flux core?
Started by kyle_22r, April 17, 2005, 04:14:10 PM
CTENG in KS
Weeeeeeeeee.....keep going!
burnyota
Flux core is a great invention. You get deeper penetration than you would with mig, and does not require a gas bottle, cause the flux is in the wire. more slag, more amps and voltage, but deeper penetration and you can use it in windy settings(garage,driveway, etc). mig is harder to set up and learn compared to running flux core. From my school flux lab, we use about a 2in wire stickout and a drag technique with no oscillation of the gun. A drag technique will always give you deeper penetration. my :twocents:
85 p/u, marlin#208, built 22R on propane, old school longs, 5.29's / detroits, bobbed, chopped, and flopped
CTENG in KS
Quote from: burnyota on May 12, 2005, 07:04:10 AM
2in wire stickout . my :twocents:
Thats hard core technical term right there!   :gap:
rockhound
Show me the drag technique. No ocillation? Is that the same as spiraling? I've been teaching myself to weld out of necessity. So this is educational.
I have a HF special too. It's a Chicago Electric Dual Mig 131. I use the .030 flux core that came with it.
I start with about 1/4 wire showing at the tip and move slowly while making a small circular  motion with the tip. With thte setting at max 2, about a 4 wire speed it seems to leave a nice bead and if I go slow enough, seems to get good penetration.
I just had to re-mount my steering box, and it took a couple times welding the frame inserts to eliminate the seam left after grinding smooth at the frame.
How you 'sposed to know what your limitations are, till you exceed them.
www.RunandPlayMotorsports.com
Weldo
Oscillation simply means side to side movement, usually prefered over a circular movement like you described.  Whether you have to oscillate or "WEAVE" or not depends on the joint.  On Tee joints (fillets) an oscillation may be helpful to wash the molten metal onto the vertical piece.  An oscillation can also give you a wide, flat bead instead of a narrow, high bead.
Drag technique simply means tilting the gun in the direction of travel.  That is, the wire coming out of the gun is pointed back to the weld you are currently making, as opposed to the "PUSH" technique where the wire is pointed ahead or away from the weld you are currently making.  Dragging typically gives higher beads and deeper penetration.  Pushing gives flatter beads and less penetration, making it good for sheet metal.
Longer wire stick outs are used with fluxcore to help pre heat the slag and increase its effectiveness, also it keeps the gun a little cleaner from the spatter.  I don't think I'd use a 2 inch stick out on a small 110V machine, though.  I might stick with 1/2" - 1" for those small machines.
rockhound
Very cool.  :thumbs:
I need to practice different techniques. I didn't know.
I thought  you were never supposed to push the weld, always holding at about 30 degrees and working away from the weld.
I didn't know about spiral movement on the tip till I saw the guy welding my spring hangers to the frame. He made some sweet beads. A little practice and I could also, on scrap, but trying to upside down or around tubing with a helmet, forget it. And a straight line for about 3 inches  and I starts to miss the desired path. Plus the welder needs to cycle.
Welding is an art, and I dig it!    :flamer:   :yupyup:  :thumbs:
kyle_22r
yeah, i don't stick the wire out very far.  i always point the gun towards the start of the weld, i learned this in my days of doing dual shield(both flux and gas, used for deep penetration on thick joints) at school.
when doing most kinds of joints, i use a weaving zig-zag technique.  get a nice puddle going, move it slightly up and to the other side, and over and over again.  i used this technique on a stick welder to run my root passes, then generally drag all the other passes with some slight side to side movement to flatten the bead out.  some people may say its a bit weaker but i've never had a problem with slag inclusions -- when my test plates were bent, there were 0 discontinuities on my vertical plates
gonzo
Quote from: Weldo on May 12, 2005, 06:25:58 PM
Hey Weldo what do you use to clean your tip?  I've been using a dipping jelly, anything better that you know of?
Weldo
Using that nozzle dip or anti spatter spray is good.  It makes the spatter removal easier.  To clean the nozzle and contact tip I use pliers.  You may have seen those "MIG pliers" at harbor freight or something.  They work good, but needle nose pliers will work just fine as well for cleaning out the spatter.
Makman
Note that vertical welds are typically supposed to be run uphill if they are to have any significant structural value.  It's harder to do but prevents a cold-lap condition possible when running downhill.  When welding around a tube, it's hard not to weld in a little of every position on the way around so you just do what you have to do.
If it never breaks, people can only speculate how much it was overbuilt.
gonzo
Quote from: Weldo on May 13, 2005, 12:15:26 PM
Awesome Thanx Weldo  :thumbs:
guywithuglyyota
Whats the best method for welding upside down with flux-core? Im assuming you turn up the wire speed slightly?
Im currently using .30 flux core from lincoln
kyle_22r
haven't tried overhead with my flux yet.  i'll have to give it a whirl soon :crossed:
who in their right mind runs a structural vertical weld downhill??? :slap:
guywithuglyyota
I try to never run while im welding, hard to keep a good bead.   :yupyup:      bad joke sorry
Weldo
Quote from: kyle_22r on May 13, 2005, 05:43:33 PM
For overhead, set the machine similar to what you might do for flat, maybe turn the wire speed down a hair.
There are certain codes that require downhill welding.  Mostly all plate is welded uphill, but there is some codes that call for downhill MIG, especially for root passes, on pipe.  Also, the API 1104 pipe welding code requires E6010 root and filler, all downhill.  Conversely, the ASME Section IX code for pipe welding requires all uphill.
burnyota
wow!
I think that we have enough info on this subject to start a research paper...buts thats way cool  to all share our knowledge...same here as far as bend tests go - all have passed in mig,arc,and flux..the best are the side bends in arc...here is a pic from 1st semester arc
CTENG in KS
TTT
Hey Kyle_22r
How are you feeling about the duty cycle on that little guy.  It says 10% at 80 amps...is it REAL slow going or will it lay a few beads before it needs a rest?
kyle_22r
you know, i havent pushed it to the point to where it shuts down on me(supposedly its thermally protected).  i can run a couple 3"-4" beads, let it cool a little bit while i wire wheel the slag off and prep for my next weld etc and it's ready to go when i need it.  of course i wouldn't mind having something a little more powerful with a better duty cycle, but you wont find a better wirefeed for $120 :yupyup:
CTENG in KS
That's pretty kool...I gotta make some kind of a decision on a welder one of these days.
kyle_22r
the real test is going to be when i install crossover steering within the next month or two :eyebrow:
burnyota
Yo! how is your welding comming along??
kyle_22r
not too bad.  i pulled it out after work yesterday to help my little brother with his skateboarding box(he was putting a piece of angle on the side to grind on so he wanted me to weld 2 pieces so it'd be long enough with no seams).  this was like 1/8" stuff the welder handled it like a champ!  it actually got a little hot on the first pass i made and burned through it!
CTENG in KS
Still going well...?  I threw in my $115 bucks, I gotta see how these work.  Got some small non-structural progets to test it with.  Just can't see spending too much when I know in a year or so I will have a place for a 220V unit.   :crossed:   We will see.   :gap:
toybuilt
1983 Toyota Turned Chevy
eddyb
We have both in the garage, stick and MIG and use both according to what we are doing.  For the record we use 7018 rods in the AC buzzbox and .30 wire in the MIG(with gas of course).  I've been doing alot of welding at work recently, welding heavy duty mesh to steel studs to keep people from breaking through the walls.  I've been getting the best results from the highest amperage and the speed set at a little under 2.  The metal is very dirty and galvanized.
A bad day of wheelin' is better than a good day at work
CTENG in KS
Hope you are wearing a mask...galvanized puts off sum yukky fumes.  :hammer:
eddyb
puts hair on your chest
gonzo
Quote from: eddyb on June 17, 2005, 04:03:53 PM
and your tongue......best to stay clear of the fumes......it is difficult some times.
might kill you too.
eddyb
I keep well away from it.  It is some foul stuff.
