0 Members and 20 Guests are viewing this topic.
Cage is almost done, Should I make the rear hoop behind the cab a double tube?? I don't think I need it for strength and it would only add weight and make it hard to take off the cage. I have the cage on mounting plates and plan on using a slip tube between the cab and bed so the bed will stay on and I can take off the cage. Anyone think I should add anymore to the front bumper???
That thing is SWEET! If you are looking for easy, combine the 22 block and the 20r head, get some new pistons and such and run propane...no new wiring harness needed, no fancy computers...4cyl gas mileage...runs upside-down...
Started by BIG BALLS New Member Check-In!
Started by zeros215 « 1 2 3 » Project Research and Build-Ups
Started by FrostTaco Project Research and Build-Ups
Started by locktup Project Research and Build-Ups
Started by Aus_Mallcrwlr Project Research and Build-Ups
