Author Topic: Motor Mount Problems  (Read 2854 times)
JoeShmo65
  • Male Posts: 291
  • Member since Apr '07
  • Big Red
« on: Sep 02, 2008, 02:18:08 PM »
Im having some motor mount problems i have a 94 yota pickup i bought bout a month ago, it was origonaly a 6 cylinder engine but somebody before me switched it to a 4 cylinder and it looks like they didn put dif motor mounts on the engine because they dont match up wit the frame mounts wat im wondering is if the frame for a 6 cylinder engine is dif from a 4 cylinder engine?? and if not can i just go buy some new motor mounts that are ment for a 4 cylinder engine?? any help would be appriciated  :bowdown:
"what was that daddy?"..."Don't worry honey, just a jeep i used for traction, now go back to sleep."
ROFL
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: Motor Mount Problems
« Reply #1 on: Sep 02, 2008, 02:31:33 PM »
So what, is the motor just resting on the mounts?  Why do you ask?  There isn't a big difference though, I put a 22r rockstomper mount on my 3.0, bolted up just fine.
              -Ronald Reagan
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #2 on: Sep 02, 2008, 02:40:13 PM »
the mounts are in a different spot..... they mounts themselves will work, but the actually little horns on the frame where they mount are not in the same spot
JoeShmo65 [OP]
  • Male Posts: 291
  • Big Red
« Reply #3 on: Sep 02, 2008, 02:51:12 PM »
the flat piece thats on the rubber is half way on the frame mount and the idiot welded it on so is a 4 cylinder engine mount different in langth than a 6 cylinder engine mount??
ROFL
  • Male Posts: 8,707
« Reply #4 on: Sep 02, 2008, 02:54:32 PM »
the issue isnt the mount itself, it is what the mount sits on... it is located in different spots on the engine.... so the frame horns arent in the same spot as they are for the other engine.....
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #5 on: Sep 02, 2008, 04:29:51 PM »
halfway vertically, or moved forward or back?  Got pics?
              -Ronald Reagan
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #6 on: Sep 02, 2008, 05:35:17 PM »
the 22R mounts are almost perfect center of the block front to back
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #7 on: Sep 03, 2008, 12:26:50 AM »
4cyl motor mounts are further towards the front of the truck by about an inch.
Quote
JoeShmo65 [OP]
  • Male Posts: 291
  • Big Red
« Reply #8 on: Sep 03, 2008, 06:59:52 PM »
thnx toy that helps also are the 4cyl mounts longer than 6cyl mounts??
ROFL
kauai_fab
  • Male Posts: 45
  • Member since Aug '08
« Reply #9 on: Sep 12, 2008, 07:45:18 PM »
what you could do is trash toyota engine and go v8
  • Male Posts: 8,707
« Reply #10 on: Sep 12, 2008, 07:53:33 PM »
blackdog is running aftermarket 4cyl mounts on a v6 i believe....
it isnt the mounts are longer, it is that what the mount attaches to on the frame is in a different spot
Last post Aug 16, 2004, 05:05:00 PM
by SWAMPER
Last post May 16, 2006, 12:07:51 PM
by Cheesemaker
Last post Jul 22, 2006, 10:00:08 AM
by MR_DIY
Last post Jan 11, 2007, 09:49:42 PM
by boggerunner
Last post Feb 03, 2012, 11:06:37 PM
by SFD4x4
