85 Ext Cab Red Truck Build
Started by boomtacoma01, April 03, 2012, 09:38:23 AM
J_Cole92
Looking good! i cant wait to put tons under my 84 xtra cab  :smokin:
92 4Runner built on Toyota axles
84 Xtra Cab stock Daily Driver
55 Willy's Pickup Cab
Can't find it grind it
4runner build: http://board.marlincrawler.com/index.php?topic=96221.0
boomtacoma01
#241
Thanks man. It has been fun so far. Definitely more work than expected.
After almost 5 months I have a roller again. I need to finish plumbing my rear brake lines and address a few things on the front like removing a leaf or two,  add some brake fluid and bleed them out.
IG @boomtacoma01
boomtacoma01
Drove the truck for the first time in a long while. Just need to address a few of the finishing details. Other than those, I'm just about ready to wheel.
Hydro assist finished up. Just needs a little paint
IG @boomtacoma01
1985CRAWLER
looks good man! those front hubs stick out pretty far it seems?
why did you change the hydro assist bracket from the housing to the axle tube, also did you fab up that tube bracket?
daniresch
Gah! i keep thinking i need to go 60s and you're not helping.
making solid progress on this truck, i'll be watching!
redneckcustoms13
Coming from someone with a runner on 40s and tons and a pickup on 38s and toyota axles. Toyota ftw, tons have too low of clearance for anything less than 40s, and even then the toyota on 38s has more...
01 double cab hunting truck
06 tacoma street truck
boomtacoma01
I changed the hydro assist due to not trusting the welds between the mild steel and cast steel of the diff. The bracket I found is from undercover fab. It worked perfectly.
I realize the 40's and tons have a little less clearance than the toy axles. It doesn't bother me though. It will offset the cost of the ring and pinions I kept blowing up in the toy axles.
IG @boomtacoma01
J_Cole92
Quote from: boomtacoma01 on November 03, 2015, 06:03:50 PM
I defiantly agree with you there. 5.29s get smoked like cigarettes  :smokin: haha i only blew one set up last season, a buddy of mine  went threw 3 third members last Memorial Day on the rubicon. All 5.29s on 37s
boomtacoma01
#248
I been finishing up some odds and ends while waiting on some parts to show up.
I added a piece of 1/4" plate in the rear of the front spring hanger and got it burned in to add a little more strength to that area. It made it a ton easier to get a good weld. After that I painted everything up in that area.
Got my trimmed up grille installed for the first time in almost 3 years.
Started on my rear traction bar cross member.  The Chevy 63s are prone to tons of axle wrap. It was bad before and I assume it will be worse now with the increased unsprung weight of the 14b and 40s.
Waiting on my sliders,traction bar parts and some one ton brake parts to show up.
IG @boomtacoma01
boomtacoma01
Finally installed my 1 ton MC. I ended up replacing the rear OEM brake line with a -3 SS line to remedy the leaking one.
Added some fluid and got them initially bled. I just have to tuck all the lines away. Then on to a test drive.
IG @boomtacoma01
boomtacoma01
Started mocking up my sliders tonight. I found them online from a shop called Slag Factory. They are 67" long with a kickout. The main tube is 2x3  with 1.75 outers and 2x2 legs. Scab plates and gussets were also included. They seem to be built well. I'm leaving the 2x3 tubes out a bit in order to be able to tie some tube into. Time to bust out the chop saw tomorrow to get the other legs cut and burned in.
Scab plate and gusset
The rug will be removed before  I burn my rig and garage down
IG @boomtacoma01
Peterbuilt84
Diggin' your build. About to swap tons into my new truck soon. Definitely a help to seeing what you've done. Really like that shaved 14 bolt. Keep the progress up, looks good!
RATCATCHER38
Such a cool rig you've got mate. The sliders look great. I tried to look them up on their website but couldn't find them... Might have to call them and see what the go is.
boomtacoma01
Thanks man. I don't know if they have an online store. They do sell them on eBay though. That where I found them.
IG @boomtacoma01
boomtacoma01
After running out of wire and gas for the welder I finally got my sliders burned in.
IG @boomtacoma01
J_Cole92
Sliders look solid as hell. Those front hubs stick out quite a bit it looks like. Is that just because of your rims?
redneckcustoms13
Yep, if you don't run around 10" wide wheel on a d60 the hub sticks out past the lip.
boomtacoma01
Tha BS of the dodge wheels are 5.5-6". That is why the front hub sticks out like it does. I was trying to keep my track width under 80" and it came out at 79".
IG @boomtacoma01
boomtacoma01
Got the red truck out of the garage in preparation for Wheelers 4 Wishes.
Front winch mount
I will be loading up in the morning to head out for the day.
IG @boomtacoma01
boomtacoma01
I've been working on a few things over the past week.
Addressed my pass side spring perch and got it all torqued down. I had to trim the inner 5/8 bolts to fit correctly to keep the spring plate on evenly.
I painted the front calipers, high steer arms, and steering linkage. I should have painted all this before in installed it the first time.
Just waiting on the paint to dry. Should be back in this week.
I installed a new fuel pump mount on the back of the cab just slightly lower than the fuel cell.
Finished up my anti wrap bar
IG @boomtacoma01
jangelfire
Goose
FYI: I own Slag Factory and hand built those rock sliders.  :biggthumpup:
Glad you like them. They're definitely beefy and look great on your rig. Good buildup too!
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
boomtacoma01
Thanks. The sliders will be getting a work out in mid March. We shall see how they hold up. They fit up perfectly and went together well !!
IG @boomtacoma01
boomtacoma01
Truck is ready to wheel as of this afternoon. I made a few hot laps through the neighborhood.
Rock lights are done.
I need to get my spare DS shortened since the slip yoke on my current one is beat up pretty badly and I don't believe it will hold up for too much longer.
IG @boomtacoma01
xhootiehoox
Beautiful that's a dream truck man nice build
The secret is more beer and better music 🇺🇸
boomtacoma01
Thanks man.
Spent the last few days removing all of the EGR equipment off of the truck. I have had the block off plates for a while and stumbled into this because I couldn't pull my FPR because the EGR piping was in the way. I cleaned up some vacuum lines and removed the charcoal canister since it is not being used anymore.
Spent the rest of the night packing for my wheeling trip next Thursday.
IG @boomtacoma01
xhootiehoox
Quote from: boomtacoma01 on March 12, 2016, 07:59:16 PM
Thanks man.
how is that no smog thing working out for u lucky
xhootiehoox
Quote from: boomtacoma01 on November 28, 2015, 10:48:52 AM
we got an online store just don't have the sliders up yet I'll talk to goose a gain today about it lol  :hammerhead:
Thanks man.
when you removed charcoal canister, what did you do with vent line from tank
boomtacoma01
The vent line wasn't in use. I have a fuel cell with its own vent and rollover valve.
IG @boomtacoma01
