Author Topic: Motor Mount Issues  (Read 3878 times)
punkrock crawler
  • Male Posts: 117
  • Member since Dec '06
Motor Mount Issues
« on: Jan 07, 2007, 07:32:52 PM »
Just broke my drivers side motor mount on first trip out with the new crawl gears in my case. I went to the local o'reillys and picked up a motor mount. Now I first searched for the part on the net and it showed it to be LS and RS specific. When I went to the store the counter guy tells me that the mount is not side specific. So I go to put the thing in and the holes dont line up to the frame side. Has anyone run across this lately? Are the motor mounts side specific?
Dying to live and living to die!
1983 Hilux
3" suspension lift, Marlin L52 transmission, Marlin ultimatecase 4.70, Marlin 1200 Clutch, 30" tires, Spraypaint exterior, Webber carb.
2006 Tacoma 4x4
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Motor Mount Issues
« Reply #1 on: Jan 07, 2007, 07:37:00 PM »
as far as i know they ARE NOT  side specific
you better  put a chain on that thing  or you'll keep breaking mounts
punkrock crawler [OP]
  • Male Posts: 117
« Reply #2 on: Jan 07, 2007, 07:45:05 PM »
They must have the wrong part number in the computer or the manufacture is punching the holes wrong because its not working. Thanks for the info.
1983 Hilux
2006 Tacoma 4x4
insane04
  • Turtle Points: -64
  • Male Posts: 390
  • Member since Feb '06
« Reply #3 on: Jan 08, 2007, 02:47:38 PM »
i know you have to open up the holes to run 79-83 mounts on a 84-88 frame
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #4 on: Jan 08, 2007, 07:55:51 PM »
Every mount i have ever purchased i had to open up the holes for them to fit.  chain them so they don't break again.
_HOIST_
  • Turtle Points: 300
  • Member since Jan '06
  • Slow is smooth, smooth is fast
« Reply #5 on: Jan 08, 2007, 10:25:52 PM »
Buy a set of LC Engineering semi-solid motor mounts and never worry about them again. Every yoter I've ever build the motor mounts were broken and thats always my first upgrade. I've been running them for years and haven't even wore down the polyurethane bushing at all. You'll feel a little more vibration in the frame from the motor but way worth it...
croberts
  • Member since Apr '06
« Reply #6 on: Jan 09, 2007, 05:49:58 AM »
don't waste your money on stock mounts there just going to break again. I got a set from rockstomp.com? rockstomper.com its one of those. there bullet proof. They do have some vibration though but well worth it . :hammerhead:
yotadork83
  • Turtle Points: 18
  • Male Posts: 705
  • Member since Mar '06
  • ninja turtules rule!!
« Reply #7 on: Jan 09, 2007, 07:37:16 AM »
weld in a chain is as good as the solid mounts as long as you make sure you dont have to much slack in the chain, save you $80 if you dont have it.
yotas 4 life homie!
  • Male Posts: 117
« Reply #8 on: Jan 09, 2007, 01:17:23 PM »
Thanks, good to know I wasnt the only one getting mounts that the bolt holes dont line up. Thanks for the info guys.
1983 Hilux
2006 Tacoma 4x4
  • Male Posts: 117
« Reply #9 on: Jan 11, 2007, 07:08:36 AM »
FYI.....Just picked up a motor mount from Auto Zone that matched up perfectly. If you go to O'reilly's the motor mount they offer will not bolt up and requires modification to fit. It also cost 20 dollars more than the Auto Zone mount. I will post the part numbers up later today.
1983 Hilux
2006 Tacoma 4x4
mjos
« Reply #10 on: Jan 11, 2007, 07:28:24 AM »
I used a set from Autozone also.  They work great.  Im going to chain mine though too.
05' 4R V8 Sport, Toytec Ultimate 3", 33's, Sliders
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #11 on: Jan 11, 2007, 07:45:59 AM »
Anyone got a pic of the chain setup? i just replaced the drivers side mount last night
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Last Edit: Jan 11, 2007, 08:03:12 AM by jimbo74 »
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #13 on: Jan 11, 2007, 08:35:17 AM »
sorry to be the one to say it, but it looks kinda cheesey, and my truck has enough rattles already.  Im just going to build some motor mounts with some 3rd gen 4runner  4 link bushings
  • Male Posts: 117
« Reply #14 on: Jan 11, 2007, 09:16:32 PM »
Ok Crawlers here's the part numbers for the motor mounts. The good one that fits without modificaion is from auto zone pt#713791. The o'riellys mount will require grinding and cost 20 bucks more pt#8162 and the line is ANR. Hope this helps.
1983 Hilux
2006 Tacoma 4x4
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #15 on: Jan 11, 2007, 09:32:03 PM »
you can also drill them out and run a bolt thru them.
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #16 on: Jan 11, 2007, 09:49:42 PM »
so no cheasy chain for me, im going to turn these into motor mounts
Last post Aug 16, 2004, 05:05:00 PM
by SWAMPER
Last post Jul 22, 2006, 10:00:08 AM
by MR_DIY
Last post Aug 16, 2007, 09:04:55 PM
by lilbuddy
Last post Dec 09, 2009, 06:57:06 PM
by yotaneck13
Last post Feb 03, 2012, 11:06:37 PM
by SFD4x4
