ImmortalYota80's First Gen Build
Started by ImmortalYota80, July 02, 2013, 10:22:46 PM
HogCanyonHopper
J_Cole92
3rz is gonna be bad asssss when its back goin again you'll have to come up and wheel the rubicon with us sometime
92 4Runner built on Toyota axles
84 Xtra Cab stock Daily Driver
55 Willy's Pickup Cab
Can't find it grind it
4runner build: http://board.marlincrawler.com/index.php?topic=96221.0
ImmortalYota80
Quote from: J_Cole92 on April 22, 2014, 02:42:23 PM
Hell ya man im down! My goal is to have the 3rz swap done by the end of summer.
1980 4x4 Pickup, 22RE Swap, Marlin Built G54 Trans, 35/12.50 Cooper STT's, 4" Alcan Front springs/F150 rears, Open 5.29 front, 5.29 E-Locker Rear, Rebuilt Axles, High Steer
Build:
http://board.marlincrawler.com/index.php?topic=94416.new#new
ImmortalYota80
Ok so here are some pics of yesterday  :shake:
Started tearing her apart today. Just have to take out the trans bolts and itll be pulled probably by tomorrow i hope  :crossed:
Whats wrong here???
Ya thats right looks like she was hungry for some thrust washers yummmmmmm  :yumyum:
Build:
ImmortalYota80
Ok got the engine pulled today. Pretty easy to do by myself. The old 20r is forsale has a good top end 2 year old smog legal webber carb, and a good leak free powersteering setup.
She sits 2 inches taller  :love:
Build:
HogCanyonHopper
what tranny are you planning on running with the 3rz swap? maybe I missed that
ImmortalYota80
Quote from: HogCanyonHopper on April 27, 2014, 06:38:51 PM
I have a marlin built G54 that I got about one month ago. I really hope that its gong to work cause i just dropped 1500 on that transmission.
Build:
HogCanyonHopper
hate to break it to ya but i dont think there is any way you will be able to bolt that tranny to a 3rz. better do some research
ImmortalYota80
Quote from: HogCanyonHopper on April 27, 2014, 07:01:55 PM
A w59 bellhousing will bolt up to my current g54 they have the same bellhousing boltpattern as a w56
Build:
HogCanyonHopper
nice. I did not know that. maybe I better do some research  :ha_ha:  :hammerhead:
HogCanyonHopper
ImmortalYota80
Quote from: HogCanyonHopper on April 27, 2014, 07:15:21 PM
http://board.marlincrawler.com/index.php?topic=29043.0;message=318196
some info here that may be useful to you
Ya ive seen that but im not too worried about running a G54. I mean it is a brand new marlin built transmission if I ever have any problems with it I know that marlin will help me out im not worried about it at all.
Build:
1985CRAWLER
this is gonna be sick! i love a good 3rz powered 1st gen.
i just wish i would've done the swap after my original 22re bit the dust instead of dropping another 22re in it.
ImmortalYota80
Quote from: 1985CRAWLER on April 27, 2014, 08:25:09 PM
Thanks im pretty excited to start it too stay tuned!
Build:
ImmortalYota80
Ok so i have a guy that wants to trade me for my old engine for a set or 4 35 inch bfg km1 tires. 3 Tires have 60% and ones got 20%. Do you guys think thats a decent trade?
Build:
damascusyota
Is there a reason most everyone chooses the 3rz over the 2rz? I know the 3rz has more displacement but from what I remember reading, the performance numbers are practically the same.. just wondering.
ImmortalYota80
Quote from: damascusyota on April 27, 2014, 09:41:26 PM
Im not sure either but id settle for a 2rz. 3rz jut seems more popular.
Build:
Tungsten Slayer
Little difference in power between the 3 and 2RZ.  8 HP to be exact.  The 3RZ has a forged crank while the 2RZ is Cast from what I was told.  3RZ has balance shafts which I would delete for rock crawling and the 3RZ has a longer stroke, hence the balance shafts and more displacement.  I always rock the 2RZ because of no balance shafts and I get em so much cheaper.. Going turbo on mine right now.
ImmortalYota80
Ok so I got my dash pulled and started stripping the truck down even more.
Some of the wiring is a little messy and has been nig rigged but i will clean everything up
Now i have no clue why the previous owner did this
Those are the ports for the heater and ac to go to the little dash vents on the sides. I have no clue why they have been blocked off. Also im going to be removing all me AC stuff it doesnt work anyways and it wont be compatible with the new engine.
Build:
Dingman.
Quote from: ImmortalYota80 on April 27, 2014, 08:48:19 PM
Kind of your call..  Im not sure how long ago they made km1's but i feel like it has been awhile.  with that said ive always heard people say once a tire is 7years old it is no good anymore.  After i had a 8year old km1 blow out on the highway, i started staying away from buying old tires.  just my :2cents:
ImmortalYota80
Well boys and girls its not a 3rz but I suppose its not that bad of a deal for only $800
Build:
megaphoneman
Chuyota
ImmortalYota80
Well only had the runner for one day and the tear down has already began!
Also i thought this was weird my ECU is labeled 22r
I've decided that im going to do a complete rebuilt to the engine. I compression tested the cylinders and they were
#1- 170 PSI
#2- 175 PSI
#3- 171 PSI
#4- 179 PSI
I thought that was very high so im extremely happy with this. I'm simply gonna get new gaskets, seals, water pump, oil pump, some stiffer valve springs, and maybe a cam. Since the compression is so high im most likely gonna leave the bottom end be because everything should be in good shape. I'm gonna order everything through 22re Performance. Any other suggestions?
Build:
ImmortalYota80
Also forgot to mention that my dad has a buddy that has a little welding for me to do to his bronco. Gotta weld some shock hoops on, weld a set of mounts on for his new extended radius arms, and cut and turn his dana 44 axle knuckles. Hes giving me a brand new set of 35/12.50 tires for this work well worth it if I do say so myself  :ladys-man:
Build:
ImmortalYota80
Build:
1985CRAWLER
Quote from: ImmortalYota80 on May 26, 2014, 08:50:26 PM
:thumbs:
good choice! they are great guys there and gave me a good deal on parts for mine!
Dwill817
I would so appreciate it if you would do a really good write up on the 22re swap! Especially on the wiring required! I would almost pay you... almost. Lol
I have a spectacular opportunity to do a 3rz swap (whole truck for $300 :o ), but I don't know if I can do the wiring for it so I may go with a 22re if I can find a truck.. Either way, I'm sure many others and myself would benefit from a legit write up on a 22r ---> 22re swap.
ImmortalYota80
Quote from: Dwill817 on May 26, 2014, 09:42:06 PM
You know theres a ton of info out there for 3rz swap but not alot for the 22re. Basically its all an easy swap up until you have to splice in your existing guages, ignition and all that other fun stuff. Thats where im stuck at and looking for help.
Build:
Dwill817
Quote from: ImmortalYota80 on May 26, 2014, 09:46:30 PM
Yep! I'm not at all worried about mounting the 3rz and transmission, rerouting the exhaust, clutch lines, gas tank, etc. but the behind the dash wiring scares the heck outta me. BUT a 3rz would be awesome! My uncle has done several LS swaps and a few other domestic swaps so he may be able to help me out. If not, I may wind up paying someone to do the wiring part..  :crossed:
