply #16 on: Jan 18, 2011, 08:30:54 PM »
ya its got to be just moisture because my coolant level hasn't dropped at all..
Last post Feb 22, 2003, 04:07:53 AM
by BigMike
22RE won't start
Last post Sep 27, 2005, 06:36:54 AM
by RHG
Last post Apr 28, 2006, 12:55:00 PM
by 79coyotefrg
Last post Aug 19, 2012, 05:18:51 PM
by Royota
Last post May 31, 2020, 11:14:15 AM
by Gnarly4X
