2012 - $1,000 Holiday Wish List Give-A-Way! [FINISHED!]
Started by BigMike, December 07, 2012, 07:30:10 PM
Tug86
Count me in, I am headed out to the garage to gift wrap my transmission core. Thanks Marlin!   :thumbs: http://www.marlincrawler.com/wishlist/808
The_josh
http://www.marlincrawler.com/wishlist/809
Powertank pt10-a kits
ARB air compressor qty 2
Tire inflator
Thanks!
4runner
http://www.marlincrawler.com/wishlist/493
Merry Christmas Marlin and Crew...Thanks for the chance
This will be a good start on my next rig
Heavy Duty Knuckle Gusset Kit
2 Electric Locker Motor Guard
4 Bilstein 5125 series
Heavy Duty IFS Steering Box Mount Kit
Hoodie
Silicone Ultra Gray
Dual Case Kit (MC07-XD)
built not bought 89 4runner
vortec v8, r151, dual cases
4link 1/4 elliptical
79toy20r
Thanks for the chance guys!! I need some parts for my truck that was stolen and stripped! Hopefully will be back to its former glory soon!
1- 79-83 front u-bolt flip kit $59.00
1- 79-95 rear u-bolt flip kit $59.00
1- 8" High pinion 3rd member housing $261.57
1- 8" High pinion 5.29 gear set $347.86
1- 8" High pinion setup kit $229.05
1- Billet aluminum transfer case shift knob $39.00
Grand total- $995.28
http://www.marlincrawler.com/wishlist/810
1994yota
Thanks for the chance for some free parts on my build  :crossed:
2-Full Face Differential Armor
1-Spool Equip 8" 4cyl 5.29
2-Bumpstops (large)
http://www.marlincrawler.com/wishlist/811
1-4MTNS
Thanks for the chance ------ >  http://www.marlincrawler.com/wishlist/813
Power Tank
•PT10 Alumuinum Tank (powder coated) w/ Nickel Plated Valve
•SuperFlow HPX Regulator
•25' HP1100 braided hose
•Power Grip Guard
•Super Bracket
•Tank Boot
•Cover
And the Tire Inflator
FJ40
HARLEY
LEXUS
THE GOOD LIFE ....
82rustbeast
#456
 http://www.marlincrawler.com/wishlist/624
Rocker switch cover
Speedometer Extension Cable
Crossmember Mount, HD
Upper Axle Reinforcement Gusset-Solid
x2-Chromoly UM07 Marfield, 27-spline
Caliper hard lines (Left and Right)
Clutch fork boot
Heavy Duty Shifter Seat, Forward Shift
Clutch Slave Cylinder
Heavy Duty Transmission Output Seal
Heavy Duty Transfer Case Rear Output Seal
Heavy Duty Shift Spring
x2-Brake Line Mount & Clip Set
I worked on this way back when the contest started, but Im just now getting to finish it. Thanks for the opportunity, this will help immensely!
Thanks Marlin!  :biggthumpup:
fj-rankenstein
the never ending build...
http://board.marlincrawler.com/index.php?topic=12165.0;highlight=extend-a-toy
Quote from: BigMike on April 10, 2010, 11:30:18 AM
Was searching for something and came across this old jew. BUMP to a classic thread :thumbs:
OVRAROK
OVRAROK
crossmember mount oem
clutch master cylinder
clutch slave cylinder
chromoly rear axle(s)
w56 rebuild kit 85-91
http://www.marlincrawler.com/wishlist/814  happy h :turtle:lidays marlin crawler
Tyler+Ashleys4runner
Only one more day i cant wait  :clap:
The items off my wish list that i need are
1. Front bumper for 1990 4runner with short stinger 2. Heavy duty clutch kit v6 3. Clutch slave cylinder 4. 2- elocker motor guards in red 5. 2- front wheel bearing kits 6. Front axle top brace 7. Tie rod end left 8. Tie rod end right 9. Large hoodie 10. V6 3.0 manifold badge 11. Marlin crawler 3" round sticker
Total $999.51
Link to my wishlist http://www.marlincrawler.com/wishlist/469
1990 sr5 4runner sas
1981 pickup  home build dual case 35" tires "sold"
1986 4runner diamond axle, tg axle 37mtr elockers f/r dual case "sold"
1990 sr5 4runner sas  35 km2's e-lockers front and rear. "Sold"
1995 4runner vw1.9 diesel, diamond axle
Steve-44
http://www.marlincrawler.com/wishlist/92
MC07-R10
4.7, 23spl, chromo gearset
30spl, chromo output combo set
speedo ext cables
~$1,725
The anticipation mounts!   :crossed:
ace
 I would like the heavy duty front driveshaft and the dual case adapter kit http://www.marlincrawler.com/wishlist/482
spongeidys
http://www.marlincrawler.com/wishlist/818
Dual Case Unit
WhiteLightning
http://www.marlincrawler.com/wishlist/830
4.7 gears
30 spline t case outputs
I'll cover the diffetence  :gap:
Merry Christmas and thanks for the chance.
Staceman
http://www.marlincrawler.com/wishlist/829
Dual Case Unit
HD Crossmember Mount
SHD Clutch Kit
Twin stick boot replacement (mine's torn!)
Turtle shift knob (a must have)
T-Shirt, yet another MUST have!!
sandyrunner
http://www.marlincrawler.com/wishlist/828
   Rocker Switch Brackets  $6.42
   RD132  (ARB locker)   $977.18
   Rocker Switch Covers   $4.95
   Rocker Switch  $10.02
      total $998.57 :usa: murika
Guims
It's a long time to watch your product  :thumbs:
http://www.marlincrawler.com/wishlist/832
I'll cover the freight cost to New caledonia  :yikes:
   1 Grizzly Locker 8" V6
   1 Transmission Shift Knob
   2 Heavy Duty Rear Axle Eco_seal
   2 Rear Axle Service Kit, 1979-99
1994 LN106 reg Cab 2.8 Diesel  - A/T 31"  - 2" OME lift - ARB bumper - Alloy Flatbed - Factory SAF : )
wyomingben
wickedlowss
 http://www.marlincrawler.com/wishlist/831
28.50" no cv Front Driveshaft  built to fit triple drilled flanges
Front bumper with stinger for 94 Toyota pickup
Snowtoy
http://www.marlincrawler.com/wishlist/823
Shock Hoops
6cyl 1988-95 Heavy Duty Clutch Kit (1,200 lb)
4cyl 1989-92 Heavy Duty Clutch Kit (1,200 lb)
Hoodie
ARB Air Compressor
ARB Compressor Wiring Harness
xxxtreme22r
Pretty much everything I need to fix my ailing rear and some other stuff and the mandatory Marlin Bling. :)
Thanks guys. I hope I win.
http://www.marlincrawler.com/wishlist/827
Toyota 8" V6 4.88 Yukon Gears
Heavy Duty Shift Lever Ball Seats White and Blue
Toyota 8" V6 Set-Up Kit
Spartan 8" 6cyl Locker
Heavy Duty Shift Lever Socket
Billet Aluminum Transfer Case Shift Knob
10th Anniversary Transmission Shift Knob
$948.15 total.
99nmtaco
Thanks for the chance to win some quality offroad products BigMike and Marlin Crawler!! For Christmas this year my taco would like:
Zip Locker 8" V6
Arb Air Compressor, Compact
http://www.marlincrawler.com/wishlist/383
It would make my taco's christmas very merry!  :driving:
rockscrambler
#477
wish everyone the best of luck. but I hope I'm the winner
http://www.marlincrawler.com/wishlist/838
Arb air compressor 263.39
3 1/4 arb recovery snatch strap 24, 000lb 78.18
4 1/3 Arb recovery snatch strap 33, 000lb 105.95
Hoodie xxl 34.00
Powertank PT10 - a kit 439.95
Windshield sticker 24.99
Powertank pro series tire repairs kit 39.95
2 12 " turtle stickers 5.98
2. 6" turtle stickers 5.96
Total.   998.35
we're born,we roll over,we crawl,we walk,we run,we drive,we install cages,we wheel,we crawl,we roll over,the circle of life is complete.!
"we sleep peaceably in our beds because rough men stand ready in the night to bring violence upon those who would do us harm" to you I say thank you
87 Chevy K5 V10 tonka truck,87 Toyota 4runner
83 Jeep CJ8,sold-76 Dodge W200 & 87 Ford broncoII
Ryanrogers
I would like:
(2x) toyota 8" v6 5.29 ring and pinion gears
(1x) spartan 8" v6 locker
(1x) full face differential armor
(1x) 5.5 inch shackles
(2x) v6 left/right brake caliper
http://www.marlincrawler.com/wishlist/835
Thank you, Merry christmas!
larry d evans
http://www.marlincrawler.com/wishlist/839
for christmas my 4runner would like 4.88 gears and some chromoly birfields!
merry christmas and thanks for the chance to win.
larry
