FJ40/FJ60 mash-up
Started by Flipper1938, November 29, 2014, 07:45:41 AM
Flipper1938
I have a basket case 1974 FJ40 and a 1985 FJ60 parts truck and want to make a decent FJ40.
The FJ40 was V8'd with a toyota trans and transfer case a couple of owners ago.  The guy before me got rid of the toyota trans/transfer case/ and rear axle.  He bought a SM465/205/ford 9" to put in it. The front LC axle has been re-drilled to 5x5.5 to match the bronco rear axle.  He also kept the AA bellhousing in the pile just in case.  Current suspension is spring under with Big Dicks 4" lift springs.
I'm thinking about taking the transmission, transfer case, axles, springs, power steering and maybe the A/C unit from the FJ60 along with the AA bell housing and build a spring-overed FJ40.
Anybody see anything wrong with this plan?
Reeses81
 Sounds like a good plan, take some good pics to post!  :thumbsup:
MRHilux87
Subscribed. Soundsike you need a 4bt and a front 60. Haha.
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
Flipper1938
Quote from: MRHilux87 on November 30, 2014, 10:25:37 AM
...and keep the 9" ford rear?
Flipper1938
Any other FJ60 parts from the donor that I should try and work into the FJ40?
Flipper1938
Flipper1938
zippo
NICE!!!!! I'lle take the FJ shell if you don't wnat it! Hell I'de even take the 85!
If you see it, its for sale.
Flipper1938
I can't believe I let this thing sit for so long without even mocking it up.  I bought it in pieces and moved it straight to my dad's barn.
Flipper1938
Flipper1938
Even though I plan on doing some welding to repair the cut quarter panels, I'm tempted to try and polish the paint.  I've never owned anything this old with original paint.
zippo
Flipper1938
Idea of what to do with the leftover FJ60 parts?
Flipper1938
Jaguar XJS clips going under the FJ60....
yep, at the bottom of the pile.  Yep they were aquired for the 48 they are in
20141230_112843 by Flipper_1938, on Flickr
front out
20141230_114546 by Flipper_1938, on Flickr
rear out...gotta love the tire mis-match
20141230_122629 by Flipper_1938, on Flickr
Landcruisers are pre-channeled from the factory [cl
20141231_121049 by Flipper_1938, on Flickr
Harvested the rear for Molly's FJ40
20150101_111848 by Flipper_1938, on Flickr
Nice flat spot
20150101_112156 by Flipper_1938, on Flickr
not too wide anymore
20150102_115021 by Flipper_1938, on Flickr
tada!
20150102_130718 by Flipper_1938, on Flickr
Flipper1938
Gasser cruiser???
20150102_131841 by Flipper_1938, on Flickr
More parts for Molly
20150103_100324 by Flipper_1938, on Flickr
20150103_112251 by Flipper_1938, on Flickr
Tada again...and this is without a motor.  It will be lower.
20150103_120358 by Flipper_1938, on Flickr
20150103_120422 by Flipper_1938, on Flickr
20150103_120434 by Flipper_1938, on Flickr
20150103_120555 by Flipper_1938, on Flickr
ryantowry_81
I love the lowered 60 look!!! Kudos man, but you got to get it lower still.
Flipper1938
Its going lower.  This was the first swing.
I need to build a step in the rear frame to raise the IRS assembly.  Front should come down quite a bit when the engine and trans are installed.
This thread. It's got potential. :eye: :eye:
Flipper1938
Quote from: BigMike on January 04, 2015, 10:53:49 AM
Do you like the FJ40, the FJ60, or both?
The 60 was not originally planned, it started out as a "how are we gonna move it around without axles?" discussion.  The jag stuff was in the barn....and it looks like it should work as more than something to make it roll.
Looking forward to seeing more of the 40 :thumbs:
Flipper1938
I can probably come down 4 inches without having to cut the rear floor depending on how brave I get with the notch
step notch by Flipper_1938, on Flickr
Flipper1938
I bought some serious rubber for the FJ60.  ...two sets of C5 Corvette rear wheels (18x9.5).  I guess it is turning into a pro-touring.
275/35/18 front and 295/35/18 rear tires
20150410_182219 by Flipper_1938, on Flickr
Flipper1938
Tada!
20150419_092026 by Flipper_1938, on Flickr
it will go down a couple more inches when I put a motor in it
20150419_092007 by Flipper_1938, on Flickr
Flipper1938
I picked up a chevy 5.3 for the FJ40.  I'm going to hook it up to the fj60 4 speed.
Flipper1938
When hooking a LS engine to a Toyota 4 speed via a AA bellhousing....can I use a 2005 chevy truck flywheel (.400 longer to match ls crank) and the 1968 Checker 6 cylinder clutch like a normal SBC to Toyota swap?  What throw out bearing and pilot bushing do I need?
