2012 - $1,000 Holiday Wish List Give-A-Way! [FINISHED!]
Started by BigMike, December 07, 2012, 07:30:10 PM
akarilo
After previously purchasing a 4.7 box years ago, (loved it), I would like to experience the 3.1 Landcruiser gears in my FZJ 80.  I have about 5 buddies with the same truck that I can show them off to.  :D  Of course then they'll want some too.
http://www.marlincrawler.com/wishlist/558
Graet promotion for the wheeling community.
toyotajoe35
He is my wish list for my Red Runner:
High steer kit with heavy duty 25mm lower caps and bearings.
Heavy duty knuckle gusset kit.
Full face differential cover.
Short throw shifter for R150f with 3vze.
Tall shock hoops.
http://www.marlincrawler.com/wishlist/108
Thanks for the opportunity win some of you great products Made in USA. Merry Christmas.
kilkus
Hope all have a very happy holiday!  My wish list includes some front axels, rebuild kit, and the tools.  Hoping to my project "Slimer the climber" the best 85 yota  runner it can be.  Good luck to everyone!
http://www.marlincrawler.com/wishlist/561
emsvitil
#183
PICK ME.....
:cheese:
http://www.marlincrawler.com/wishlist/555
Toyota 7.5 IFS R&G 4.88
Toyota 7.5 IFS R&G setup kit
Toyota 8.0 V6 R&G 4.88
Toyota 8.0 V6 R&G setup kit
Toyota 8.0 V6 3rd member housing
Solid pinion spacer for 8.0 V6 R&G
Solid pinion spacer for 7.5   (One of the 8.0 solid pinions will fit the IFS 7.5, lost link of which one......)
Just added
22RE sticker
Spring Perch
thanks
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Cheesemaker
Took me awhile.
http://www.marlincrawler.com/wishlist/562
Thank you guys, I know I would put it to very good use, and be one huge step closer to going slower!!
MC07-XD
Total Spline input
Spartan locker 8" V6
$915.49
KDXSR5
Thank you for this opportunity!
Bilstein 7100 series Short Body 12" (x4)
Bumpstop (large) (x4)
LINK->  http://www.marlincrawler.com/wishlist/563
Toyotadon
Land Cruiser Crawler Gears  :turtle:
Powertank 10 lb. Kit
http://www.marlincrawler.com/wishlist/565
Can I use my 10% off coupon?  ;)
usickid
http://www.marlincrawler.com/wishlist/564
Rear Axle Service Kit, 1979-99 (2x)
High Steer Kit for Hilux
Heavy Duty IFS Steering Box Mount Kit
Rebuilt IFS Steering Box
Mahalo for the giveaway i going be sick if i actually win and no more da high steer in stock.
superkaliguy
Cletis Crawdad
Thanks For the opportunity!!!  :biggthumpup:
Chromoly 30 spline Axle Kit
Chromoly rear Axles
2Rear Axle Service Kits 1979-99
2 spindle Brass axle bushings
Front axle service kit
2 Heavy Duty rear axle ECO seals
http://www.marlincrawler.com/wishlist/119
Xj chopper
I can't think of a better Christmas gift! Only marlin parts are good enough to go on my runner. Keep up the great work gentlemen.
http://www.marlincrawler.com/wishlist/357
GET IT
Cyberman
#191
http://www.marlincrawler.com/wishlist/467
Chromoly 30 spline front axles
Knuckle service kit
54mm hub socket
Knuckle alignment tool.
2- Bilstein 5125 (12" )
Hoodie
Ho ho ho
Sent from my DROID RAZR using Tapatalk 2
'91 Xtra cab 3.0 SAS, 5.29s, single 4.7 transfer, locked f/r, 35s
My Frame-up Rebuild Thread
Homefries
http://www.marlincrawler.com/wishlist/571
Marlink for Hilux/4Runner
30 Spline Chromo input/output combo
Marlin XL Sweatshirt
High performance V6 brake combo
30 Spline Chromo axle kit
Donzo
I would love to win the items from my wish list!  I could really use a zip locker, ARB Recovery snatch strap, a crossover steering stabilizer, ARB compressor and more for my 85 4runner project truck http://www.marlincrawler.com/wishlist/573
cooju
ninja turtle
#196
Awesome giveaway Marlin crew!!
1,010- 3" Marlin Crawler stickers
http://www.marlincrawler.com/wishlist/414
zembalayan
Wow!   This is awesome.  Thank you, Marlin Crawler!  I went crazy with the wish list, detailed and linked below, which is well over $1,000, but it's a wish list, right?  I'd love to have anything and everything on there, and probably more as well!  ;-)
Here is the link to my unique wish list:
http://www.marlincrawler.com/wishlist/572
Here is what's on my wish list so far:
One (1) Marlin Crawler Bolt-in Crawl Box with following specs: 2.28:1 21 spline input; 23 spline output; 1984-1988 forward shift style; 10* rotation.
One (1) Marlin Crawler Rebuilt Heavy Duty W56A 5 speed transmission.
One (1) Marlin Crawler Short Throw Shifter Kit for R151F.
One (1) Toyota Steering Arm Service Tool
Two (2) Bilstein 12" Short Body 7100 Series shock absorbers
One (1) ARB Compressor Wiring Harness for standard compressor
One (1) ARB Air Locker Purge Valve Kit
Two (2) FJ60 Oversized Wheel Cylinders
One (1) Marlin Crawler 4.70:1 Competion Chromoly Gear Set
One (1) Marlin Crawler 30 Spline Chromoly Front and Rear Output Shaft COMBO KIT!
Thanks again for the very generous chance!!!
MHopkins
http://www.marlincrawler.com/wishlist/574
Gasket & seal rebuild kit
Poly body mount kit
HD ifs steering box mount
Crossmember mount HD
Arb air compressor
Shift knob
Extended brake line kit hilux
4 hilux driveline u joints
2 oem pinion seals
2 solid pinion spacer kits
Toy 8" 4cyl setup kit
kiyul4130
-kiyul-
ECV 7-11
KYOTA FOREVER
ohoktimmyg
Hey thanks for the great products I already have on my truck, and also for this chance to win some more!
ARB Rear Air locker RD132
http://www.marlincrawler.com/wishlist/576
:greengrin:
wakkjobb
#201
Well since I didn't win anything from the $bajillion-dollar Powerball...
http://www.marlincrawler.com/wishlist/577
It's never too early to start piling parts for another build; especially since this was the end of my last attempt:
Too rusty (frame, quarters and floors) and too many other projects right now... :down:
:beerchug:
Rockdad
#202
For Christmas I would like a Chromoly 30 spline axle kit and a 8" Grizzly locker for a 4cyl
http://www.marlincrawler.com/wishlist/445
Thanks Santa Mike & Marlin!!! Thanks for making Christmas wishes come true!!!
TacoRunner's 3 & 4 Link Systems
http://www.4wheelunderground.com/
Ready for any trail adventure you throw at it!
mudmaster
Wishing for a Grizzly equipped 8" high pinion 3rd with 5.29 gears
http://www.marlincrawler.com/wishlist/124
Time to go wheelin!
mclare6
On my wish list for my 1984 4runner I have:
Extended brake lines
Brake caliper and rotor combo because stopping is a good thing.
Front axle service kit, so the wife will stop complaining about the gear oil spots on the drive.
Spartan locker for a 4cyl 8"
Backing plate eliminators
Wishlist link- http://www.marlincrawler.com/wishlist/462
PhantomD aka Zach
#205
I already have dual cases, and E-lockers, I just need some axle shafts and I would like your new Short Throw shifter. My friends have been talking about it and I would like to be the first to have one!
If I win it will motivate me to paint my truck too!
Here is my list:
http://www.marlincrawler.com/wishlist/582
Short Throw R150F shifter
Chromoly 30 spline axle shafts
2 Bilstein 5215 12" shocks
Snap ring pliers
MARLIN HOODIE!!!
Maybe a photo would inspire the contest?
3rd Gen Extra Cab, Dual Cases, E-Lockers
Porterka
http://www.marlincrawler.com/wishlist/305
Dual Case Kit (MC07-XD)
Heavy Duty Knuckle Gusset Kit
Hoodie
Knuckle Alignment Tool
Full Face Differential Armor x2
Front Wheel Bearing Kit x2
There is so much more though...
Thanks for the oppurtunity.
Tyler+Ashleys4runner
 :bowdown: :bowdown: :clap2:
Thanks for the chance  :bowdown:
The items off my wish list that i need are
1. Front bumper for 1990 4runner with short stinger
2. Heavy duty clutch kit v6
3. Clutch slave cylinder
4. 2- elocker motor guards in red
5. 2- front wheel bearing kits
6. Front axle top brace
7. Tie rod end left
8. Tie rod end right
9. Large hoodie
10. V6 3.0 manifold badge
11. Marlin crawler 3" round sticker
Total $999.51
Link to my wishlist
http://www.marlincrawler.com/wishlist/469
1981 pickup  home build dual case 35" tires "sold"
1986 4runner diamond axle, tg axle 37mtr elockers f/r dual case "sold"
1990 sr5 4runner sas  35 km2's e-lockers front and rear. "Sold"
1995 4runner vw1.9 diesel, diamond axle
AC
Would have loved to select the 4.7 transfer case gears, but out of stock.
W56-A transmission. Thanks for the opportunity guys.
http://www.marlincrawler.com/wishlist/578
tanabuse
http://www.marlincrawler.com/wishlist/583
thanks for the opportunity for the chance to win some big parts guys
here is my wish list for my 80 hilux i just busted my front ring and pinion out of high pinion diff now i need new gears!!
(1.) Toyota 8" High Pinion 5.29 youkon gear set
(2.) Rf1A 30-Spline transfercase Chromoly Output COMBO KIT
Turning
Over after
Years
Of
Trail
Aabuse
