Author Topic: 97 Taco 350 v8 Conversion Questions  (Read 2121 times)
81RedRocket
  • Male Posts: 27
  • Member since May '07
« on: Aug 03, 2009, 01:55:52 PM »
So my roommate is getting tired of her 97 v6 A/T taco .. and is wanting to trade me straight across for a Dodge of mine. I have a few questions on the complexity of swapping in a 383 stroker or base 350 carberated motor into the taco. It would be a long term project so time invested isn't a huge issue but my plan would be to straight axle, swap out tranny/axles/etc. and use it as a show truck is the body is in perfect condition. Has anyone out there done this before and possibly has a write up as to the complexity of dealing with the electronic side of it? I've swapped 22re's and Cummins motors but never a fuel injected truck to a carbed' any help or sites to look at would be appreciated. Thanks!
81' 4x4 short box 32/36 weber, 3" procomp, 33" bgf all-terrain, magnaflow, aussie lockers
02' Cummins quad cab, edge w/ attitude, 5" straight pipe, FASS system, 5.5" lift w/ 35" toyo MT's
93' Cummins single cab, 80hp injectors, 50hp fuel pin, aFe intake, 5" straight stacks, 8" lift w/ 37" toyo MT's,
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
Re: 97 Taco 350 v8 Conversion Questions
« Reply #1 on: Aug 12, 2009, 04:14:10 PM »
if you in ca you can't swap efi for a motor with a carb it wount pass smog just have him swap in a 5.7 vette motor
Dooner
  • Turtle Points: 217
  • Male Posts: 769
  • Member since Feb '05
  • Invest in precious metal
« Reply #2 on: Oct 05, 2009, 09:16:53 AM »
Sounds like you are set on running a carb, most folks are going the other way. It would be cool to slide in an LS1 with an overdrive auto trans along with a stretched out wheel base on one tons. Set it nice and low all 4 linked up on 42's. It might be kinda hard keepin it show truck ready when you start hitting the hammers!
« Last Edit: Oct 05, 2009, 09:31:47 AM by Dooner »
"Project Land Cruzah" In Land Cruiser Section
71 FJ40 327/465/ 4.7 Mini T/c, Trussed, Armored Mini Axles w/ High Cross Over, Aussie Lockers & 30 spline Longs.  p/s 35's, SOA, , .  86 Burb D-60 14 bolt 350/400/205 37's.  02 F350 Tow Barge, Toyo 38's, Banks 5" Wicked wheel turbo, Edge Juice w/ Attitude, Blah Blah Blah
854RUN
  • Turtle Points: 30
  • Male Posts: 890
  • Member since Mar '06
  • 4WHEEL 4EVER
« Reply #3 on: Oct 05, 2009, 10:43:22 PM »
dose it have to pass smog test?? 97= obdII and a carb setup= not obdII = no pass smog. why a carbed motor?
-JOSH-
Last post Aug 03, 2004, 12:21:40 AM
by WHITE_TRASH
Last post Apr 29, 2005, 09:11:58 PM
by awhotrods
Last post Sep 25, 2005, 11:33:09 PM
by kneedownnate
Last post Jun 18, 2008, 06:24:37 PM
by sir flops alot
Last post Mar 25, 2010, 09:51:37 PM
by dntsdad
