2012 - $1,000 Holiday Wish List Give-A-Way! [FINISHED!]
Started by BigMike, December 07, 2012, 07:30:10 PM
ori
Thanks guys!!
http://www.marlincrawler.com/wishlist/584
3rd Member Housing
Heavy Duty Knuckle Gusset Kit
12mm Upper Knuckle Stud Kit
Oil Slingers
Solid Pinion Spacer Kit
Grizzly Locker 8" High Pinion
Toyota 8" High Pinion
rubiconrunnerneville
dual case 0* adapter
knuckle gusset kit
full face diff armor x2
snap ring pliers
58" sliders
3.4L short throw shifter
14" shock hoops
upper axle gusset solid
if the sliders come back in stock or you guys make them for me take off the 3.4L shifter please to get it back to a grand or under if you pick me thanks guys
ASE certified tech. Cummins factory trained tech.
4 5125 Bilstein 14" Shocks, Front Axle Service Kit, MC07-XD Dual Case Adapter, Crossover Steering Stabilizer Kit.
http://www.marlincrawler.com/wishlist/587
qmanman
Thanks for the chance to win! I've never won anything so this would a great gift.....
http://www.marlincrawler.com/wishlist/588
pickeledpigsfeet
#214
Thanks for the chance!
http://www.marlincrawler.com/wishlist/591
MC crawl box dual crawler kit, MC heavy duty clutch, V6 5.29 R&P(unless a MC top shift conversion kit is in stock by then).
90 sas xcab, arbs 5.29s iroks xd9000i,exo,blah,blah,blah
olomanaboy78
So here's what I'm thinking
http://www.marlincrawler.com/wishlist/590
...it's way over $1k
Items are:
Crossmember mount, HD
25mm steering upgrade
tie rod ends L & R
Backing plate eliminator
slave cylinder
L45 Trans (I know this thing is on its last turns, so here's to wishing!)
beedy89
bleakhorizon
i will put my name in the Marlin Crawler nice list (since santa has is on the Naughty list :( )
alot of stuff i was going to put on the list is out of stock... Bummer...
so without any more delay
my list is
Marlink, Front and rear shackle kits, 2 MarJoints, 1 front u bolt flip kit, 2 hoodies
AND a 500 dollar Crawl Card for when some stuff is off backorder.....
http://www.marlincrawler.com/wishlist/592
hopefully i fallowed the directions  :dunno: lol
Those are some huge welds!
Tillamook, OR
Skull
I sure could use the 30-Spline Chromoly Output Shaft Combo Kit and two Long Spline Drive Shaft Kits for my build. Thanks.
http://www.marlincrawler.com/wishlist/594
jessesmirl
Hi Guys! Love your products! Quality Merch!
For my wish list i would like:
some decals so i can represent! :biggthumpup:
1 - 92 Hilux Front Bumper
2 - rear axle service kits
1- super heavy duty clutch kit
2 -over-sized wheel cylinders
1- big bore v6 brake master cylinder
Pick me and help me tune up my 92 Shorty! thanks guys
http://www.marlincrawler.com/wishlist/568
La80sr5
http://www.marlincrawler.com/wishlist/595
Shock hoops
Front u-bolt flip kit
Rear u-bolt flip kit
Rear shackle hanger
Front 5" shackle
Rear 5" shackle
2 5.29 toyota 8" ring and pinion sets
Heavy duty Ifs steering box mount kit
Knuckle service kit
Total 1004.28
Thanks!
LiveWire64
TEN8HBO
1985 4Runner
4runner1316
Thanks guys, you guys rock.
Wishing for:
Short throw shift kit, r151f
knuckle gusset kit
diff armor x2
axle truss
brake caliper and rotor upgrade
body mount lit
rear bumper
large bump stops
steering stabilizer
front end service kit
http://www.marlincrawler.com/wishlist/581
1985 4runner, 22rtec, r151f, dual cases, 5:29's, arb's front and rear, All-Pro lift, 36" Iroks
BUDDERS
Here's my wish list:
http://www.marlincrawler.com/wishlist/604
Wish me luck!
Thanks to the Marlin crew for doing this  :biggthumpup:
nisota
#226
Chromoly 30 spline axle kit
T-case shift lever clip
Boot, transfer case handle
Axle shock mount
big bore v6 hilux brake master cylinder
Brake line mounting L bracket
Hoodie
3rd member housing
Here is my wish List http://www.marlincrawler.com/wishlist/603
Thanks to Marlin, Bigmike & Everybody at  :turtle: this stuff would finish my build & help me out alot, Good luck to everyone & Merry Christmas to all.
Nisota!!!
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
kevin88x
Thanks for the generous chance to win!!! I've been dying to buy an ARB locker but couldn't afford it.
http://www.marlincrawler.com/wishlist/605
22Ryan
tight on cash this year, 20 years old, work at a metal fab shop and go to cuesta college full time. winning would help me out a lot
http://www.marlincrawler.com/wishlist/606
David D
ryantowry_81
WOW! winning this would make it the best Christmas ever! I have been working 80 hour weeks trying to pay for my wish list after christmas. maybe this way i can actually see my family....lol
http://www.marlincrawler.com/wishlist/90
9.5" spartan locker
Knuckle Service Kit x2
54mm Socket
18mm Tap, Drain or Fill Plug
Five Pattern 27-Spline Flange x2
Five Pattern Differential Flange x2
Long Frame Bushings
MarJoint with Threaded Shank
Stock Upper Mount Shock Bushing
Threaded Tube Insert
Spring Perch
twin stick kit
Thanks for the opportunity!!!  you guys are awesome!!!
bigred013183
I've been working on my truck for awhile and would love to get it finished. All that's left is the rear end. Would love to win this and finally make my truck perfect.  :usa: :beer: :crossed: :bowdown: :bowdown: :bowdown: :bowdown:
http://www.marlincrawler.com/wishlist/608
lone walker
With high hope and with Marlin's help, these parts will finally get my rig up and running. Hope I get to enjoy them!
http://www.marlincrawler.com/wishlist/613
1. 4.70:1 Competition Chromoly Gear Kit - 21 spline
2. Full Face Differential Armor
3. Electric Locker Motor Guard x2
4. Electric Locker Control Kit
5. Toyota 8" E-Locker Ring and Pinion
6. Toyota 8" E-Locker Setup Kit
Thanks Marlin Claus!
Going, going, gone
Jack8542
Thanks Marlin Crawler!
Im wishing for a Zip locker, an fj 80 master cylinder and billet alluminum shift nob! Thanks and happy hollidays!   :turtle: :usa:
http://www.marlincrawler.com/wishlist/612
RIP SSg Sizemore, Sgt Mock, Spc McGuness, Pfc Hill, Pfc Marsh, Pfc   Garcia, Pfc Hardge, Ssg Campos. You will be missed greatly by all of C-Rock.
COToy91
http://www.marlincrawler.com/wishlist/611
Heavy Duty Transfer Case Rear Output Seal
Powertank PT10-A Kits
Turtle Shirt
Hoodie
30-Spline Chromoly Front Output Shaft
2- Brake Line Mount & Clip Set
2- Heavy Duty Rear Axle EcoSeal
2- HD Inner Axle Seal, Hilux
ARB Purge Valve Kit
Monster Valves
Mert
#235
Nothing looks better beneath the tree than parts from Marlin.
I'd like it to be a W56C trans for my '91 4x4:  http://www.marlincrawler.com/wishlist/609
Good Luck!
Yota4life
http://www.marlincrawler.com/wishlist/615
(2) Bilstein 5125 series
Heavy Duty Clutch Kit (1,200 lb)
Rear Axle Service Kit, 1979-99
Hoodie
Grizzly Locker 8" 4cyl
Thanks Marlin !
ohioyota
 http://www.marlincrawler.com/wishlist/617
Remove   Products      Wanted   Have   Qty.   Purchase   Total
      $249.00
      $0.00
      3rd Member Housing
      $261.37
MERRY CHRISTMAS!
46&2
First off, thanks for the chance! Awesome giveaway.
My wishlist:
Chromoly 30-Spline Axle Kit (Would like to toss my stock birfs in the toolbox for spares and run something a little tougher)
Powertank PT10-A Kit (Need onboard air!)
Turtle Stickers! (always need more :turtle: stickers!
http://www.marlincrawler.com/wishlist/618
Rockdad
#239
For Christmas I would like a Chromoly 30 spline axle kit and a 8" Grizzly locker for a 4cyl
http://www.marlincrawler.com/wishlist/445
Thanks Santa Mike & Marlin!!! Thanks for making Christmas wishes come true!!!
I have been good this year. Well better than last year.
TacoRunner's 3 & 4 Link Systems
http://www.4wheelunderground.com/
Ready for any trail adventure you throw at it!
