Maybe our ECUs are shot?
Mine starts so hard but runs like a champ...
Have you adjusted your timing after the new TPS?
So ive realized something...My charge light is really really dim sometimes (with motor off and key in on position). other times its really birght but lately its been dim
Wierd, my charge light is on all the time since the problem started...i just figured it was because i've been beating the hell out of my battery with all the starting and stoping during the testing...
Might even be a worn out ignition switch issue....
Timing is supposed to advance way high when throttle is added. For the dim charge light issue, check the ground wires and main power wires on you're engine and alternator, and make sure you have good contacts (no rust or paint on them). If the ECM is getting low voltage for some reason when running, it will set weird codes. After all that is confirmed good, try setting the TPS with your timing light after you clean the crap out of the inside of your throttle body. Jump the t1 to e1 connector on the diagnosis connector in the engine bay with the engine running and A/C off and the idle should drop. Next check the timing with a timing light. It should be at 10 degrees or so. Loosen the screws on the tps and gently tap it until the timing changes (note: big change). When it changes, gently tap it back the other way until it goes back to base timing and tighten screws and you're set. I know it doesn't tell you to do it this way in the FSM, but smog guys have been doing this successfully for years without problems, and it's easier than the stupid fealer gauges. If this doesn't fix the tps code, you have some serious wirring issues. P.S. If you need another tps, I might have what you are looking for for free....[/quoteThe TPS is set perfect and timing is set perfect also (with the AC off and the wires jumped) I just dont know why im getting #11 though....
Started by Benge Scott Engine
Started by punkrock crawler Toyota Pickup/4Runner Tech 1979-95
Started by 1982toy Engine
Started by yotaneck13 Engine
Started by warrbear Engine
