Diesel GOAT: The one I wish Toyota would have built
Started by helipilot77, May 20, 2015, 12:49:27 PM
0 Members and 13 Guests are viewing this topic.
helipilot77
#60
Got the steering box housing all cleaned up.
SqWADoosh
BigBluePile
Nicely high lighted [emoji106]
Sent from my HTCONE using Tapatalk
'86 4Runner SR5 TRD 5VZ-FE
...slightly modified from OEM...
helipilot77
helipilot77
#64
The two white dots are my center punch marks for the hydro assist ports.
Aced it! Got the port dead center on the vain.
zippo
Just an idea. Take it to -6 an with caps now. So down the road you don't have to do anything but take the cap off.
If you see it, its for sale.
BigBluePile
helipilot77
#67
Progress... With what everyone wants... Pictures... Lots of them...
zippo
SqWADoosh
Your truck needs this so badly. I'm very excited that you are getting this sorted.
BigBluePile
Niiiiiiice!
helipilot77
Next step is to redo my motor mounts so that it sits about a 1/2" lower. It is rubbing on the underside of the hood right now, making a lot of racket.
zippo
Only 1/2"? I might would to a little more 3/4 or even 1"?
helipilot77
I can't go to low or the drag link will hit the oil pan when the suspension compresses.
LittleSteve
Quote from: helipilot77 on July 09, 2015, 08:45:06 AM
I vote we make a new pan and pick up.."
Refusing to fit in or comply.
Easy is not worth anything.
helipilot77
Quote from: LittleSteve on July 09, 2015, 12:58:42 PM
I already did. If I go any higher I'll be into the crank!
redneckcustoms13
The shaft feeding the box, coming from steering wheel. How does that seal go in? Could I simply take a pick and remove it? Does the whole nut have to come off the box in order to replace that?
01 double cab hunting truck
06 tacoma street truck
helipilot77
#77
Quote from: redneckcustoms13 on July 17, 2015, 07:54:18 AM
It is pressed in, from the inside of the top housing. You can see me pressing it in here.
You would have to take that housing off to replace that seal.  :sad2:
redneckcustoms13
I was afraid of that. Fork it I'll just grab a box at the junk yard.
helipilot77
So on the way home from work yesterday my FJ-80 dual diaphragm brake booster catastrophically failed. I found myself throwing all of my body weight into my brake pedal for a normal stop. I'll be picking one up at the salvage yard this weekend. I tested it with my mighty-vac and it wouldn't hold any vacuum for even a second.
redneckcustoms13
I just bought one from oreillys. I was pulling my boat when mine went out. No fun at all...
zippo
That sucks dude! Let me know if I can help.
SqWADoosh
Quote from: helipilot77 on July 30, 2015, 04:10:30 AM
Yikes dude!  You can't get a break can you?  :therethere:
Quote from: SqWADoosh on July 30, 2015, 10:30:29 AM
You meant to say, " Yikes dude!  You can't get a brake can you?"
SqWADoosh
Quote from: blackdiamond on July 30, 2015, 12:22:46 PM
No I'm not as corny as you.  :cheese:
helipilot77
#85
Quote from: redneckcustoms13 on July 30, 2015, 10:20:52 AM
Yikes! That's the worst time to have a booster fail!
Drove an hour and a half down to B&R auto wrecking today in Napavine. Even though their database said they didn't have one, I was able to find one out of an FJ-80. $50 for the booster and a throttle cable.
SqWADoosh
Quote from: helipilot77 on July 30, 2015, 08:39:23 PM
There a reason you went there? I would think there would be a yard closer than that?
helipilot77
Quote from: SqWADoosh on July 31, 2015, 05:35:12 AM
Nobody else had one listed on car-part.com
SqWADoosh
Quote from: helipilot77 on July 31, 2015, 06:11:34 AM
Thought that above you said that the database stated that they didn't have one?
helipilot77
Quote from: SqWADoosh on July 31, 2015, 06:38:05 AM
Car-part.com said they had three, but their internal database said they didn't have any.
