questionable runner -> on the road and never done
Started by 83yota, November 21, 2010, 03:17:19 PM
bigarms23
as for steering go with sky manufacturings crossover steering or high steer and you forgot going with a chevy master cylinder but i like your plan
83yota
i need to run the chevy MC. good to know before i scrap the truck. anything else i should get off the truck?
sabatoa1
I think that we should chop the top off this weekend, and get the motor and trans out. It will make it easier to push around. I think that once we take that all apart it will help us when we start chopping off the ifs.
1984 4runner buggy 22r on pane, duals, hydro assist, spool front, spool rear, 37x13x16 Creepy Crawlers.
http://board.marlincrawler.com/index.php?topic=89989.0
83yota
Ok so I picked up a 94 runner. took the doors and tailgate. 90runner took some stuff and my room mate took the seats. if you need anything else let me know. I will get some pics of where I am at. plan is to scrap the 94 by friday but that means i need to get out there and do something.
sabatoa1
I think he is going to try and make his steering because of how much the sky kit is, but I think he is going to buy the outboard shackle's from sky. He pulled his MC and booster so he has that now, and he is working on getting peices together. He needs the front bar, shackles, high steer, brakeline's, frame spacers, and some other misc. items. He has some perches for the rear with shackle's and 63" Chevy's, but he might be going with fj coils which will give him the front bar because the perches.
83yota
So i put the doors on last night (got pics but not up yet.) but i came to the realization that 2nd gen doors are A LOT heaver than my 1st gens. I droped the drivers door. and now both the rear corners are bent, and there is a dent in the door but I will get it fixed.
83yota
The new doors on.
you can see the tag sticker on the fender
This is how clean the floor is when I pulled the carpet
the new tail gate
the parts runner
83yota
the fire fender
So for now just gathering parts. hopefuly starting the bob this weekend and maybe doing the wiring on the new doors.
so progress might slow due to my DD being broke for now.
83yota
So a quick question... i am doing an internal cage on this a-pillar with a dash bar, b-pillar with a brace bar behind the seats that the harnesses will mount to and a c-pillar built the same as the b-pillar. no0w the question is; Is .095 wall 1.75 DOM strong enough to hold up in a roll over?
83yota
ok i know its rough but it is on paint and took me about 2min. but this is the idea of how i am looking at my cage. remember I am wanting to know if .095 1.75 DOM is going to hold. all interior.
Sparkplug
.095? thats less than a tenth of an inch thick. Too thin for a cage, needs to be about double that.
83yota
i figured but i found dom for less than 4 a foot for that so i thought i would ask
83yota
Well I got the wheels yeaterday. I am hopeing that my truck will sell in the next day or 2 and then I can get the stuff to finish it up.
jtaco1
Go with 0.120" wall for the main cage tubes and you can use 0.095" for gussets and non-essential tubes.  Don't skimp on materials, the cage could save you or your friends life in a roll over.  Your vehicle weight dictates the need for 1.75"x0.120" tube if you go by SCORE Rules, which is a great guidline.  (3001 - 4000 lbs. 1.750" x .120" CDN/4130/Seamless or ASTM 1018/1026 CDS/DOM)
As for your sketch, the curved tube like that will not work as you don't have enough room to run something like that inside the cabin.  Take a look at some other manufactures cages to get an idea of what works.
Also, you may want to look into getting a pre-built/bent cage.  Once you figure out how much tube you need, bend it and what not, you may be better off getting one already done.  I ended up getting mine from 4xInnovations in DOM and it is a great cage that takes less than a day to install and rather inexpensive when you look at what you are getting.
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual cases w/ 4.7's, Elocker rear axle, 37" PB Rockers and no lift
Was
99' Toyota Tacoma Crushed by Toyota
83yota
#44
So I have come across a vortec 4.3 for basically nothing. I am considering doing this swap instead of th 7m I was looking at before. Is the 700R4 the way to go and the 203/205 t-case. How would you suggest going, go with an after market wiring harness. Should i take it apart and rebuild it? it is supposed to have about 200k on it. I drove the truck it was in and it seemed to run fine. a little dirty but no major leaks i could tell. Now if i do tear it down sould i do some upgrades? any suggestions would be great.
i did get a little done today between school work, kids and a sick GF
OffRoadMedic
A 4.3 would be good for that truck, but I think a 4BT would be a better way to go.
83yota
OffRoadMedic
If I had that type of money My 87 would have a built 4BT in it. :flamer:
4RunnerChevy
Use the 4.3, since its a CPI, rebuild the upper plenum.
83yota
What do you mean rebuild the plenum? I know what you are talking about but what do you do to it?
bigarms23
use the 4.3 and the 700r4 trans will work fine with a 203/205 doubler and i think kev is talking about the spyder injecters
83yota
4RunnerChevy
4.3 CPI's have injector issues.  Before you install the motor you should replace the regulator, Nut kit (2 fuel hoses inside plenum), and look over the spider assembly inside the plenum.  If the inside of the plenum looks washed clean, then you have a leak.  Take the upper plenum cover off and have a look around, you will see all the hoses, they rub and get leaks. Other than that, they are awesome power plants.
I have no issues with my 700R4, although mine is slightly built.  You can go with the 203/205 or the toy case with an adapter.
83yota
The plan is to go with the 203/205 because I can source those for almost nothing. I will pull that apart tonight and see what I can find. I there a kit or do i need to get these seperatly?
bigarms23
but since the 4.3 has 200k on it i would tear it apart and rebuild it
83yota
well the question is since it was running well do i fix the plenum and put it in get it all set up and wait for it to go since it is not a dd? i understand the whole fix it now, but if i do that i am going all out and getting it punched .040 over and dish tops so i can eventually run a charger.
83yota
So i got something to help me with the Questionable Runner. I picked up this little beauty for 2k. Comes with 2 gear driven t-cases (1 forward 1 top) the adapter to run the gear case behind the 6cyl 5 speed, a book full of reciepts, 5 BRAND new 33 BFG KM2, and 3" of lift, and a brand new 3.0 (already insatlled) OH speaking of that what is wrong with the 3.0? This is the first one i have driven with the manual and I have no complaints. The plan is run teh IFS untill i brake it and then I will do the solid axle full widths and then run the engine till I get the 4.3 built up and ready to go in.
all the reciepts
The adapter
83yota
SOOOOOOOOOOOO.... I was working on the runner to day and i fouund a bent body mount. WELLLLLLL.............. upon hitting it i hit the steering "thing" I am not sure what it is but it is leaking BAD. do I need to replace the lines or can I eliminate it all together? My buddies 90 with the 3.0 does not have it. this is what it looks like
it is located in the pass side wheel well
83yota
well i am going to pick and pull to see if i can find one of these. wish me luck
83yota
got it all tightened back up and going again. For my first tank i am getting just under 15mpg but that was ALL in town stop and go. Cant really complain. Ran it down the freeway today at 80 and it did great. hopefully this weekend I can take it out. I ordered my gears yeaterday and they should be here today. Maybe get them put in on friday.
