Author Topic: *Odd Noise When Clutch is Depressed* HELP PLEASE  (Read 4917 times)
87_Yotaman
  • Turtle Points: -134
  • Male Posts: 119
  • Member since Apr '05
  • "This is MY YOTA!"
« on: Apr 16, 2006, 04:39:40 AM »
My 87 toyota pickup is making an odd knocking noise whenever I mash the clutch in but it stops when I let it out.  There is always something that has got my truck  :sick: .  Does anyone know what it might be? if so any help would be appreciated.
Thanks,
Alex
______________________________________
[     ]_____________|____TOYOTA___[     ]
[___]_____________|_______________[____]
OR
  __                __
(__) l l l l l l l l (__)
N.S.Runner
  • Male Posts: 37
  • Member since Apr '06
Could be the throw out bearing getting bad. First check to see if the bolts on the bellhousing are tight.
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
Did this noise just start on it's own or did you do some work on the clutch before it started?
When you push the clutch peddle the throw out bearing pushes against the fingers on the pressure plate.
If the bearing is going bad it usually starts to make a dry grumbling sound unless it has locked up, then it will squeal.
If for some reason the throw out bearing is over extending it will push the fingers of the pressure plate into the clutch disk causing some kind of grinding noise or banging noise.
Like N.S. said check for loose bolts first, then you will have to pull it apart to see what is going on. Could even be the pilot bearing going bad.
Check the end play on the crankshaft to make sure your thrust washers are in good shape. If they are worn out or have fallen out the crank will be pushed forward causing all kinds of problems.
Good luck and let us know what you find.
87_Yotaman [OP]
  • Male Posts: 119
 :bowdown: Thanks for the help mr.dub'ya and N.S.Runner.  Im at work right now but I get off at one thus I will take a look at this problem when I arrive at the house where my truck is waiting.  I hope that this will solve my problem.
Mr.W ---> :idea:            :hammerhead: }
N.S. ----> :idea:            :think: }           <----87 Yotaman
 :beer:                         :hammerhead: }
OR
  __                __
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
lol yotaman
Sounds like a throw out bearing.
How may mile U got on that clutch?.  THe problem is most people when they do clutches  they never replace the bearing :nonono: ( can be a real pain )    So if your clutch has been done before chances  :dunno: are that bearing is way old.
87_Yotaman [OP]
  • Male Posts: 119
I don't think that it is the throwout bearing.  I just replaced the engine about 20,000 ago.  When he put the new engine in it was an automatic transmission engine thus we had to get a new clutch, throughout bearing ect.
OR
  __                __
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
if it just started it could be the clips on the TOB have come off and it is trying to spin on the fork
87_Yotaman [OP]
  • Male Posts: 119
yeah it just started yesterday and it was real quite then this morning it was extreamly loud.  I hope that it is nothing big.
OR
  __                __
Plowking
  • Turtle Points: -75
  • Male Posts: 504
  • Member since Jan '05
  • Awesome yota
    • Buy me a drink
Years ago I had a spring blow out of a clutch disc and made some really loud noises, I hope thats not the problem
2008 Dodge Diesel  (Cummins Rule)
6.7 manual quad 8 foot bed H&S delete, banks air box
93 yota 3.0 locked up...
2004 Yamaha Raptor 660R
87_Yotaman [OP]
  • Male Posts: 119
My Mechanic said that the problem was either that or the release bearing.  Either way the transmission was going to have to come off and that I was looking at around $500.  :yikes:
OR
  __                __
$500  :aaa: do ya live near me
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Save the $$ and do it yourself, its really not that hard :nope:
              -Ronald Reagan
Yota87Truck
  • Turtle Points: 2
  • Male Posts: 1,175
  • Member since Aug '06
  • Got Moab!
Sounds like I have the same problem or something in the like.  I was going on the interstate today 70 or 80 MPH and I shifted down from 5th to 4 and it made a slight metallic grinding sound.  While on the interstate I shifted a couple more times between 4th and 5th gears.  When I got off the interstate not to long after I pushed the clutch petal in and it made the same sound only much worse, but the noise only occurs when I have the clutch pushed in.   I have had a simalar problem to this before, once when one of my  motor mounts came off and a couple of times when my transmission was loose so I assumed that is what it was, but when I went to tighten the bolts they were all fine.  Any suggestions on what exactly might be my problem, sounds like im gonna have to drop my trannie.  Clutch was new 20K or so miles ago, but I don't remember what parts are new or not.  Its an 87 22R pickup 4x4.
87_Yotaman [OP]
  • Male Posts: 119
Well it sounds like the spring. That's what was wrong with mine. Wasnt that bad to replace cept for having to buy a new clutch to replace a new clutch.
OR
  __                __
:shake:  HELLO this thread was OVER a year old on the last post and originally is over 3 years old  :shake:
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
its his thread glen.
Yota87Truck
  • Turtle Points: 2
  • Male Posts: 1,175
  • Got Moab!
Oh, I know this is old but I beleive this was a pilot bearing issue....
THE ROCK
  • Male Posts: 219
  • Member since Apr '07
 :psss:did they install a pilot bearing when the truck was converted from auto to standard trans? :think:
drew303
  • Member since Jan '10
Damn I'm having a similar tranny issue, G54 i assume, 87 22r. but anyway, only 40mph over i can get the metallic grinding noise when you find that sweet spot between driving the tranny with the motor vs coasting.. you know what i mean? like theres no load on the drivetrain from DRIVE or COAST??..
and i get the noise regardless when the clutch is depressed, which is when the drivetrain is coasting.
ugh.. i have no idea what it is. 223k on the tranny tho. It's quite a horrid sound lol, im just waiting for it to blow up on the freeway
Last post Jun 07, 2006, 09:27:09 PM
by 2bigtacoma03
Last post Aug 20, 2006, 04:46:14 PM
by Jedi87
Last post Jul 03, 2008, 02:29:45 PM
by ROCKO
Last post May 30, 2009, 10:01:51 PM
by drayday55
Last post Oct 20, 2012, 10:16:08 AM
by Royota
