Author Topic: All Pro Tacoma SAS  (Read 49723 times)
mudaddict
  • Turtle Points: -82
  • Male Posts: 1,829
  • Member since Dec '04
    • All Pro Off Road
All Pro Tacoma SAS
« on: Apr 14, 2012, 09:52:15 PM »
Well  guys im back on here been a while but im back and now rebuilding my Tacoma. Some of you know/remember me some don't but started out as a bone stock 98 taco when i got it in 08 (had a super charger though) went to a 3in lift for about 4 months then stepped up to a 6in w/35's . Got offered a set of 37 krawlers from the bfg rep for way to good of a price and now its time to sas the taco. been building parts and what not for about a year now. Not new to building trucks or solid axles this has been my daily driver for some time and weekend play here and there when needed since i have put my 4runner on the back burner since it is in Washington and i am now in So Cal.
Build stats areas follows.
All Pro 3 link kit with full aluminum lower links
Walker Evans coilovers
Diamond housing made for tacoma brake set up
Marlins 25mm steering arms
hp diff with 5:29's and grizzly locker
front range t-case mount
long fields with hub gears
switching to all pro 3in rear springs with walker evan shocks
sticking with 37's for now
All pro armor all around
Duals after the swap is finished
im doing all the cleanup work at the shop after housing and on weekends. Once frame is clean we are gonna get it in the shop and start getting it set up.
well enough jibber jabber onto the photos
Here is a picture of my last build
Bone stock
fab tech 6in with 35's
37's
Now time for the fun part  :flamer:
And its out  :willynilly:
Only way to move this crap around lol
Clean up time
And drive side outer frame is cleaned up (just out side bottom and back to follow
Pass side start
That's where i ended this was over a 2 day period been raining down here all week have not been able to get much done out side.
A picture of the front coilovers from walker
the HP from marlin with the rear gears
here are the rear walkers been running these with my 5in springs for a while just gonna set my bumps up correctly
More pictures to come i have most the parts at the shop still awaiting the inner axles and the steering from marlin. hoping to have this done very quickly
« Last Edit: May 18, 2012, 12:08:35 PM by mudaddict »
I work At
All Pro Off Road
bigfoot1080
  • Member since Mar '10
Re: 98 sas time
« Reply #1 on: Apr 15, 2012, 08:03:33 AM »
Subscribed! Looks like this is going to be a great build
83 Crawler
  • Turtle Points: -13
  • Male Posts: 2,779
  • Member since Jun '09
Re: 98 sas time
« Reply #2 on: Apr 15, 2012, 08:45:04 AM »
Watching this one for sure!
Yota87Truck
  • Turtle Points: 2
  • Male Posts: 1,175
  • Member since Aug '06
  • Got Moab!
Re: 98 sas time
« Reply #3 on: Apr 15, 2012, 08:15:21 PM »
X2, Subscribed!
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
Re: All Pro 98 sas time
« Reply #4 on: Apr 16, 2012, 11:39:04 PM »
No new pictures today just worked on the bottom and inside of the frame today and cut out sheet metal to fit the steering box on the driver side. BUT Talked to Brian at front range today custom length inner axles are done and shipped out :banana: heard from Brendan the bearings im waiting on for the 25mm kit should be in tomorrow hopefully and here by end of week its all coming together just in time!Hoping to hear from summit machine on the lower links tomorrow. frame should be done tomorrow after a bit more grinding and getting ready to start mocking up steering, braces, frame supports and brackets.
I work At
All Pro Off Road
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #5 on: Apr 17, 2012, 09:50:47 PM »
well worked on the frame for another day after work. Frame is all done oil is drained gonna swap out the pan tomorrow and hopefully into the shop Thursday and get the link and brackets all set up and get it ready it ready to go so i can button it up sat at least get it back on the ground get some measurements for the drive shaft and get the rear diff out and get the new gears in. make it 4wd again.
I work At
All Pro Off Road
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
« Reply #6 on: Apr 17, 2012, 11:21:15 PM »
Want to see this thing done!
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #7 on: Apr 18, 2012, 09:17:27 AM »
Oh it will be done my hope/plan is to get it back on tires by sat. but just got bad news lower links are still over a week out  :sad2: but the wait will be well worth it i will just run the basic lowers until then.
I work At
All Pro Off Road
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #8 on: Apr 18, 2012, 10:40:50 PM »
Found a light in the shop today so we got alot more done.
rear drive line removed.
putting the new pick up in
Oil pan is on i guess i didnt get a picture of it lol ooops.
Next we put the new front range crossmember in
Old one out
New in
When we get it in the shop its gonna be removed again do some final welding and get it all painted.
I work At
All Pro Off Road
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #9 on: Apr 19, 2012, 09:50:42 PM »
Got a pretty package from front range today. Hoping to see a good one from marlin tomorrow. Nothing got done today due class.
I work At
All Pro Off Road
greg_k113
  • Turtle Points: -49
  • Male Posts: 224
  • Member since Feb '10
« Reply #10 on: Apr 20, 2012, 05:40:49 PM »
Subscribed!
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #11 on: Apr 21, 2012, 12:21:47 PM »
getting the axle all cleaned up so we can start mocking it up next week. trying to finish grinding off the old crossmemeber for the trans/t-case but its very warm and my hands are tingling from grinding already! but brain is   :whip: saying get back to work. once the inside of the frame is clean no more grinding for the most part WOO!.
I work At
All Pro Off Road
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #12 on: Apr 21, 2012, 03:45:39 PM »
Lots of grinding in this warm weather but well worth it. Boss stopped by to check it out and pick up some parts. Told him where i was and where it was gonna be come monday morning and he said alright monday we can pull it in.  :bananasplit: . Frame is done. There will be a few pictures taken since we have to redo the instructions for this kit since we have changed the length of the links the mounts and some other small parts.
 :beerchug:
Oh and figured id give you guys a shot of the fun thats under the hood!  :drooling:
I work At
All Pro Off Road
- Sales Employee -
freds40
  • Turtle Points: 293
  • Male Posts: 2,331
  • Member since Dec '02
« Reply #13 on: Apr 21, 2012, 09:54:41 PM »
Nice build Kurtis. I was curious what you were working on.
"between projects"
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #14 on: Apr 22, 2012, 02:20:32 PM »
Thanks Brendan. Oh tell your shipping guys thanks for the packaging on my diff that thing was like a present to open with all the bubble wrap.
Came back to the shop today did more prep work so we can get this thing installed quickly. Diff is put into the axle and painted hubs,spindles and knuckles are cleaned up for the most part gotta bring em next door and have them go through the parts washer.
I work At
All Pro Off Road
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #15 on: Apr 23, 2012, 08:05:17 PM »
Well figured out on sunday i needed a new brass bushing for one of my spindles luckily my other stuff didnt ship thursday from marlin got one of thos put in. Should have all my 25mm stuff tomorrow and that will finish all my axle stuff i need besides my hd seals they are out for a couple weeks still. Truck didnt make it into the shop today were behind in production so i had the guys building sliders and other stuff all day hopefully tomorrow it can come into the shop but im thinking it will not be done in time for the Tinbenders jam this weekend like i had planned. so onto figuring out what truck i can use from the shop lol. choices are a sas'd taco with duals or a built 83. just trying to figure out which one needs less work to finish taco just needs a few minor adjustments only been out 1 time since the sas
I work At
All Pro Off Road
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #16 on: Apr 23, 2012, 08:50:53 PM »
Damn Mud, that is going to be one Taco to recon with. I'm Locked in on this one.
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #17 on: Apr 23, 2012, 09:01:59 PM »
Thanks im stoked on this build but its going to slow i want it done lol.
Here is a picture of the tacoma we built at the shop the only difference is the axles are currie 9's . This is my ride at Tin Benders. If anyone is gonna be there done hesitate to stop by and say hi. if you see us.
« Last Edit: Apr 24, 2012, 12:58:54 PM by mudaddict »
I work At
All Pro Off Road
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #18 on: Apr 23, 2012, 09:02:33 PM »
Oh and for that i gave ya a turtle point lol!
I work At
All Pro Off Road
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #19 on: Apr 23, 2012, 09:08:57 PM »
You rock, I can now LIVE with myself knowing i got a positive turtle point :woohoo:
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #20 on: Apr 23, 2012, 10:04:46 PM »
:rofl:
I work At
All Pro Off Road
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #21 on: Apr 24, 2012, 05:42:39 AM »
:beerchug: :cool:
91 ex-cab
  • Turtle Points: -171
  • Male Posts: 1,660
  • Honey Badger
« Reply #22 on: Apr 24, 2012, 11:49:00 AM »
 :smokin:
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #23 on: Apr 24, 2012, 03:16:50 PM »
Thank you marlin!!! :bowdown:
This just got put on my desk!
I work At
All Pro Off Road
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #24 on: May 16, 2012, 04:41:06 PM »
well its been way to long since i have worked on this. We have had the shop full of other trucks getting some proto typing of some new tacoma stuff done but now that its all done the trucks are off to the Over Land Expo for the weekend its time to bring the Taco into the shop. Here are some as we were moving it around in the shop.
Getting it all hooked up i gotta stand back and watch i love my job.
It started to slip as we were turning it   :yikes:
Rearranged it
I work At
All Pro Off Road
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #25 on: May 16, 2012, 04:46:15 PM »
In she goes
All in now
Goin Up - It was a whole shop affair lol.
Shes up and ready to get some goodies.
So i went shopping down the isles lol.
I work At
All Pro Off Road
Dingman.
  • Male Posts: 3,448
« Reply #26 on: May 16, 2012, 04:53:04 PM »
SICK!!!
I wish the shop at my work was like that  :yupyup:
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #27 on: May 16, 2012, 06:59:30 PM »
haha nothing better then going shopping at your own work. reminds me of an episode of Overhaulin LOL
dropzone
  • Turtle Points: 7
  • Member since Feb '07
  • Drive a 1st Gen
« Reply #28 on: May 16, 2012, 07:14:35 PM »
that's just what I was thinking
81 Toyota Trekker 221:1
mudaddict [OP]
  • Male Posts: 1,829
    • All Pro Off Road
« Reply #29 on: May 16, 2012, 07:52:26 PM »
It did make my day loading everything up into the cart. I had alot of stuff pulled to the side just none of the brackets or any of that.
I work At
All Pro Off Road
Last post Mar 03, 2004, 03:04:59 PM
by conflict
Last post Dec 31, 2004, 09:24:25 AM
by PinkToyota
Last post Sep 07, 2010, 11:51:21 AM
by SFD4x4
Last post Sep 29, 2010, 01:42:19 PM
by toyotaboy
Last post Oct 14, 2010, 09:06:27 AM
by 3.4Runner
