Author Topic: 86 1 ton runner 4wu 3 link  (Read 26076 times)
91 ex-cab
  • Turtle Points: -171
  • Male Posts: 1,660
  • Member since Mar '10
  • Honey Badger
« on: Sep 12, 2013, 11:49:39 AM »
 Here's my new project/rig 86 4 runner.
Parts list of what I already have so you get where were going with this.
Dana 60s Front and rear
60 front: arb,5.38,35 outers, Yukon chromolly hubs
60 rear: welded,5.38,chromolly Yukon 35 spline, disc brake
Dual cases: tg 23 spline adapter, mc 23 spline 4.70, longfield output
Motor is a rebuilt 22re all stock minus metal guides and lce header
4 wheel underground front 3 link  :smokin:and right now I have 16" radflo remote resivoir coilovers
And 4" fox air bumps. Here's where I'm at cleaned the frame up and got the body back on.
« Last Edit: Sep 16, 2013, 05:35:21 PM by 91 ex-cab »
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
Re: 86 1 ton runner
« Reply #1 on: Sep 12, 2013, 03:07:42 PM »
I'll be watching this one! Things gonna be a beast! :beerchug:
x250f23x
  • Male Posts: 172
  • Member since Aug '12
  • 8D 8] 8| 8\ 8[
Re: 86 1 ton runner
« Reply #2 on: Sep 12, 2013, 06:02:14 PM »
 :biggthumpup: Watching!
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
Re: 86 1 ton runner
« Reply #3 on: Sep 15, 2013, 12:09:14 PM »
Got a little bit of time to play with the runner this weekend, finished the frame and got the axles moved under the truck and got my lower links on time to squeeze the upper link in there.
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,896
  • Member since Jun '07
Re: 86 1 ton runner
« Reply #4 on: Sep 15, 2013, 07:47:26 PM »
good start buddy keep it up
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
Re: 86 1 ton runner
« Reply #5 on: Sep 15, 2013, 08:31:54 PM »
nice!
You'll never take me alive
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
Re: 86 1 ton runner
« Reply #6 on: Sep 16, 2013, 01:50:04 PM »
Thanks guys  :beerchug:  So got a little bit more done early this morning before school, I have both lowers,upper, and panhard all lightly tacked in basicaly there final position and i also got the steering in. I need to cycle it and make sure it all clears and make my final adjustments on everything then im gonna stuff the axle as high as i can get it and get the air bumps in there.
zidaro
  • Turtle Points: 480
  • Male Posts: 526
  • Member since Oct '02
  • Mo Chi Chu!
Re: 86 1 ton runner 4wu 3 link
« Reply #7 on: Sep 16, 2013, 06:20:38 PM »
sick build list and moving right along.
watching
'87runner.
'10 Crewmax
'05 CRF450x
http://www.4wheelunderground.com/
TONIK- Mammoth Lakes
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #8 on: Sep 17, 2013, 04:02:30 AM »
Great progress :beerchug: Is it just me or is your tie rod bent.....?
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #9 on: Sep 17, 2013, 02:10:20 PM »
watching
Your build is my main inspiration right now your runner is  :drooling:
It's not just you I made it originally form 1.5" need a new piece of tube 1.75"
zidaro
  • Male Posts: 526
  • Mo Chi Chu!
« Reply #10 on: Sep 17, 2013, 02:51:55 PM »
hah, thanks bud!
'87runner.
'10 Crewmax
'05 CRF450x
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #11 on: Sep 17, 2013, 09:39:57 PM »
So as Brian commented to me earlier i needed to move my panhard bracket to make the bump can land on the axle pad and also to make my draglink and panhard on on the same plane as eachother to avoid bumpsteer im guessing? So heres the final panhard position I think, everything seems to clear and I moved my draglink to the top of my steering arm to make it match the panhard. Off to play with the air bumps, almost positive the 4" air bumps I have are not going to work and im gonna have to find some 2".
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
« Reply #12 on: Sep 17, 2013, 11:04:51 PM »
4" bumps are crazy long. Remember bump stops are for the Oh Sh!#! moments. Your shocks are what should soak up everything else.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #13 on: Sep 18, 2013, 12:53:32 AM »
 They will only fit if I switch to these fox air bump cans.
kdub0013
  • Turtle Points: 2
  • Male Posts: 622
  • Member since Apr '11
  • no mommies wey
« Reply #14 on: Sep 18, 2013, 08:07:49 AM »
Looks good. I didn't realize you got rid of the extra cab, why the change?
zidaro
  • Male Posts: 526
  • Mo Chi Chu!
« Reply #15 on: Sep 18, 2013, 09:35:12 AM »
I'll tell you what my experience is placing the bumps.  and you can look at my build to see what i mean.
I was going for max uptravel so that has some bearing on location, but my bump cans were at the VERY bottom of the panhard brkt. tabs and i even notched out the tabs for the bump to fit against the stop ring.
The bumpcan then was up high into the shock tower and i had to notch out the tower to get the can to fit fluch against the frame (level).
What im trying to say is, if my bumpstop body was any taller it would not have fit with my towers.  there is not alot of room in there for extra stuff.
Just make sure your thinking bout all the elements before you commit to using the 4"bump, it might work or it might create alot of work for you.  Just like me REALLY wanting to use 2.5 Coils, thank the Gods i did not and followed Brians advice to stick with 2.0x16 cuz there is not room for them, even with my axle width, for 2.5x16coils and tires in a runner frame wheelwell.
'87runner.
'10 Crewmax
'05 CRF450x
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #16 on: Sep 18, 2013, 11:47:08 AM »
Im going to go ahead and just get some 2" air bumps thanks for the help guys  :beerchug:
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #17 on: Sep 18, 2013, 07:48:04 PM »
This things gonna be wide.
zidaro
  • Male Posts: 526
  • Mo Chi Chu!
« Reply #18 on: Sep 18, 2013, 10:23:56 PM »
you mean STABLE
'87runner.
'10 Crewmax
'05 CRF450x
x250f23x
  • Male Posts: 172
  • 8D 8] 8| 8\ 8[
« Reply #19 on: Sep 24, 2013, 10:28:49 PM »
 Most stuff you buy can be modified or tweaked to gain a little more performance. Because Brian has built everything so damn tight (the most performance you can get out of this kit), anything you do to improve this kit will only bite you in the ass. Following Brian's instruction will not only give you the most performance, but will shorten the build time.
 A piece of mind about buying 4WU is that you are buying a heavily engineered product that gives you the the max you seek. Kinda like buying a Ferrari. Isn't much you can do to improve the performance you know? Thats right I said it! When it comes to linked suspension for the Toyota's, 4WU is top of the food chain, alpha status.
« Last Edit: Sep 25, 2013, 11:31:43 AM by x250f23x »
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #20 on: Oct 02, 2013, 02:42:28 PM »
So Ive got nothing on trades for 2" air bumps and im on a tight budget here. Im going to run the 4" air bumps(my coilovers will absolutely have no problems with clearing them) And I can get these spacers in 1" incriments to reduce them to 2" travel http://www.polyperformance.com/shop/Fox-2.0-Air-Bump-Stop-Shaft-Spacer-p-17528.html#.UkyQuuAoxUQ  I dont see why this wont fit the bill  :dunno:  Only progress ive made is got my tranny and dual cases all reassembeled and painted with my crossmeber bolted up ready to go, started playing around with the rear end a little bit I think this is what im settled on my 39.5 iroks sit right in the front of the wheel well and im gonna trim out the back to fit  :flamer:
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #21 on: Oct 06, 2013, 07:59:43 PM »
Took it back to a frame for welding and painting everything then i will assemble it drivetrain and all before putting the body back on. overall pick of the link setup.
kdub0013
  • Turtle Points: 2
  • Male Posts: 622
  • no mommies wey
« Reply #22 on: Oct 06, 2013, 10:19:33 PM »
Right on dude looks good.
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
« Reply #23 on: Oct 06, 2013, 11:13:54 PM »
I wish i had all of those parts!!!!   Cant wait to see it done!
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #24 on: Oct 07, 2013, 12:58:23 PM »
Thanks guys ive been collecting parts for about 2 years now for this thing I cant wait to get it rolling.
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #25 on: Oct 14, 2013, 02:20:49 PM »
 Got this thing mostly back together still need to put my lce header on and run exhasut back from there, brakelines all around with linelock and wilwood proportioning valve in cab, Coilover hoops for my 16" radflo coilovers on the front and bilstiens with hoops on the oustside of the frame for the rear. I rebuilt my 22re with an engbldr rebuild all stock specs ive got about 5,000 on it now and its running amazing just need to clean the mud off it.
83oneton
  • Member since Nov '10
« Reply #26 on: Oct 14, 2013, 08:21:23 PM »
looks sweat. you happy with 4wu brackets? they look beef
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
« Reply #27 on: Oct 14, 2013, 10:14:24 PM »
subscribed
kdub0013
  • Turtle Points: 2
  • Male Posts: 622
  • no mommies wey
« Reply #28 on: Oct 14, 2013, 10:32:12 PM »
Heck you will be on the trail again in no time.  :beerchug:
John Doe
  • Turtle Points: 469
  • Male Posts: 1,587
  • Member since Jun '05
    • Bored In Iraq.
« Reply #29 on: Oct 14, 2013, 10:39:26 PM »
Progress looks Great!
So you are outboarding your rear shocks? How wide is your rear axle?
Last post Oct 09, 2008, 10:26:40 PM
by Hyena
Last post May 24, 2010, 10:51:44 PM
by joeycool00
Last post Oct 29, 2014, 09:40:57 AM
by deans87
Last post Jun 16, 2021, 02:43:13 PM
by Ritchie
Last post Aug 12, 2023, 04:24:49 PM
by lone walker
