0 Members and 21 Guests are viewing this topic.
im so stoked that mine is ready to go mines a few tiny things. might as well:THINGS TO GET DONE:-some sort of skid plate.-lift up the rear DL a bit-lengthen front i believe.-rebuild power steering pump.
flex your junk out before u get a new shaft
ya your set pretty much maybe you should find some tiedowns now
im running a 2" BL. i know a lot of people say it sucks or whatever but as far as im concerned i weighed out the PROS and CONS and its more beneficial to run it then take it off. when you do a 3.4 swap you need a 2" body lift or hood mods are required. i plan to do that one day so that was a +. i got a marlin clocked adapter and was able to flat belly it. ya it was easy just put a floor jack and a wood block underneath and raised it till the desired height. no floor mods.
