Standard S.A.S on Red Solo Truck
Started by Red Solo Truck, April 15, 2012, 10:16:07 PM
Red Solo Truck
I'm Solid axle swapping my 1990 Toyota Pu. I have high steer and everthing on the way. I just got my axle today its out of a 1979 Toyota. I'm putting the axle rebuild kit in tommarow after work.
locked 4x4
looks like a clean truck.  subscribed.  you going to gusset and truss the axle before you put it in?
Red Solo Truck
No im planing on doing that a little later down the road. I need to gett some more $ saved up, but it will for sure be getting done.
ToyotaObsession
I love the user name lol. I love that body style of truck. I love them even more when lifted with a SAS! Can't wait to see how it turns out.
Wait... What?
greg_k113
Zs Confederate Toy
Gonna be a sweet build. Clean truck man
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
Red Solo Truck
-So i have got my axle apart and i have one side torn down. Last night i left the axle with the pinion shaft facing down and it leaked out gear oil. I'm guessing there is a seal in the third member that's bad any ideas????
88yota
I guess I'll subscribe...even though I'm jelous haha  :usa:
zebracrawler
mm lets get that axle done then throw this together gurr
sas 85 2wd dual cases locked rear 35s
http://board.marlincrawler.com/index.php?topic=81775.0
OldGold3VZE
I would have kept it IFS and built the 1st gen!
My 1980 Long Bed build thread
http://board.marlincrawler.com/index.php?topic=84562.0
Truggy build thread
http://board.marlincrawler.com/index.php?topic=89844.0
Rastafari Livity!  Ital = Vital!
Red Solo Truck
Got the axle all apart, now..... All of it looks good other then I need a new third member with 4:10 anyone have an old one laying around?
Dingman.
where you located?  buddy has a 4.10
Red Solo Truck
91 ex-cab
Gonna be one of the cleanest sas 3rd gens rolling around town. Subscribed, lets get this thing rolling.
Red Solo Truck
So I pulled my rear third member tonight found out 4:56 in my rear axle and my new front axle has 309...... I have no idea what I'm gunna do now..... I don't have the money to regear.  Any ideas??????
83 Crawler
Quote from: Red Solo Truck on April 16, 2012, 09:51:27 PM
poor first gens, always getting raped for all there good parts!
OldGold3VZE
309?  Might want to check that again.  I don't recall Toyota ever offering 309 gearing.  If that 1st gen is a 79 or 80 then it should have 4.375 gearing.  If I were you, I would start looking for another 4.56.  Or, a set of v-6 4.88 rears.
Truggy build thread
ninja turtle
Quote from: OldGold3VZE on April 20, 2012, 07:19:05 AM
typo, its 3.9 which came in some 81's.
91 ex-cab
I'll have to check the gearing again for him,I have to be wrong its probably not 3.90 if that only came in 81.
And I think we found a 4.10 v6 rear so all we will need is a 4.10 4cyl front hopefully  :crossed:
83 Crawler
it was a 4speed truck then its 4.37 gears
86yoter
86' runner nothing special
Red Solo Truck
I ended up getting a temperay 3rd member with 4.10s............its comeing togther very slowly!!
I was wondering if my v6 roters and calipers bolt up to the spindel????????
Nimyad
Calipers yes rotors no. Also depends on what spindle you have. Early spindles has a different bolt pattern then the later ones.
Red Solo Truck
so what would you do use the stock rotors and put my calipers ???
mudaddict
you use fj front rotors i am blanking on the years to get them off of im sure someone will chime in if not when i get in tomorrow i will post up what year the rotors come off of.
You use the fj rotors and then your stock calipers.
nimyad is correct early spindles are different
In late 1981 Toyota changed the design of the front knuckle and rotor. Early and late rotors are different and not interchangeable.  In order to get you the correct part you look at the face of your existing rotor . The early rotors (1979 - 1981) had only the 6 holes for the wheel studs. Axles from 1982 - 1985 have 8 hole rotors, six for wheel studs along with two additional smaller holes.
You said the axle was out of a 79 i recommend if you can find a set of later spindles it will help out alot not saying you cant use the ones you have now but with the later ones you can use a vented rotor that is bigger allowing for more braking force
I work At
All Pro Off Road
Red Solo Truck
Makein my own eliminator plates!
Axle is bassicly done!
Zs Confederate Toy
I like the look of the red and black on that.
ZACH
87 Rock Rat X
Trail Junky
