questionable runner -> on the road and never done
Started by 83yota, November 21, 2010, 03:17:19 PM
Nimyad
If you rotate it so you can run a flat pitman instead of just moving it forward, you can move the box farther forward without having to cut the body mount.
83yota
83yota
HELP!!!!!!!!!!!!!!
So we cant get my rig up at all. We have tried a set of allpros. Then tonight we tried a set of 48" rears and still no luck. I dont know what to do. I really want to get this thing out but my springs are as flat as can be. I dont know what to do. I want to see if anyone has an idea on maybe a hybrid pack to build. Luke was thinking adding 2 more lower springs from another rear spring pack I have. If anyone has any ideas what to build let me know. Looking around waggies are expensive so if you have another idea let me know.
Here are a few pics of the RUF as it sits tonight. Any help would be great
86bobbedtoy
83yota
86bobbedtoy
it wont
how many are in the pack?
I always run 6, I put 2 packs together
GONZO97
you need to put an overload in that pack or more leaf springs
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
86bobbedtoy
looked at the pics better
yeah add some leafs for sure,
look at my old build and see how it sits
84toytank
i run 7 on mine rufs mixed with junk yard ford springs the fords have alot of arch to lil springs and u have a ton of axel wrap. go to local yard and find same width springs wit the most arch u can find
ToyTanK
yoda power!!!!!
83yota
cool maybe I will try to get over to the yard tomarrow and see what I can find.
bleakhorizon
x whatever on the run more leafs,  i run 6 in my front ruf...
old runner had 7 and had a couple chevy 4" leafs mixed in, didnt flex as good but rode higher and drove awesome compared to double RUF pack
Those are some huge welds!
Tillamook, OR
Nimyad
My ruf's a factory 81 pack with the longer overload taken out and I added one 6" lift Cherokee spring. Also notched the frame for more up travel..
Peterbuilt84
Just mix the all pro and ruf packs and see what it looks like.
83yota
I really dont want to sacrfice performance. so maybe i will try some and see what happens
83yota
Well last night I took 45 min and pulled one spring pack appart and pulled the other one off the truck. Now what should I cut the springs with so they are stagered?
IronClad
i used a torch for mine but any abrasive type cutting will work.  dont bother with a sawzall
Annihilation  Fabrication
Do you need a Hammer?
83yota
Peterbuilt84
Did you put the packs together and bolt them up to see how it looks on the truck? I know it's a bit more work, but before you start cutting springs I would see if it's helped the issue you had :twocents:
84toytank
dont use a torch use an angle grinder and cut off wheel then use a flap wheel to clean them up
ToyTanK
yoda power!!!!!
86bobbedtoy
Quote from: 84toytank on January 10, 2012, 06:41:26 PM
what I did
83yota
That what I was thinking. I was not going to put them on first because if it does not fix it I am not going to put the other set back together. I was planing on just cutting it off before I clean them up and then putting them together and try it out.
83yota
Well.... This whole deep seated desire to get back in shape is really messing with my rig time. Well last night after I got home I cut the 6 springs I am going to put in the packs. I used a 4" cutoff wheel and it did great. Then I took a 4" flapper wheel (40 grit) and cleaned the springs up. Got one painted. will get the rest painted tonight and put back together in the morning. Then Sunday morning I will put them on with pics.
Sparkplug
I torch mine off also, cutoff, chop saw, heat vision, dont really matter
spc mike
Nice, i'm interested to see how it comes out. How far apart did you stagger the springs from each other?
IronClad
torch is fine since you are just cutting the ends off. been doing it for the past 10 ish years and havent had a problem
GONZO97
I use a torch on mine just do it quickly and youll be fine
The Build:
Coming Soon
*** YELLER ***
except BACON
83yota
The cut off wheel worked really well. 3" off each side
Yota87Truck
Sweet.  I need to build a custom leaf pack for my tacoma.  Looking forward to the pics.
