Author Topic: solid axle 87 4runner spring hanger help.  (Read 3327 times)
12 valve
  • Turtle Points: -3
  • Male Posts: 99
  • Member since Mar '10
« on: Aug 14, 2012, 09:42:31 AM »
I'm trying to get my shackle angle right and I put the spring hanger 3/4" in front of the frame tube but my shackles are way off need to come back. Should I move it back to where the hanger is flush? Any help would be great thank you.
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
Re: solid axle 87 4runner spring hanger help.
« Reply #1 on: Aug 14, 2012, 10:56:59 AM »
It's either do that or move your shackle mount forward
12 valve [OP]
  • Turtle Points: -3
  • Male Posts: 99
« Reply #2 on: Aug 14, 2012, 06:19:08 PM »
I put the shackle in the middle of the cab mount I thought that is where it went?
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #3 on: Aug 14, 2012, 06:32:57 PM »
Just depends what you want. Pictures will help with suggestions.
4low4runner
  • Male Posts: 38
  • Member since Jun '11
  • Let it idle and crawl...
« Reply #4 on: Aug 15, 2012, 09:05:04 PM »
Depend what spring you got if u have 5 inch spring move hanger 3/4 forward due to the longer spring but if you have 4 or 3 inch spring move spring hanger flush
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #5 on: Aug 15, 2012, 09:18:10 PM »
I have never moved my spring hanger forward, I have always mounted them flush with the stock front x-member. I have ran both 4 and 5 inch springs.
12 valve [OP]
  • Turtle Points: -3
  • Male Posts: 99
« Reply #6 on: Aug 16, 2012, 08:07:33 AM »
I'm running 5"
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #7 on: Aug 16, 2012, 08:29:28 AM »
The inch of lift in the springs doesnt matter. The length does. Almost all Aftermarket springs dont need the hanger moved forward at all. Its really only RUF that require that, and even then, depending on the angle your prefer, its not needed. Pictures would help alot.
mudaddict
  • Turtle Points: -82
  • Male Posts: 1,829
  • Member since Dec '04
    • All Pro Off Road
« Reply #8 on: Aug 16, 2012, 12:41:22 PM »
Put it flush. Putting the rear shackles hanger in the center is what some companies say to do we recommend putting it as far forward as you in inside the body mount.
As mentioned about the lift size doesn't matter there is only about a 1in difference in length depending on lift height (between most manufactures) but pictures would really help
 :worthless:
98 Taco- Super charged, sas'd, bobbed, locked,taco boxed with 39's
Taco Build http://board.marlincrawler.com/index.php?topic=88901.0
I work At
All Pro Off Road
12 valve [OP]
  • Turtle Points: -3
  • Male Posts: 99
« Reply #9 on: Aug 16, 2012, 03:00:08 PM »
I also dont have my engine in it right now I know that might help a little with the angle.
nisota
  • Male Posts: 608
  • Member since Feb '12
  • Wonsyld/Leard Built Fab
« Reply #10 on: Aug 16, 2012, 04:15:43 PM »
yes that will give you a better idea of where your shackles will sit.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #11 on: Aug 16, 2012, 08:21:41 PM »
Also remember that if you use new springs, they will settle out too.  So, you will gain some angle later on.
4low4runner
  • Male Posts: 38
« Reply #12 on: Aug 19, 2012, 11:24:09 AM »
As far as I know I'm running AP 5 inch spring up front I mounted front hanger flush with 5 inch shackle after 2 week of driving my spring started to settle down and shackle starts to hit body mount I call AP they told me that if I have 5 inch spring front hanger need to move 3/4 forward due to longer spring and I did what I was told remount hanger and everything was perfect.
helipilot77
  • Turtle Points: 1018
  • Male Posts: 1,728
  • Member since Jul '12
  • Seattle, WA
    • My build thread
« Reply #13 on: Sep 04, 2012, 08:08:53 AM »
I also have a 87' 4runner I mounted mine 3/4" forward and have been driving it that way for years. works great!
Last post Dec 05, 2004, 10:05:50 PM
by Fireimp141
Last post Jul 10, 2006, 08:42:16 PM
by Addicted Offroad
Last post Jun 12, 2008, 06:57:59 PM
by turnmeover
Last post Jan 17, 2011, 02:23:08 AM
by Yota Rolla
Last post Mar 09, 2012, 09:57:30 PM
by Rock4Runner
