Standard S.A.S on Red Solo Truck
Started by Red Solo Truck, April 15, 2012, 10:16:07 PM
88Rokyoat
I've never had issue with spacers, I've had them on a lot of different rigs. Make sure you keep an eye on the knuckle studs too. Usually painted arms and cone washers don't mix well...
Nice build and clean truck.
stupid people shouldn't have kids.
86yoter
 WOW i haven't had a problem yet  :crossed: but i will have to check everything seeing this happen
86' runner nothing special
CrazyYota
Quote from: Tankard on May 14, 2012, 07:57:34 AM
Whoa! :scared: That's no good, glad you didn't get injured.
In the past I have used fingernail polish for all my DD wheel spacers with zero issues. Impacting the manure out of them is more than likely where things went wrong. The torque specs are under 85 ft. lbs. (check a manual for the correct torque numbers). If you use a torque wrench it will allow for an even torque on all those itty-bitty studs.
Over torquing a stud usually stretches it and makes it untrustworthy. I recommend new studs with proper torque specs and lock tight and you should be good  :thumbs:
I DD my junk with wheel spacers and have never had problems with them. They have been on my truck over two years. I think your problem was you used an impact gun and did not torque them evenly.
toyotech
+1 on not torquing them down correctly.  i have had mine on for a while now and tons of wheeling trips. all i did was torque them down to 80ft lbs.
Holy crap that's crazy! Great looking truck and cool build, sucks on the wheel spacer issue!
Definitely make sure to not only torque the wheel spacers, but all four wheels properly. Torque the nuts at the wheel spacer to 85 ft-lbs, and torque your steel wheels to 75 ft-lbs (for those running aluminum wheels, I recommend 85 ft-lbs).
I also highly recommend double checking the torque on everything again after the first few trips. After you've double checked it two or three times I'd call it good. Repeat this process whenever you remove one or the other (wheels or wheel spacers).
In my opinion, never use thread lock on your wheel spacers and/or wheel lug nuts. This is incorrect, unsafe, and Toyota does not recommend to do this. I say it is unsafe, especially in the case of the wheel spacer lug nuts, because the nuts will settle into the wheel spacer and your steel wheel over time and you'll need to retorque them as mentioned above. If you use thread lock, then the lug will be locked to the stud, and as the nut wears into the softer aluminum wheel spacer, you won't be able to close the gap by "checking the torque" since the loctite will give your torque wrench an extremely high artificial reading.
It's not something I wanna mess with, for safety sake of myself and others on the road, so I make sure this is done right on my rig.
:twocents:
mudaddict
Truck looks really good i like the low stance and that thing is freaking clean!! i remember those days  :yupyup:.
I agree with Big mike. Also i don't recommend using a impact on the studs to snug yes torque no. I have ran wheel spacers on multiple trucks and have actually sold plenty of sets and never actually seen that happen before. I know you are looking into the ifs hub swab that is a great way also if you are looking to keep the spacers and want more thread engagement i know it is very little for the amount of engagement on the spacers to hub there are lug nuts that go into the spacer another 1/4 inch to allow more engagement.
I work At
All Pro Off Road
86yoter
looks better on its rubbers. did you get those kinks worked out
Red Solo Truck
Quote from: 86yoter on May 17, 2012, 07:55:49 PM
Yea still have some small stuff to do befor its good.
86yoter
Red Solo Truck
i really need to get a front drive line i I'm gunna do a square tube intell i can get the money together to have a balanced one.
86yoter
ya i didnt want to run the square tube but until i have my gear driven case installed i don't want to waste the money. i got a square driveline from someone that i picked parts up from for like $10 i just have to cut it down it is for a truck with duals.  but i am installing the 529 and i want to test it out so i guess the square guy is going on :bling: :thumbsup:
Red Solo Truck
Finally makein some progress on a driveline...... I decided to just go with a square tube for now.
JANDO11
that thing is sooooo clean.... you gotta get some body armor on there to keep it looking fresh...
my build http://board.marlincrawler.com/index.php?topic=88876.0
COFFIN CRAWLERZ
DFD
1988 turbo xtra cab, 3RZ, links
1985 pickup, 37 mtr
1985 4runner SR5, KINGS, LINKS, BUMPS, 40s
Red Solo Truck
Quote from: jeep slayer on May 30, 2012, 01:23:14 PM
Haha Ya I no I'm workin on it.
JANDO11
word man sick build keep up the good work
COFFIN CRAWLERZ
DFD
1985 pickup, 37 mtr
86yoter
nice get it roll n'.  i am at body armer too but my friends are trying to get me to go anyway.  but i don't want to slip and snag a rock the wrong way.
Red Solo Truck
Quote from: 86yoter on May 31, 2012, 09:39:30 AM
There are other things I should get done be for buddy armor but i don't wanna do something dumb wheelin around and mess up the body
Red Solo Truck
#108
Just a little bit of grinding and welding left to do!
86yoter
Red Solo Truck
 Ok I'm at the end of my ropes with this, the hardest part on doing my sas was moveing the steering box forward. I never had a signal leak from it befor I touched it no it leaks it's not any of the lines it has to be comeing from the splines were the stearing shaft gose into it..... Any ideas?
JANDO11
same thing happend  to me... my box just randomly started leaking after i moved it forward... i found a bad o ring soooo replace this one
COFFIN CRAWLERZ
DFD
1985 pickup, 37 mtr
Red Solo Truck
So we have a topical 3.0 blew the head gasket.
zebracrawler
sas 85 2wd dual cases locked rear 35s
http://board.marlincrawler.com/index.php?topic=81775.0
suprawheeler
I have 3" spacers front and rear and havent had any issues with them.
85 4Runner powered by 7mge,W56 trans,dual t-case, 5.29 gears and Toyota E-locker front and rear, Longfield 30 spline front axles and chromoly hub gears, Front Range full float rear axles, Tundra front brakes, v6 calipers and FJ60 rotors on rear, t-case e-brk, 6shooter knuckles with trunnion bearing eliminator kit, Stage 8 locking spindle nut, 41x14.50x16 Swamper Iroks.
