Author Topic: Weber on my built engine  (Read 6074 times)
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: Weber on my built engine
« Reply #30 on: Sep 16, 2010, 10:45:43 AM »
Yea, you won't have a 160 if you bought the mileage/high altitude kit.  That's pretty fat jetting.  At what elevation are you?  Does it come with a chart that shows which jets should be matched with what?
And where'd you get your starter... and please don't say kragen/schucks/vatozone/o'reilly's.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #31 on: Sep 16, 2010, 12:56:57 PM »
well, we dont know where you live so :dunno:
yea, what elevation are you??
1badeagle [OP]
  • Turtle Points: -1
  • Member since Mar '09
« Reply #32 on: Sep 16, 2010, 01:10:24 PM »
My first post says Columbus, ohio but im not sure the elevation. The kit didnt come with a chart and yes. The shitty starter came from autozone. This was the 4th replacement before the year warranty was up. Im trying to get ahold of a guy locally that has a used factory one for 25 bux that im gonna pick up from him.
1badeagle [OP]
  • Turtle Points: -1
« Reply #33 on: Sep 18, 2010, 04:37:58 AM »
Alright guys, my starter had just gotten hot is all. She's alive again. I played around with my mixture this morning and I can get it to idle good and free rev pretty well, but as soon as I drive it, it gets ugly. As long as I'm driving really slow at a idle it's fine, but when I try to accelerate easily or hard it starves for fuel and dies. If I turn the psi on my fpr up to about 5 it runs ok, but still has a stumble when you floor it. Why can't I lose the fpr and jet it down? It ran a ton better without the fpr anyways??
1badeagle [OP]
  • Turtle Points: -1
« Reply #34 on: Sep 18, 2010, 09:08:31 AM »
Ok guys, I got a quick update for you. I pulled the fpr off and changed my fuel jets from 145p and 150s to the 140p and 145s. I also advanced my timing a bit and she's running pretty good now. No more stumble when you smash on the gas either. Made it much more drivable and I didn't have any stahling issues.
« Reply #35 on: Sep 18, 2010, 09:26:44 AM »
sounds like your timing is bad off
« Reply #36 on: Sep 18, 2010, 09:27:32 AM »
LOL  well :thumbs:
  • Male Posts: 9,757
« Reply #37 on: Sep 18, 2010, 11:19:07 PM »
Mine didn't appreciate having a fpr on it.  Wasn't able to keep up at higher load, despite where the float was set.
1badeagle [OP]
  • Turtle Points: -1
« Reply #38 on: Sep 20, 2010, 07:53:50 AM »
Mine absolutely hates the fpr no materr what anything is set at. Hopefully my fuel mileage will go up past 14 with the smaller jets in it and more timing added.
  • Male Posts: 9,757
« Reply #39 on: Sep 23, 2010, 10:22:22 PM »
I think I had 140/145 in an attempt to gain better mileage, but found myself constantly having to dip into the secondary cause it wouldn't get out of it's own way, and was burning through gas quickly.  Went back to 150/155 or 155/160 and it has more balls now, but I've only gone through one tank and can't afford to top it off yet to figure my mileage.  Kinda hard to figure out for sure though since my tires are 6" taller than stock and I have a slightly taller rear ratio than stock too  :haha:
« Last Edit: Sep 24, 2010, 05:13:58 PM by kneedownnate »
« Reply #40 on: Sep 24, 2010, 10:20:22 AM »
I think I had 140/145 in an attempt to gain better mileage, but found myself constantly having to dip into the secondary cause it wouldn't get out of it's own way, and was burning through gas quickly.  Went back to 150/155 or 155/160 and it has more balls now, but I've only gone through one tank and can't afford to top it off yet to figure my mileage.  Kinda hard to figure out for sure though since my tires are 6" taller than stock and I have a slightly taller rear ration than stock too  :haha:
:ack:
  • Male Posts: 9,757
« Reply #41 on: Sep 24, 2010, 05:15:36 PM »
Oops, said ration instead of ratio.  Only way I can figure my mileage for sure is if I had a gps or could easily track how far I actually go.
1badeagle [OP]
  • Turtle Points: -1
« Reply #42 on: Sep 28, 2010, 03:51:21 PM »
Thats funny, i havent been able to check my mileage yet. Hopefully it goes up though cause it blows right now.
  • Male Posts: 9,757
« Reply #43 on: Sep 28, 2010, 08:47:37 PM »
Of the few 4wd toyotas I've had, most have pulled about 15 mpg stock.
1badeagle [OP]
  • Turtle Points: -1
« Reply #44 on: Sep 29, 2010, 04:07:25 PM »
wow that blows. my 89 which it was efi would run close to 23 on the highway. Id seriously be tickled with 17 or 18 mpg
DTPROFAB
  • Turtle Points: -1
  • Male Posts: 107
  • Member since Apr '09
  • 0331
« Reply #45 on: Oct 01, 2010, 09:41:56 PM »
also im not sure if anyone mentioned it but lc enginering said that the stock mechanical fuel pump puts out 10 + psi and that a weber to work right at any elivation needs 4- 5.5 psi i had this same issue with my weber as well and the guys at lc have everything you need and will answer your questions over the phone and trouble shoot with you
libo beer and bullets 0331
STI-dd....81 toy putting in a 5vz-fe
Last post Oct 21, 2004, 12:37:03 PM
by hacksaw
Last post Aug 13, 2005, 12:27:35 AM
by toyotaboy
Last post Jun 01, 2015, 09:16:39 PM
by Cheesemaker
Last post Sep 20, 2007, 07:56:39 AM
by Rocksurfer
Last post Jun 12, 2019, 06:00:05 PM
by sirdeuce
