0 Members and 14 Guests are viewing this topic.
no new pics?
nice, you need a sr5 cluster? its ugly without a tach
lets see what was it about a page ago about MY welding
I said you were great at welding. Can't be that hard to remember.
so, in the interest of doing it right the first time, I oughta go for some new gears, huh?
wow Duffil, that sucks about the welded rearend. future reference if your welding a rearend you want to glob as much weld on those teeth and plate as possible so there's absolutely no way it could ever move and/or break loose.
In your second to last picture it looks like your dif is bleeding from the cut you made The work looks good on the rear axle. Keep the pictures comming. What thickness plate are you going to use the plate it with ?
i got some 1/4" plate, but you have to do mine too
the tacoma housing. i do have some plate if you need it though. i have a couple 18x24 pieces of 1/4. along the outside they have 4 holes on each side. they were used to hold bolt pattern for steel collums during a pour.
ive got a bunch of 1/4 a572 plate you guys can have, i gotta come by napa to get a fresh tank of shielding gas anyhow...817-6651paul
Started by tdawg Parts Wanted
Started by lilbuddy Rig Gallery
Started by DTB « 1 2 3 4 5 » Chit Chat Camp
Started by BadnewsBob Project Research and Build-Ups
Started by 83Camo Newbie Questions
