2012 - $1,000 Holiday Wish List Give-A-Way! [FINISHED!]
Started by BigMike, December 07, 2012, 07:30:10 PM
Buck87
1.Twin Stick Kit
2.4.70:1 Competition Chromoly Gear Kit
Hurry! I want them installed in time to go to King of Hammers.
http://www.marlincrawler.com/wishlist
Thanks
$0.00
Matt 1987 4Runner, 5speed, 22re,SR5, mostly stock
suueeet
   Toyota 9.5" 4:88 Land Cruiser $277.90
   Toyota 8" 4:88 High Pinion $347.85
   Tire Inflator $69.95
   Powertank Pro Series Tire Repair Kit $39.95
   Snap Ring Pliers $24.99
Thanks Santa Marlin!
Wallace
Thanks for the opportunity, Happy Holidays!!
http://www.marlincrawler.com/wishlist/678
Marlink for Hilux/4Runner
4Runner Front Bumper
Turbo Clutch Upgrade Combo Kit
2 Low Profile Magnetic Drain Plug (Metal Gasket)
3 Low Profile Magnetic Drain Plug (Aluminum Gasket)
XL Hoodie
some day...
Cyberman
#304
http://www.marlincrawler.com/wishlist/467
Chromoly 30 spline front axles
Knuckle service kit
54mm hub socket
Knuckle alignment tool.
2- Bilstein 5125 (12" )
Hoodie
14 days to go!
Sent from my DROID RAZR using Tapatalk 2
'91 Xtra cab 3.0 SAS, 5.29s, single 4.7 transfer, locked f/r, 35s
My Frame-up Rebuild Thread
sandman250
This is a great deal! Come on... Victory!!!
I am all about the differential right now!
5:29 Grizzly Rear complete Pinion    $1049.99
5:29 Spool Front complete Pinion   $749.99
http://www.marlincrawler.com/wishlist/677
Tyler+Ashleys4runner
 :bowdown: :bowdown: Thanks for the chance  :bowdown: :bowdown:
The items off my wish list that i need are
1. Front bumper for 1990 4runner with short stinger
2. Heavy duty clutch kit v6
3. Clutch slave cylinder
4. 2- elocker motor guards in red
5. 2- front wheel bearing kits
6. Front axle top brace
7. Tie rod end left
8. Tie rod end right
9. Large hoodie
10. V6 3.0 manifold badge
11. Marlin crawler 3" round sticker
Total $999.51
Link to my wishlist
http://www.marlincrawler.com/wishlist/469
1981 pickup  home build dual case 35" tires "sold"
1986 4runner diamond axle, tg axle 37mtr elockers f/r dual case "sold"
1990 sr5 4runner sas  35 km2's e-lockers front and rear. "Sold"
1995 4runner vw1.9 diesel, diamond axle
87crawlin
Quote from: sandman250 on December 11, 2012, 10:58:05 AM
you do know you cant go over $1,000 total right?
Mdumaw
Holy wow, most amazing thing ive seen someone do for their customers,  :thumbs:
http://www.marlincrawler.com/wishlist/427
only took me 3 days to figure what i wanted  :greengrin:
My list
1. W56 Rebuild Kit, 1985-91 $299.00
2. 2X Toyota 8" 4cyl 4.88:1 Ring & Pinion $483.28
3. 1X Toyota 8" 4cyl Differential Set up Kit $164.32
Total $946.60
You guys are awesome! :usa:
94YOTAGIRL1026
Currently I am building my 94 v6 Toyota. I have had this dream of what it would look like since I was little. Now it's my senior year and before grad she needs to be prime :) thank you for this opportunity Marlin Crawler!
Http://www.marlincrawler.com/wishlist/236
<3 BOGGERS <3 "I don't fall for pick up lines, I fall for pick up trucks!"
tawneybuilt
I'm wishing for a set of 4.70 gears and a high steer kit.
http://www.marlincrawler.com/wishlist/685
Thanks Marlin!
Slowzuk
1stgenteege
Dual Case Kit (MC07-XD) $429.00
Heavy Duty IFS Steering Box Mount Kit$55.00
Heavy Duty Clutch Kit (1,200 lb)$288.05
U-Bolt Flip Kit $59.00
3/8" Spring Pad Spacer $6.00
Billet Aluminum Transfer Case Shift Knobs $39.00
Transmission Shift Knob $49.00
* The Unique Link to your Wish List is: http://www.marlincrawler.com/wishlist/579
This has to be the coolest thing any company has ever done. Thanks for the chance to win some high quality parts! This would help my build out so much. 1983 pickup 2rz duals yadda yadda. Thanks again!
NCK4L
thanks a lot for doing this guy, youre gonna make one lucky crawler very happy this christmas :beerchug:
looks like the 25mm steering upgrade wont be available?
4 tie rod ends
arb recovery strap
2 hoodies
snap ring pliers
c clip pliers
2 spartans for 4 cyl 8"
http://www.marlincrawler.com/wishlist/688
Quote from: THK Matt on December 11, 2012, 12:31:40 PM
Not true, Mike already has said that it is ok to go over as long as you plan on paying the difference.
zorak
zippo
Star Light Star bright,
The first star I see tonight,
I wish I may, I wish I might,
Have the wish I wish tonight.
1 x Front Axle Service Kit
1 x Dual Case Kit (MC07-XD)
1 x W56 Kit, 1985-91
2 x Backing Plate Eliminator
2 x Spindle Brass Axle Bushing
http://www.marlincrawler.com/wishlist/691
If you see it, its for sale.
noredcoat
http://www.marlincrawler.com/wishlist/259
   Gear Drive, Right-hand output      $849.00
   Clutch Fork Boot      $15.38
   Shift Handle Boots      $7.03
   G52      $1,039.10
smunns
Thanks for the chance!
http://www.marlincrawler.com/wishlist/692
      Speedometer Extension Cable
      $39.00
      Clutch Slave Cylinder
      $39.99
      $55.00
      Shock Hoops
      $69.00
      Bumpstop Extensions
      $12.00
      Full Face Differential Armor
      $118.00
      Front Wheel Bearing Kit
      $90.00
      Bilstein 5125 series
      $158.00
      $17.00
      Spindle Nut Kit
      $17.58
      12mm Knuckle Stud
      $31.20
      Bumpstop (large)
      $59.00
      Crossover Pitman Arm
      $59.00
      $49.00
      Heavy Duty Shift Lever Ball Seats
      $12.49
      Heavy Duty Shift Lever Socket
      $7.49
      $39.00
      Clutch Fork Boot
      $15.38
      54mm Socket
      $24.99
      Hoodie
      $29.00
      Brake Pads Early Style
      $19.99
      8mm Hub Stud
      $12.36
      12mm Knuckle Cone Washer
Thorn4run
Just spent $3000 rebuilding the motor on my '88 4Runner so winning this "wish list" give away would rock! http://www.marlincrawler.com/wishlist/654
  Colorado, 3rd Edition
         $29.95
   Moab 2nd Edition
         $29.95
   Hoodie
         $29.00
   Chromoly UM07 Marfield, 27-spline
         $129.00
   Zip Locker 8" 4cyl
         $768.39
   Oil Slingers
         $13.50
Cyberman
#322
Knuckle service kit
54mm hub socket
Hoodie
Looking for some Christmas cheer.
nicholas9999
http://www.marlincrawler.com/wishlist/693   All i need is a rebuilt manual G52 Transmission i choose the heavy duty for my 1984 Toyota 4 Runner as i still have the orginal in it and it is getting kinda tired. Thanks Edward  Merry Christmas to all.  :driving:
chris10338
I would have to say "Marlin Crawler has the highest quality Toyota parts and they give $1000 away in gifts as a bonus". Hard to beat that deal. Love there new Toyota 8.0" 4cyl Completely Assembled Differential equipped with a Grizzly Locker and 5.29:1 gearing.
http://www.marlincrawler.com/wishlist/694
Got a heavy exo-cage need that Grizzly locker
Crawlin85
85 runner with cool stuff
-A truck with a body lift is like a fat girl in a mini skirt, it shows you everything you don't want to see
inh
http://www.marlincrawler.com/wishlist/698.        Looking to get a front bumper, a HD comp clutch, And a front axle armor cover.
Rockdad
For Christmas I would like a Chromoly 30 spline axle kit and a 8" Grizzly locker for a 4cyl.
http://www.marlincrawler.com/wishlist/445
Thanks Santa Mike & Marlin!!! Thanks for making Christmas wishes come true!!!
Please! Please! Please! Please! Please!Please! Please! Please!
TacoRunner's 3 & 4 Link Systems
http://www.4wheelunderground.com/
Ready for any trail adventure you throw at it!
bdcplayer_83yota
http://www.marlincrawler.com/wishlist/702
30 splined chromo axle kit
spartan 8" 4cyl locker
heavy duty knuckle gusset kit
$980
i picked the three things that would help out the most for next season
