Diesel GOAT: The one I wish Toyota would have built
Started by helipilot77, May 20, 2015, 12:49:27 PM
dt75flh
Just read your thread.  Great job on the install.
I just purchased a 1kz-te 88 4runner. Had the same running hot issues I purchased a 3 core alum radiator from Malaysia, had to cut and re weld the lower output, and the fan shroud inserts were also in the wrong hole.  It also hit the hood.  I re drilled the mounting bracket to lower the radiator.
When I got the truck it would not go over 65 mph on flat ground without it going into the red zone...PO told me he had the same issue but it ran fine up to 65...I checked the fan clutch as I had to refill my prior land cruiser but it was fine.  Put the new radiator in and I can run up a 6% grade with ac on in 100 deg heat and the temp never goes past ½ mark now, and it will run 75 to 80 in the flats now.
Where did you source your engine FSM?
And any ideas for small parts?, I need a turbo drain gasket where it goes into the block.
luckily I did not hurt the head gasket on mine.  Did you get your head on ebay?
helipilot77
#121
Quote from: ovrarok on September 27, 2015, 03:41:37 PM
I sure do hope you and your truck make it next year, I just love a well built diesel.I wanna see this truck in person
I am hoping to get it there next year for MCR. I was glad that Zippo was kind enough to ferry me down this year. :D
Quote from: dt75flh on September 27, 2015, 04:03:19 PM
I have also been able to drive up grades without any overtemp problem now that I have the Aluminum 3 core radiator. I forget where I got the FSM but I will send you a copy.  :thumbs:
For small part some are available through Roughtrax. That is where I got my head. really top quality stuff. for everything else not available from Roughtrax go to Japan4x4.com email Dave Steadman [email protected] you will need to set up a Paypal account if you don't already have one. look up the part numbers you need on ToyoDIY.com then e-mail him requesting prices for those part numbers. all prices will be in Yen. Right now $1.00 approximately equals 120¥. Then pay for them via Paypal he will send you a request for futher funds for shipping once he has them packaged up and weighed. Here in Seattle it only takes about a week to get my parts.
helipilot77
looking at valve spring compressors... I might get this one  :dunno:
or make one out of a large C clamp.
dt75flh
I have also been able to drive up grades without any overtemp problem now that I have the Aluminum 3 core radiator. I forget where I got it but I will send you a copy.  :thumbs:
For small part some are available through Roughtrax. That is where I got my head. really top quality stuff. for everything else not available from Roughtrax go to Japan4x4.com email Dave Steadman [email protected] you will need to set up a Paypal account if you don't already have one. look up the part numbers you need on ToyoDIY.com then e-mail him requesting prices for those part numbers. all prices will be in Yen. Right now $1.00 approximately equals 120¥. Then pay for them via Paypal he will send you a requets for futher funds for sipping once he has them packaged up and weighed. Here in Seattle it only takes about a week to get my parts.
[/quote]
Thanks !  and for the PM.  I bought the FSM but it came in a 5x8 book..I was expecting a full size manual.  It helps to print out the pages I need though .
you swapping heads for a lil more power?
helipilot77
Quote from: dt75flh on September 27, 2015, 05:35:16 PM
No. I suspect I overheated it enough to crack it. It is running like a real dog due to low compression.  :smack:
(This is a personal note to myself) 4.56 gears will work nicely with 35"-37" tires.
cavey
G'Day  just some info on cooling and overheating issues with the 1KZ-TE engine here in Australia  cracked heads on this engine is a known to happen due to the position of the thermostat it mostly happens when towing up hills so there are two different heads out there, vehicles released in Australia have what is known as a " long valve head " where as imports such a Surfs  have " short valve head" the long valve heads still crack , I personally know a bloke who had a 1KZ -TE Prado and overheated the engine twice in 12 months towing a trailer up hill and cracked two heads, firstly change the thermostat to a 70 degree item so it opens sooner  make sure the cooling system is up to scratch , use the fan shroud , and fit a external oil cooler
own a 1989  LN106r diesel with a 1KZ-T 3 litre turbo diesel  bolted to a imported R151F gearbox with snorkel Rancho springs & shocks & Detroit lockers F & R & 11x 32  cooper sst ultimate dual transfer cases 130 litre fuel tank   full floating disc brake rear end
LittleSteve
Quote from: helipilot77 on September 27, 2015, 05:22:24 PM
I have a spare one you can have.
Refusing to fit in or comply.
Easy is not worth anything.
helipilot77
Quote from: LittleSteve on October 03, 2015, 03:16:21 AM
I forbid you to ship it all the way over from a foreign land. I'm just going to make one out of a C clamp.
helipilot77
#128
Got some work done on her today. Ready to rip my babies heart right out of her chest. Hopefully I'll have time next weekend.
One more order of parts and then I think I will have everything I need. Apparently Milner off-road no longer ships to the US. Fortunately littlesteve has agreed to forward it for me.  :thumbs:
helipilot77
#129
Apparently my truck is so good looking that matchbox decided to copy it for one of their trucks!
The rims look like they match even, is that Steve's truck in back ground trying to photo bomb
helipilot77
Quote from: ovrarok on October 12, 2015, 06:24:59 PM
Yes he is graciously letting me drive his baby while I fix mine. I didn't want to mention it. He might get emotional.
LittleSteve
helipilot77
Quote from: LittleSteve on October 13, 2015, 11:51:02 AM
And?
I know it's hard for you to think of someone else spending time with your baby.  :shudder:
helipilot77
#134
Thanks to zippo we got the motor pulled and the initial cleaning done yesterday.
looking good, is that pattern for bellhousing same as 22re, looks close.
helipilot77
Quote from: ovrarok on October 16, 2015, 07:37:51 AM
Starter and release are reversed.
redneckcustoms13
So its like a w59 bellhousing just not crooked?
01 double cab hunting truck
06 tacoma street truck
hey nate, do you think that motor would run off b100?
helipilot77
#139
Quote from: ovrarok on October 16, 2015, 08:56:43 AM
I run it on B100 all the time. I would eventually like to build a second fuel tank with a heat exchanger in it so I could run waste veggie oil.
Quote from: redneckcustoms13 on October 16, 2015, 08:42:00 AM
I'm not familiar with the w59 bell housing, but this is for an R-series transmission
redneckcustoms13
I did it for 3 years in my 12v. It's Alot of work. When fuel is as cheap as it is now it's not really worth messing with in my opinion.
helipilot77
Quote from: redneckcustoms13 on October 16, 2015, 09:38:21 AM
Yeah, but fuel will be expensive again as soon as the Saudis have successfully ran our national oil producers out of buisness.
redneckcustoms13
+1, it is funny when you roll up to a red light smelling like french fries. It always made me hungry.
LittleSteve
#143
Quote from: helipilot77 on October 16, 2015, 09:51:55 AM
Fuel being as expensive here as it is... no one bothers with veg oil anymore...
Quote from: helipilot77 on October 16, 2015, 09:27:04 AM
you already are...
you realize the filter heads out of the 2L UK trucks have a heating element in them? I happen to have two..... you want one?
Quote from: helipilot77 on October 16, 2015, 08:23:35 AM
Clutch slave is also ass about face (mirror opposite iirc)
helipilot77
#144
Quote from: LittleSteve on October 16, 2015, 11:50:42 AM
you already are...
No I am running B100, but not WVO.
helipilot77
I didn't know that. I always wondered because my engine fuse box has a circuit labeled fuel heater. I definitely take one!! My filter primer is kaput anyways.
LittleSteve
Quote from: helipilot77 on October 17, 2015, 08:57:02 AM
10-4
helipilot77
#147
Got the transmission all cleaned up today. Wow! Was it a mess.
helipilot77
#148
Got some engine tear down done today.
helipilot77
#149
Also made a crossmember for my RC crawler today.
That should be a nice place to weld the 4wheelunderground scale 3 and 4 link brackets to.
