MIG for pretty stuff. FLUX for super heavy stuff or stuff you have to weld out side in the wind.
dual shield is where its at! flux cored wire with gas. of course in side only but an amazing looking weld. esp on stainless! very tasty haha
I had no idea you could run dual shielding. Very interesting I'll have to try that.As for Stainless, what are you referring to when you say esp? Are you talkin' a tri mix.
I'd have to get the particulars from my dad but I believe the spray transfer style of mig welding does better than standard mig welding for thicker material. Not sure if spray transfer is possible with flux core or flux core with cover gas. It might be something to look into when more penetration is desired in thicker materials. I'll ask him about this subject the next time I get a chance. I also think that some welders require the polarity to be changed before swapping between the two methods flux and mig that is.
Penetration is not on how hot it is, its all about prep! Bevels, open roots, etc. Spray is hot and fast. Its for solid wire only and only in the flat position, vertical down and thats about it. Plus it takes a ton of power to do it, your 220 wirefeed at home wont do it.
So with the right prep you can get the same amount of penetration out of mig as to flux core? Flux core is just better for easier prep or if you are welding outdoors(wind)?
Whenever possible you should use shielding gas to keep the weld shielded from impurity as it cools thus giving the weld strength.Flux core is used for windy welding applications where the normal shielding gas would be blown away.Typically in the welding world flux core has a bad name, if wind is the issue most guys will use SMAW (stick welding).If you want to run MIG, you will have the best results with shielding gas-NOT Flux core IMO -and I have been welding and teaching welding for some time.
I would innershield has a bad name, dualshield is great and used a lot.
Started by kyle_22r « 1 2 3 4 5 » General 4WD Discussion
Started by CTENG in KS General 4WD Discussion
Started by bigcountry « 1 2 » Welding Tech
