Duffil's 84 Xtra Cab is still bringing the suck
Started by Duffil, March 26, 2006, 07:25:29 PM
milla85
How does the steering work? I thought you had to do a ifs box and histeer? I want to lift my truck like 5 ish but am a little confused on what to do with the steering and all the doos and donts.
Duffil
Quote from: milla85 on August 01, 2006, 10:20:07 PM
You don't have to, but it helps if you do.  With 5, you could probably get away with just the drop draglink, but flipping the ball makes a big difference, and lets you flip your front ubolts.
There's a pic of the ball flipped on the steering arm above. Reply # 44.  I'll try to take a pic of my steering setup later today.
Oh that's the best idea I've ever heard, go jump it not only will it soften your springs but it will give you this cool look on the fronts too.
They will loosen up over a few runs, just run it through every technical section you can find with something heavy in the rear.
Duffil
dont worry, I'm not gonna jump this pile.
MiniSimp
Duffil
Quote from: MiniSimp on August 02, 2006, 03:19:03 PM
Weight!!!
yeah, some would help on rear compression and keep the ass end down, but those things are maxxed.  On extension, anyway.  Look at the last pic as well, there's about 1" between the tire and the bumpstop.
Duffil
Quote from: Duffil on August 02, 2006, 10:21:40 AM
As promised:
Duffil
Buy/install front shocks
Measure for rear shocks
Modify/Weld on rear shock mounts
Buy/install rear shocks
Spring/shackle bushings
Front U-bolt flip
Cut rear U-bolts down
Modify/install bumpstops
Service front axle
New tires
milla85
Cool! do you have power steering? How much was the extended steering?
Duffil
Yeah, I do have power steering.  The drop link was like $76.99 at 4Wheel Parts.
Ramrod
moving your rear shackle mount in the back forward looks like it would get you quite a bit more droop judging by the fact that it is totally streched
Duffil
Quote from: TEAM RAMROD on August 02, 2006, 05:21:49 PM
hehe, yeah, it is.  If it comes to that, then, well, OK.  If these rears don't settle as much as I want, I'll prolly do that to fix my shackle angle.
Duffil
Got some new-to-me meats today.  Wheels also.
trekker
The truck looks good.How did you flip your ball on the j arm? I tried with hetat and a 20 ton press with no luck. So whats needed to get this done :beerchug:
I need a running 22r
Duffil
You have to grind the backside of it off.  It's like a rivet, and the backside is mushroomed over.  I took and ground down till it was flush, then pressed it out.  Once it's out, just flip it and weld it.
this first pic, you can just see the outline of the stud around the dark circle.
trekker
thanks for the pictures it helped out alot :beerchug:
MiniSimp
I think I've got one of those 2 piece drivelines in Toulumne if you need it. :thumbs:
Duffil
Quote from: MiniSimp on August 14, 2006, 09:45:05 PM
Nah, the driveline is OK, I just had bad angle. Thanks though. :beer:  What I really need is an MC-07, if you got one laying around. :hammerhead:
boggerunner
i see lots of slime on the gas tank, yummy
thestoic22
I had the same problem.  Read this post that I did about a month ago.  This solution really has worked well for me.
I just wanted to give thanks for Steve at South Bay Driveline for helping me solve a irritating problem that I was having. After lifting my '84 Extended Cab I was experiencing some "spine tingling" vibrations coming from underneath the truck. After climbing under the truck, I found that the center support bearing was completely worn out and the rear half of the driveshaft's pinion angle sucked. Once I discovered this, I weighed the options and found that I could either replace the center support bearing and have the same thing happen down the road, or I could cut it all out and replace it with a one piece shaft. After doing some looking on the net, I stumbled across this article and it grabbed my attention (http://www.4x4wire.com/toyota/tech/driveshaft/).
After reading the entire article a couple of things stuck out. This shaft was, in essence, a chevy shaft built to fit onto our Toyota trucks. This shaft was completely ready to go and outfitted with Dana/Spicer u-joints which means they are strong, as well as easy and cheap to replace if needed. I was sold, so I contacted Steve and all he required was the flange-to-flange measurements in order to get the shaft built. I provided him with these numbers and he custom built and shipped the shaft the same day. When I recieved the shaft, it was noticably lighter and beefier, so I put it in and haven't looked back.
I just thought I would give Steve some "props" since he treated me really well and the price was more than reasonable. That's just my two cents.
And......That's it.....
Duffil
Yeah, I read that like a week or so ago.  I'm gonna keep the two piece in it until I go duals.  I don't want to spend money twice when there is no reason to, plus I have a shaft that is the correct length for an Xtra Cab running duals.
Quote from: boggerunner on August 15, 2006, 12:01:35 PM
Yeah, grease tends to fly off the ujoints when you overgrease em. :haha:
boggerunner
Your supposed to grease them? :headscratch:
boggerunner
so what is next for the truck? bumpers sliders? exo cage
Duffil
Quote from: boggerunner on August 15, 2006, 03:38:51 PM
I really want to bob the bed, but I'm a girl thingy when it comes to cutting up something that is in good condition.  So probably sliders :greengrin:, and as soon as Meanokie [khmm, paging shawn, aisle1] gives me my rear third back, I'll be dropping in 4.88s.
snowshoebrue
is it going to be ready for mcr5.  you got like 26 days
Duffil
aarrgh!! I can't make it, man.  No locker, poor flex...don't ask me that question, it upsets me! :gap:
snowshoebrue
you can ride with me.  my brother flaked on me and i now have an empty passenger seat
Duffil
 :eyebrow:
MiniSimp
Duffil
 :wink2:
