Gnarly4X's 22RE Rebuild
Started by Gnarly4X, July 01, 2016, 07:07:57 PM
0 Members and 17 Guests are viewing this topic.
H8PVMNT
My extra weight, wind resistance and tire keep me from breaking into 20 mpg I think.
I think guys are doing a little better mpg with the 261C.
– Steve McQueen
Gnarly4X
#301
Quote from: H8PVMNT on August 29, 2016, 09:27:59 AM
I am VERY curious how this cam and engine performs, and I will put it on the dyno at my local speed shop, and I will record my gas mileage.  We have wind here quite often and I drive from about 1,000 elevation to my home at about 1400 feet elevation, and I can feel the drag on the slow up hill climb for about 5 miles. If I'm bucking a headwind, I had to shift into 4th gear!  :shake_head:  ... which you have pointed out several times... bugs the crap out of me.
As I remember this truck is 3250 with a full tank of fuel and me sitting in it.... I'm 195 lbs.
Gnarls.
H8PVMNT
Quote from: Gnarly4X on August 28, 2016, 10:12:11 AM
Hi helipilot77,
Yeah.. I agree we can get a little crazy with the subject of tweaking more power out of 22.  I've read thousands of posts over the years on the subject.  I've done engine swaps in my past and they were a lot of work and required fabricating adapter parts.  If I were going to get real serious about swapping an engine in this truck, I would become a sinner and build a 1963 Buick 215 aluminum block V-8 - IF I could get it to pass emissions. :shake_head:
For this rebuild I think the machining of the block and head at the machine shop, it probably would not cost much more to bore it to .060" over, deck the head a few thousandths, and buy an adjustable timing gear.
I DO think the gain torque would be worth it.... but it's all speculation right now.
It's all fun.
Gnarls.
I had that 215 in a hand-me down 1980 Toyota with cat sized rust holes in it.  It was a pretty cool engine, I have to say.  The carb didn't like angles at all but it got 16-17 mpg highway and was not lacking for power at all.  I ran it with stock gears and 33s.
– Steve McQueen
helipilot77
What is the ballpark cost for a basic Dyno run? No tuning just to see what power your putting down.
Mudder
I averaged 17-18 with my new engine on 87 octane. I did have the A/C on as well, although my truck does weigh in close to 4500  :headshake:
OTO Phil
Quote from: helipilot77 on August 29, 2016, 03:59:04 PM
Any shop near me wants about $90 to just over $120 for a few dyno runs
Sent from my LG-H830 using Tapatalk
Gnarly4X
Quote from: H8PVMNT on August 29, 2016, 03:56:58 PM
My nephew who is Mopar expert has a friend who has a good number of these 215 aluminum block engines and would build one for me for my truck.  I have always wanted to do a swap in my trucks.
Back in my sand duning days, my good friend and ex-drag racer Steve Korney, raced a sand rail with a 215 with two bottles on it, one nitrous and one propane... guess what the propane was for??
It was EXTREMELY quick on the sand!
Gnarls.
Gnarly4X
#307
Hey helipilot77,
My local speed shop charges $110 for about 1 hour.  I can get about 3 to 4 pulls.
The operator has been operating this dyno and software for about 10 years.
This is one of the most accurate chassis dynos on the market.  I've heard comments that the DynoJet  chassis dynos give "happy" numbers?
Here's their chassis dyno:   http://mustangdyne.com/md-600-series/
Gnarls.
Quote from: Gnarly4X on August 29, 2016, 09:31:52 AM
Gnarls.
:yikes: damn that thing is LIGHT.  but you probably don't have the armor my 4500 lb truck does
emsvitil
Gnarls.
It's heavier than that...........
An 86 XtraCab has a 5080 GVW and a 1400 payload   (as I look at my 86 brochure)
That leaves an empty weight of 3680 lbs  without anybody or anything in it  (but full tank)
Gas is 6.2lbs / gallon * 19.3 gallons = 119.7 lbs
or 3560.3 lbs as you run out of gas  (not including you)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Gnarly4X
#310
Quote from: emsvitil on August 29, 2016, 05:52:14 PM
I didn't mean to shave off some weight....
Well.. it's been almost ten years since I weighed it.  But, yes as I recollect I was surprised that it weighed about 300 lbs. more than my 1985 shortbed.  So, I can't find my little log book, but yes, I think it was close to 3500 + something?
I think my 1985 was 3195 with me not sitting in it and a full tank of fuel, 33" tires mounted on aluminum wheels, with 103" wheelbase.
This 1986 has 112" wheelbase and has a 17 gallon gas tank.
Gnarls.
H8PVMNT
Quote from: Gnarly4X on August 29, 2016, 04:41:33 PM
Gnarls.
There was one for sale for $500 over here last year.  I looked into it but the 215 is not an economical engine to rebuild.
– Steve McQueen
Gnarly4X
Quote from: H8PVMNT on August 30, 2016, 07:37:59 AM
Hey H8PVMNT,
I haven't looked into a 215 swap for over 10 years, so I'd have to check it out again to see if I could get one to pass emissions, then how feasible to building one, including whether or not any adapters are available or I'd have to fab them?
A 4.7 V-8, like the one in my Tundra may be a smarter swap???  :dunno:
Gnarls.
H8PVMNT
The one I had was on a 1980 style 4 speed.  It pretty much looked like it nearly bolted up.  I remember a couple extra holes drilled in the bell housing.  I never did a clutch in it but it supposedly had a mix of Toyota and Buick clutch components.
Guy who had it was an old school machinist so who knows.  I sold the truck real cheap to a buddy.
– Steve McQueen
Gnarly4X
Speaking of swaps... has anybody done a Toyota 4.7 V-8 swap in an early Toyota pickup or 4Runner?  :dunno:
Gnarls. :spin:
OTO Phil
This guy did a 2uz swap: http://www.instagram.com/dinigram/
OTO Phil
Gnarly4X
redneckcustoms13
Quote from: Gnarly4X on July 16, 2016, 08:23:41 AM
Hi redneckcustoms13,
Sorry I hven't been back on this thread in a while. I have ran numerous header options on 20r and 22r engines. I ran the dougy and lce both on the same engine in the the same truck. Could be that it was not a stock truck on 29" tires, but I felt zero difference between the two. Either is an upgrade over factory cracked manifold. Both would be an excellent choice in my opinion.
I re-read your post.  Are you saying that you could NOT tell any difference between the LCE and DT, or that you could not tell any difference between the LCE & DT and the stock exhaust manifold?
Thanks,
Gnarls. :spin:
01 double cab hunting truck
06 tacoma street truck
Gnarly4X
#319
Quote from: redneckcustoms13 on August 30, 2016, 07:26:12 PM
Hey redneckcustoms1,
You posted what appears to be a quote that I posted.  I didn't post that.  It looks like you got your reply mixed up with my posted questions.   But I think I see what your reply is..
You couldn't tell the difference between the LCE 4-in-1 and the Doug Thorley, right?  And... your experience may be my experience.  I could test each one and NOT feel any difference... but I sure would like to test them on an engine dyno.
Speaking of experiences... obviously each of us has a different level of awareness, experience and driving style.  I have driven trucks that the owner thinks is a real modified cats-a$$ machine.  But, compared to my more stock 22R, my truck would kick his truck's butt.  I have also had a guy ride in my '85 and when I tac'd it to 5,000 RPM in 1st, 2nd, and 3rd gears, the guy says I'm going to blow up my engine! :willynilly:   ...and says he never tacs his engine over 4,000 RPM!!  :smack:
Gnarls.
Quote from: Gnarly4X on August 30, 2016, 09:10:49 PM
Gnarls.
:smack:
Gnarly4X
#321
Quote from: 79coyotefrg on September 01, 2016, 03:45:26 AM
:smack:
I made a 1/2 dozen trips to the Glamis sand dunes with both my first 1986 22RE longbed automatic and my 1985 22R shortbed 5-speed.  I REDLINED those engines a-l-l daaaay loooonng!!  Before each trip, I went over the entire truck with a fine tooth comb and tuned the engines to within a gnat's a$$ of right-on!  Fresh oil and air filter.  I added a 1/2 can of STP Oil Treatment to crankcase.  At the dunes my tires were air'd down to 4 PSI.  I removed every pound I could from the truck, including tailgate and spare tire.  In my 85 I installed a 5-point harness, but in the dunes I could only use the lap belt because the bouncing in the seat would beat the crap out of my shoulders.
Geeezz.. .those were fun wheel'n days!!!  :dancing:
Gnarls.  :spin:
Gnarly4X
Question:
I'm about to clean the nasty carbon'd up throttle body.
What have you found that works the best?
I bought a couple brushes and will use some kind? of solvent.
It was 102d F in the garage today, so I didn't get to work on my engine that much!!  :crazy:
Thanks,
Gnarls. :inthedark:
emsvitil
Oil Eater from Costco and an old tooth brush.
Mix 50/50 with water.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
H8PVMNT
Pinesol works wonders on carbs.
– Steve McQueen
Gnarly4X
Quote from: H8PVMNT on September 02, 2016, 07:25:17 AM
Thank you for the input...
I did some research on the net on what products can clean an alloy throttle body and I got 2 dozen different opinions and experiences on what product has been used and what happened.
I was thinking about soaking it in a solution like overnight to help reduce the work to clean it out, but I'm not sure WHAT solution would attack the aluminum in the TB.  From the look of it, I'd guess that it is 30 years old and never been cleaned.
Gnarls.
Gnarly4X
UPDATE:  9-9-2016
The rebuild and re-install is going slower than I had anticipated.  I've spent more time cleaning parts and ordering parts than I predicted.  As I mentioned, I already went over budget by about 25% $$$$$.  :think:
I'm working a little OT to help fill in the dings in my checking account, I'm on rice & beans  :yumyum:, clipping coupons :gap:, and extended my hair cuts to every 6 weeks! :therethere:  I have the AC temp set at 81d F trying to save a little more on the outrageous summertime electric bills here in sunny AZ.  :idea:
HOT TIP:  If I could start over, I would have taken way more time to carefully examine EVERY part and make a list of all the parts I would need to replace or rebuild, including gaskets and rubber.  And, I would have added a "contingency fund" to my projected costs.  :smack:
Cleaning parts that look like they have not been cleaned in 30 years is worse than hard labor!  :thumbdown: My garage gets up to 100d F by about 1pm, so it really kicks my ol' butt.  :crazy:  Maybe I should have killed that little bug before it crawled up my butt about rebuilding my engine in middle of summer! :yikes:
I'm not complaining... just sharing some personal thoughts, experience, adding some humor to my project so I don't take life too seriously. :ha_ha: :D
Gnarls. :smokin:
Gnarly4X
UPDATE 9-12-16:
Yesterday was an attack in my engine rebuild project!  :yikes:
My house AC compressor on the heat pump apparently died.  My AC guy will let me know today, but it's estimated between $4,000 and $6,000.  I just had to put a set of tires on TWO vehicles in last week!  :yikes:
Have you priced the cost of rubber lately!!!  :smack:
So the ding in my checking account is going to like IED!!  :rivers:
At 101 degrees F yesterday, needless to say I didn't get much sleep last night!
I guess the old saying "things happen in 3's" worked on me!!
Gnarls. :sad2:
Gnarly4X
Gee, it's only predicted to be 98d F today.... and NO A/C!!  :willynilly: :crazy:
Would this be a 4x4 redneck air conditioning system?  :talkingn:
Those are frozen bottles.
Gnarls. :shudder:
Mudder
Ouch, now that's no fun at all. Have you looked into getting one of those window A/C units? Could probably pick one up for cheap on craigslist.
