*****BTW, I used the 2nd 4Crawler Bearing Preload option (42lb, rotate 5 times L/R, Loosen, rotate cycle, 42lb, rotate cycle, loosen, rotate cycle, 21lb final tighten. I used the pull scale to test bearing preload. Driver 4lb, Passenger 7lb. Guide says between 3-8lb is fine. Can I get an opinion on this?*****
Started by shmizle Project Research and Build-Ups
Started by lilbuddy Parts Wanted
Started by Scarface06 Toyota Pickup/4Runner Tech 1979-95
Started by 79coyotefrg Parts For Sale
Started by Rockin4Runner Axle/Differential/Steering
